Discuss
GE Over-The-Range MW Won't Heat. . .
 in
Microwave Repair
Fixed!!! Bad Mag (even though it seemed to test out ok.) . . Falcon
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » GE Over-The-Range MW Won't Heat. . .
  #11 (permalink)
Old 05-11-2008, 04:20 PM
FalconEddy FalconEddy is offline
Junior Member
FalconEddy is on a distinguished road
Default Excellent!. . .
Fixed!!!
. . Falcon
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #12 (permalink)
Old 05-11-2008, 06:01 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
We are glad you were able to fix it.
__________________
Professional appliance repair in Los Angeles, California.
  #13 (permalink)
Old 05-12-2008, 06:37 AM
Junior Member
Default
Quote:
As was I.
Electronics that use KV are more of an intimidation factor than anything else.
You just need to be smart about things, make a checklist, double check your discharged caps, stay systematic. . . .and curse a little bit now and then.
The rewards of the accomplishment itself, and saving hundreds of dollars in the process, are well worth the time and effort when a resolution has finally been achieved.
Thanks to all,
. . Falcon
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer will not heat during timed drying; will heat for short time while auto drying mg13nj Dryer Repair 11 11-11-2008 04:50 PM
GE Range shuts off during pre-heat MJV66 Oven Repair (including Ranges and Cooktops) 0 04-04-2008 12:13 PM
Heat but not drying, seems like heat is not blowing good Papa1 Dryer Repair 2 10-07-2007 11:11 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
