| » GE JVM1851 won't heat |
Model Number: JVM1851WH02 Brand: GE Age: 5 - 10 years
Hello All,
I have a GE SpaceMaker 1800XL microwave model #JVM1851WH02 that doesn't want to heat anything. A couple weeks ago I noticed that things I tried to heat up didn't heat up as much as they have in the past. Today something made a little pop sound and now nothing heats up and the microwave makes more of a humming noise. The keypad, lights, turntable, etc. all still work fine. I unmounted the microwave from the wall and opened it up. I discharged the cap and checked the high voltage diode. It is only reading about 11 ohms and is open both ways. So, that needs to be replaced but I have read on this forum and some others that the magnetron may be the real problem. If I replace the diode it may go bad again because of the magnetron? How do I test the magnetron to see if it is working properly? If I have to replace the diode and the magnetron I am looking at about $160...might as well buy a new microwave. What a shame... Any help would be appreciated. Thanks! Ads By Google Related Models |
| Display Modes | |
| Roper (Gas) Dryer heats up then heat goes off (still running, no heat) | jtdesignsca | Dryer Repair | 3 | 01-17-2013 12:06 PM |
| Wall oven will not heat/re-heat properly | dottavio | Oven Repair (including Ranges and Cooktops) | 0 | 01-07-2010 09:47 AM |
| Dryer will not heat. It tumbles and cycles but it will not emit any heat. | agentsmith0505 | Dryer Repair | 0 | 10-14-2009 09:44 AM |
| Normal Heat Empty, Heat Shuts Off Full | BigDaddyG | Dryer Repair | 4 | 08-06-2009 03:17 PM |
| No Heat While Turning, Heat When Stopped thou | msg2008 | Dryer Repair | 1 | 08-07-2008 05:08 AM |
