| » Whirlpool KM-27 dead, no power |
Model Number: 8178053 Brand: Whirlpool Age: 1 - 5 years
My Whirlpool microwave is right around 5 years old and has always worked perfectly.
Recently, it just went dead. No lights, no display, no power. The outlet it is plugged into works fine. Plugging the microwave into a new, known good outlet does not help, still dead. I replaced the Line Fuse inside the microwave with a new 20A fuse. No change. This is the document that I am using as reference: https://secured.whirlpool.com/Servic...LE/8178053.pdf What would be my next best troubleshooting step? Thank you in advance. -Tom |
Do you have (and know how to use) a multimeter?
Also we need the full model number from the unit. The numbers you gave us are for the manual itself and not microwave model number. Last edited by glen65 : 05-08-2008 at 12:12 PM. |
Yessir.
If I heard no advice before this weekend, my next step would be to test each component with a multimeter. I think there's even notes in that PDF about what I should see for each component. Does that sound like a good plan? Thanks. -Tom |
In this model, the fuse and the oven thermostat are the only two devices designed to kill power in the event of trouble.
If the oven lamp doesn't come on when you open the door, I'd say you have an open oven thermostat.
__________________
William E. Miller, AS-EET prototech@usa.net Feel free to contact me directly with your tough microwave oven technical questions! |
Hey Glen65, sorry for the confusion (on my part). The model number is: MH6141XK Q-1
(sometimes the Q-1 is ommitted in the paperwork but I'm 100% sure about the rest) Hey MicrowaveDisplaycom, I think I follow you. If I have an open condition at the thermostat, no power will cross it (like any other open condition). So do I need to replace the thermostat to resolve this (which I think I can do), or is there a less involved fix? Thank you both for your patience and assistance. -Tom |
Quote:
Use your ohm meter and check for continuity across both the thermostat and the main fuse (even though you’ve replaced it.) The thermostat is covered in the manual you posted. |
CORRECTION: THe thermostat passes voltage with no impedance when it is cold.
Sorry, had got that one backwards and asked an engineer to check me. Anyway, when out of the microwave and cold, there is no impedance through the thermostat. -Tom |
| Display Modes | |
| GE Profile dead, power surge | Simbot | Microwave Repair | 17 | 07-26-2008 03:18 PM |
| Dead Whirlpool Range | jaybosserman | Oven Repair (including Ranges and Cooktops) | 1 | 12-12-2007 08:41 PM |
| whirlpool seneon dryer dead | tnash542 | Dryer Repair | 0 | 10-15-2007 05:38 AM |
| No Power - completely dead | Zeaon | Microwave Repair | 1 | 09-15-2007 09:19 AM |
| Power Outage-Now My Dryer Is dead | Annie | Dryer Repair | 0 | 08-14-2007 09:49 AM |
