Discuss
Whirlpool KM-27 dead, no power
 in
Microwave Repair
My Whirlpool microwave is right around 5 years old and has always worked perfectly. Recently, it just went dead. No
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Whirlpool KM-27 dead, no power
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-07-2008, 11:43 AM
gospog gospog is offline
Junior Member
gospog is on a distinguished road
Unhappy Whirlpool KM-27 dead, no power
Model Number: 8178053   Brand: Whirlpool   Age: 1 - 5 years
Recently, it just went dead. No lights, no display, no power. The outlet it is plugged into works fine.
Plugging the microwave into a new, known good outlet does not help, still dead.
I replaced the Line Fuse inside the microwave with a new 20A fuse. No change.
This is the document that I am using as reference:
https://secured.whirlpool.com/Servic...LE/8178053.pdf
What would be my next best troubleshooting step?
Thank you in advance.
-Tom
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-08-2008, 11:02 AM
glen65 glen65 is offline
Senior Expert
APP Volunteer
glen65 is on a distinguished road
Default
Do you have (and know how to use) a multimeter?
Also we need the full model number from the unit.
The numbers you gave us are for the manual itself
and not microwave model number.
  #3 (permalink)
Old 05-08-2008, 11:09 AM
Junior Member
Default
Yessir.
If I heard no advice before this weekend, my next step would be to test each component with a multimeter. I think there's even notes in that PDF about what I should see for each component.
Does that sound like a good plan?
Thanks.
-Tom
  #4 (permalink)
Old 05-08-2008, 02:42 PM
Senior Expert
APP Volunteer
Default
I believe we can at least set you in the right direction
but we still need the full model number from your oven.
  #5 (permalink)
Old 05-08-2008, 08:06 PM
MicrowaveDisplaycom MicrowaveDisplaycom is offline
Junior Member
MicrowaveDisplaycom is on a distinguished road
Default
In this model, the fuse and the oven thermostat are the only two devices designed to kill power in the event of trouble.
If the oven lamp doesn't come on when you open the door, I'd say you have an open oven thermostat.
__________________
William E. Miller, AS-EET
prototech@usa.net
Feel free to contact me directly with your
tough microwave oven technical questions!
  #6 (permalink)
Old 05-09-2008, 06:01 AM
Junior Member
Default
Hey Glen65, sorry for the confusion (on my part). The model number is: MH6141XK Q-1
(sometimes the Q-1 is ommitted in the paperwork but I'm 100% sure about the rest)
Hey MicrowaveDisplaycom, I think I follow you. If I have an open condition at the thermostat, no power will cross it (like any other open condition).
So do I need to replace the thermostat to resolve this (which I think I can do), or is there a less involved fix?
Thank you both for your patience and assistance.
-Tom
  #7 (permalink)
Old 05-09-2008, 07:51 AM
Senior Expert
APP Volunteer
Default
-Tom
That may very well be the cause but you need to check it first.
Use your ohm meter and check for continuity across both the
thermostat and the main fuse (even though you’ve replaced it.)
The thermostat is covered in the manual you posted.
  #8 (permalink)
Old 05-11-2008, 09:51 AM
Junior Member
Default
Ok, so I tested across the thermostat with the multimeter (set to resistance) and it reads "infinite ohms".
So, I'm planni9ng to replace the thermostat. Does anyone know a reliable place to pick one up?
Thanks.
-Tom
  #9 (permalink)
Old 05-11-2008, 12:48 PM
Senior Expert
APP Volunteer
Default
You can get it here..
Model MH6141XKQ1
Part Number: AP3683988
  #10 (permalink)
Old 05-12-2008, 05:27 AM
Junior Member
Default
CORRECTION: THe thermostat passes voltage with no impedance when it is cold.
Sorry, had got that one backwards and asked an engineer to check me.
Anyway, when out of the microwave and cold, there is no impedance through the thermostat.
-Tom
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Profile dead, power surge Simbot Microwave Repair 9 04-16-2008 12:47 PM
Dead Whirlpool Range jaybosserman Oven Repair (including Ranges and Cooktops) 1 12-12-2007 07:41 PM
whirlpool seneon dryer dead tnash542 Dryer Repair 0 10-15-2007 04:38 AM
No Power - completely dead Zeaon Microwave Repair 1 09-15-2007 08:19 AM
Power Outage-Now My Dryer Is dead Annie Dryer Repair 0 08-14-2007 08:49 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
