Discuss
Microwave with broken door latch tabs
 in
Microwave Repair
Our microwave oven doesn't work because the door latch tabs (2) on the inside edge of the door have
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Microwave with broken door latch tabs
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-03-2008, 10:11 PM
condochris condochris is offline
Junior Member
condochris is on a distinguished road
Default Microwave with broken door latch tabs
Model Number: KMHS147HSS1   Brand: Kitchen Aid   Age: 5 - 10 years
Our microwave oven doesn't work because the door latch tabs (2) on the inside edge of the door have been snapped off on the ends so the door cannot latch. We have located the part # for the 2 broken pieces (#4393913) and have found a supplier to order them from. However, we can't figure out how to open the door panel so we can install the 2 latch tabs. Can anyone tell us how to install these 2 parts?
Thanks!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-14-2008, 07:04 AM
Uncle Mac Uncle Mac is offline
Junior Member
Uncle Mac is on a distinguished road
Default I did it!
I've got a GE over the range model and have spent the last two and a half hours trying to solve the same problem. I just fixed my microwave in about ten minutes once I saw the light.
Open the door and work from the inside. There is an inner seal that sets in from the outside of the frame about a inch or so. This has tabs that makes it attach to the metal frame. Put a putty knife between the seams and loosen the tabs.There is a video on YOUTube that shows how this is done.
On my GE this lets you see another screw that allows you to remove the handle.
Next, there is a faceplate with the holes that the handle fits into. This faceplate will pry out if you pry towards the outside edge of the door. Once this is off you have to apply the putty knife to the seam between the outside frame and the inner metal frame that holds the glass. )I discovered this with my thumbnail !)
The trick is finding that line between the aggression that breaks something and the timidity that solves nothing--just keep gently trying different angles for prying the putty knife.
  #3 (permalink)
Old 05-14-2008, 07:22 AM
Junior Member
Default
Thanks for the info...I viewed a video last week showing the same thing you described and I was able to open the doorpanel, remove the broken door latches and replace them with new parts I ordered from AppliancePartsPros.com. This saved me about $175!
  #4 (permalink)
Old 05-14-2008, 07:37 AM
Junior Member
Default
Congrats--I figured I probably saved about the same!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Door Latch Broken Flora5 Dishwasher Repair 7 03-27-2008 05:59 PM
Replacing Latch Spring on Microwave Door Idoitmyself Microwave Repair 1 03-25-2008 04:12 PM
Broken door latch assembly jf1942 Microwave Repair 1 03-13-2008 05:33 PM
Microwave Door Latch broken rajnedra_b Microwave Repair 3 03-02-2008 01:52 PM
Door latch broken/Door locked kitade Dishwasher Repair 2 10-23-2007 10:42 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
