Discuss
Installing new door
 in
Microwave Repair
Can you please advise me how to install the new door to my GE microwave?
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Installing new door
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-01-2008, 09:04 AM
Danny Carter Danny Carter is offline
Junior Member
Danny Carter is on a distinguished road
Default Installing new door
Model Number: JTP86B0F1BB   Brand: GE   Age: 5 - 10 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-01-2008, 06:06 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Danny,
You have to remove the microwave from the oven cabinet.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 05-01-2008, 08:30 PM
Junior Member
Default
Dear Gene,
Thanks for your reply,this microwave is mounted above the oven and I will pull it out if necessary as you stated. It appears that the current door is attached and pivots by 2 metal hinges (1) at the top left corner and (1) at the bottom left corner. My question is how do I take the old door off and then replace it with the new one. Also are you sure I need to pull it out because it appears there are pins hinge that hold the door on. Please reply and thanks again for your info. Danny
  #4 (permalink)
Old 05-08-2008, 02:15 PM
stallm stallm is offline
Junior Member
stallm is on a distinguished road
Default How to replace the door assembly..
I also have the similar need..
I have a GE Profile Microwave (JVM1460WA), which is about 10 years old, has lots of cracks around the door, and latch/spring action is broken. Instead of replacing the individual parts, I'm thinking of replacing the whole 'door assembly' (part # AP2033297).
Wondering if anyone has comments on how easy / difficult to install, any links to instructions is greatly appreciated.
Thanks,
Sam
  #5 (permalink)
Old 05-09-2008, 01:41 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Danny,
There are two door hinges (upper & bottom) which are mounted with two screws each. You can reach these hinges only after the microwave is out of the cabinet.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Installing Oven Door Switch hesper73 Oven Repair (including Ranges and Cooktops) 0 04-18-2008 11:53 AM
Installing Lid On/off Switch CCRIDER05 Washer Repair 0 03-11-2008 11:32 AM
Installing an auger trishaustin Refrigerator & Freezer Repair 1 12-21-2007 01:38 PM
Help with installing inner glass in Whirpool over door kmg126 Oven Repair (including Ranges and Cooktops) 1 11-20-2007 11:16 AM
installing idler pulley darberryman Dryer Repair 2 11-08-2007 05:52 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
