| » Installing new door |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: JTP86B0F1BB Brand: GE Age: 5 - 10 years
Can you please advise me how to install the new door to my GE microwave?
Danny,
You have to remove the microwave from the oven cabinet. Gene.
__________________
Professional appliance repair services in Orange County, California. |
Dear Gene,
Thanks for your reply,this microwave is mounted above the oven and I will pull it out if necessary as you stated. It appears that the current door is attached and pivots by 2 metal hinges (1) at the top left corner and (1) at the bottom left corner. My question is how do I take the old door off and then replace it with the new one. Also are you sure I need to pull it out because it appears there are pins hinge that hold the door on. Please reply and thanks again for your info. Danny |
I also have the similar need..
I have a GE Profile Microwave (JVM1460WA), which is about 10 years old, has lots of cracks around the door, and latch/spring action is broken. Instead of replacing the individual parts, I'm thinking of replacing the whole 'door assembly' (part # AP2033297). Wondering if anyone has comments on how easy / difficult to install, any links to instructions is greatly appreciated. Thanks, Sam |
Hi Danny,
There are two door hinges (upper & bottom) which are mounted with two screws each. You can reach these hinges only after the microwave is out of the cabinet. Gene.
__________________
| Display Modes | |
| Installing Oven Door Switch | hesper73 | Oven Repair (including Ranges and Cooktops) | 0 | 04-18-2008 11:53 AM |
| Installing Lid On/off Switch | CCRIDER05 | Washer Repair | 0 | 03-11-2008 11:32 AM |
| Installing an auger | trishaustin | Refrigerator & Freezer Repair | 1 | 12-21-2007 01:38 PM |
| Help with installing inner glass in Whirpool over door | kmg126 | Oven Repair (including Ranges and Cooktops) | 1 | 11-20-2007 11:16 AM |
| installing idler pulley | darberryman | Dryer Repair | 2 | 11-08-2007 05:52 AM |
