Discuss
Relpaced magnatron--Still no heat
 in
Microwave Repair
Touch pad, turntable, fan, lights, all work but it will not heat. It loads up as if it were heating
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Relpaced magnatron--Still no heat
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 04-22-2008, 05:38 PM
mikemisko mikemisko is offline
Junior Member
mikemisko is on a distinguished road
Default Relpaced magnatron--Still no heat
Model Number: jvm1631wb002   Brand: GE   Age: 1 - 5 years
Touch pad, turntable, fan, lights, all work but it will not heat. It loads up as if it were heating with a somewhat louder humming noise. I have replaced the Magnatron but with no results.(waveguide shows some discoloration from heat). With door closed i have 2 door switches with continuity and 1 without. All heat sensors appear to be working. I checked for continuity of the HV capasitor (two treminals)and got nothing. and on the HV Diode(does not appear to have been hot, nor blowing fuses) and got a reading of 16.6 BOTH ways. Can you suggest a cure? THANKS
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-26-2008, 07:35 PM
bairjc bairjc is offline
Junior Member
bairjc is on a distinguished road
Default
you will not get any continuity at the capacitor you need a capacitor tester for accurate measurements, if you replaced the magnatron and have a loud humming noise is either coming from capacitor, or diode, but you might have a bad transformer in theat case it really sound loud, i would replace the capacitor it is the biggest issue on GE maicrowaves they are usually 92 uf, but you can use a QB capacitor, do not go any higher than 5 uf over, plus the QB parts are lots less in cost than manufactures parts.
  #3 (permalink)
Old 05-07-2008, 12:21 PM
hfriling hfriling is offline
Junior Member
hfriling is on a distinguished road
Default
Replace the HV diode,.....should fix your problem
  #4 (permalink)
Old 05-29-2008, 12:00 AM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
Always replace the HV Diode when changing a mag tube. Also if you have a burn mark on the wave guide, the new mag wont last very long. Did the end of the old tube look melted and burned?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer will not heat during timed drying; will heat for short time while auto drying mg13nj Dryer Repair 9 03-22-2008 11:40 AM
Heat but not drying, seems like heat is not blowing good Papa1 Dryer Repair 2 10-07-2007 10:11 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
