Discuss
Microvave turns off
 in
Microwave Repair
My GE Space Maker microwave oven recently started to turn off after aprox 2 seconds of operation and flashes that
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Microvave turns off
  #1 (permalink)
Old 04-22-2008, 02:47 PM
esmith esmith is offline
Junior Member
esmith is on a distinguished road
Default Microvave turns off
Model Number: JVM1653SH   Brand: GE   Age: 1 - 5 years
My GE Space Maker microwave oven recently started to turn off after aprox 2 seconds of operation and flashes that clock needs reset. After resetting it will continue to fail with same results. I have found that if control panel is tilted forward the unit will run and operate as normal with no failure. As soon as the panel is reinstalled in the normal position the failure returns. I have tried to move wiring and checked connections with no luck. I can't see how leaning the control panel forward aprox half an inch would make any differance but it does. Any Ideas?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-29-2008, 01:10 AM
abadfish66's Avatar
abadfish66 abadfish66 is online now
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
The problem is your magnetron tube is leaking RF. The mag tube comes on 2 seconds after you hit start, and the RF interfears with the board and shuts it down. That is why dropping the front down makes a differance. Get a new mag tube put in and you'll be good to go.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer inner tub turns cw and ccw clarktim Washer Repair 0 04-04-2008 04:25 PM
MH3184XP SI Whirlpool microvave RMuller Microwave Repair 2 12-26-2007 07:03 PM
Oven Turns On All By Itself!!! CHRISTOPHER Oven Repair (including Ranges and Cooktops) 3 11-29-2007 12:44 PM
Dishwasher turns on and off slangzang Dishwasher Repair 1 11-11-2007 05:19 PM
Panasonic Microvave fault snowey Microwave Repair 1 10-09-2007 07:38 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
