Discuss
Jenn-Air control panel stopped working
 in
Microwave Repair
When I tried to start the microwave today (Jenn-Air Model M169W), the control panel initially acted as if everything
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Jenn-Air control panel stopped working
  #1 (permalink)
Old 04-22-2008, 01:05 PM
jball jball is offline
Junior Member
jball is on a distinguished road
Default Jenn-Air control panel stopped working
Model Number: M169W   Brand: Jenn-Air   Age: More than 10 years
When I tried to start the microwave today (Jenn-Air Model M169W), the control panel initially acted as if everything was OK, but the microwave did not actually turn on. For example, I entered 2 minutes cooking time and pressed start, then the timer started counting down as usual, but the microwave did not actually do anything. I thought it might need reset, so I unplugged the unit and plugged it back in. At that point, there were no lights on the control panel whatsoever. The light on the inside works, so I know it has power. It is as if the control panel itself just died. Is this repairable, or am I looking at a replacement?
An update. I left the microwave unplugged overnight, then plugged it back in the next morning and it worked for a while. Then it did the same thing as before: first, the oven stopped working, even though the control panel showed the timer counting down. After unplugging again, the control panel failed to light up. Now, if I leave it unplugged for a few minutes, then plug it back in, I can get the control panel to light up, but the oven won't start.
Related Models
Jenn-Air M169W Mwave - Mounted Over Range/wo
Magic Chef M16C-10P Mwave - Cntrtp / Stand Alone
Magic Chef M16C-10PB Mwave - Cntrtp / Stand Alone
Magic Chef M16E-10PB Mwave - Cntrtp / Stand Alone
Magic Chef M16F-10 Mwave - Cntrtp / Stand Alone
Magic Chef M16F-10B Mwave - Cntrtp / Stand Alone
Magic Chef M16F-10P Mwave - Cntrtp / Stand Alone
Magic Chef M16F-10PB Mwave - Cntrtp / Stand Alone
Magic Chef M16FN-10 Mwave - Cntrtp / Stand Alone
Magic Chef M16FN-10B Mwave - Cntrtp / Stand Alone
Magic Chef M16FN-10P Mwave - Cntrtp / Stand Alone
Magic Chef M16FN-10PB Mwave - Cntrtp / Stand Alone
Jenn-Air M170B Mwave - Mounted Over Range/wo
Jenn-Air M170W Mwave - Mounted Over Range/wo
Hardwick M205 Mwave - Cntrtp / Stand Alone
Frigidaire M205F1QA Kel(v1) / Room Air Conditioner
Frigidaire M205F1QA1 Kel(v1) / Room Air Conditioner
Frigidaire M205G1QA Kel(v1) / Room Air Conditioner
Frigidaire M205G1QG Kel(v1) / Room Air Conditioner
Frigidaire M205H1QA Kel(v1) / Room Air Conditioner
Frigidaire M206F1QA Kel(v1) / Room Air Conditioner
Frigidaire M208F1EA Kel(v1) / Room Air Conditioner
Frigidaire M208F1EA1 Kel(v1) / Room Air Conditioner
Frigidaire M208F1QA Kel(v1) / Room Air Conditioner
Frigidaire M208F1QA1 Kel(v1) / Room Air Conditioner
Magic Chef M20A-2 Mwave - Cntrtp / Stand Alone
Magic Chef M20A-2-X9 Mwave - Cntrtp / Stand Alone
Hardwick M210 Mwave - Cntrtp / Stand Alone
Hardwick M215 Mwave - Cntrtp / Stand Alone
Magic Chef M22B-6 Mwave - Cntrtp / Stand Alone
Magic Chef M22B-6-T6 Mwave - Cntrtp / Stand Alone
Hardwick M240 Mwave - Cntrtp / Stand Alone
Hardwick M250 Mwave - Cntrtp / Stand Alone
Hardwick M260 Mwave - Cntrtp / Stand Alone
Hardwick M270 Mwave - Cntrtp / Stand Alone
Thermador M3-5
Frigidaire M316B2QA Kel(v0) / Room Air Conditioner
Frigidaire M316C2QA Kel(v0) / Room Air Conditioner
Frigidaire M316C2QB Kel(v1) / Room Air Conditioner
Thermador M3BG
Thermador M3G
Jenn-Air M400 Mwave - Cntrtp / Stand Alone
Jenn-Air M406 Mwave - Mounted Under Cabinet
Magic Chef M40B-3 Mwave - Cntrtp / Stand Alone
Magic Chef M40B-3-X9 Mwave - Cntrtp / Stand Alone
Magic Chef M40C-3-X9 Mwave - Cntrtp / Stand Alone
Magic Chef M40C-6 Mwave - Cntrtp / Stand Alone
Magic Chef M40C-6-X9 Mwave - Cntrtp / Stand Alone
Magic Chef M40D-3-X9 Mwave - Cntrtp / Stand Alone
Magic Chef M40D-6-X9 Mwave - Cntrtp / Stand Alone
Magic Chef M40G-14-X9 Mwave - Cntrtp / Stand Alone
Jenn-Air M416 Mwave - Mounted Under Cabinet
Jenn-Air M417B Mwave - Mounted Under Cabinet
Jenn-Air M418B Mwave - Mounted Under Cabinet
Frigidaire M418B2EA Kel(v0) / Room Air Conditioner
Frigidaire M418D2EA Kel(v1) / Room Air Conditioner
Frigidaire M418D2SA Kel(v1) / Room Air Conditioner
Frigidaire M418F2EA Kel(v1) / Room Air Conditioner
Frigidaire M418F2SA Kel(v1) / Room Air Conditioner
Jenn-Air M418W Mwave - Mounted Under Cabinet
Magic Chef M41B-1 Mwave - Cntrtp / Stand Alone
Magic Chef M41B-10P Mwave - Cntrtp / Stand Alone
Magic Chef M41B-10P-B8 Mwave - Cntrtp / Stand Alone
Magic Chef M41B-10P-W6 Mwave - Cntrtp / Stand Alone
Magic Chef M41B-2 Mwave - Cntrtp / Stand Alone
Magic Chef M41B-3 Mwave - Cntrtp / Stand Alone
Magic Chef M41B-3-W3 Mwave - Cntrtp / Stand Alone
Magic Chef M41B-3P Mwave - Cntrtp / Stand Alone
Magic Chef M41B-6 Mwave - Cntrtp / Stand Alone
Magic Chef M41B-6-X9 Mwave - Cntrtp / Stand Alone
Magic Chef M41B-6P Mwave - Cntrtp / Stand Alone
Magic Chef M41B-6P-X9 Mwave - Cntrtp / Stand Alone
Magic Chef M41B-9P Mwave - Cntrtp / Stand Alone
Magic Chef M41C-1 Mwave - Cntrtp / Stand Alone
Magic Chef M41C-10P Mwave - Cntrtp / Stand Alone
Magic Chef M41C-10P-B8 Mwave - Cntrtp / Stand Alone
Magic Chef M41C-3 Mwave - Cntrtp / Stand Alone
Magic Chef M41C-3P Mwave - Cntrtp / Stand Alone
Magic Chef M41C-6 Mwave - Cntrtp / Stand Alone
Magic Chef M41C-6-X9 Mwave - Cntrtp / Stand Alone
Magic Chef M41C-6P Mwave - Cntrtp / Stand Alone
Magic Chef M41C-6P-X9 Mwave - Cntrtp / Stand Alone
Magic Chef M41C-9P Mwave - Cntrtp / Stand Alone
Magic Chef M41D-1 Mwave - Cntrtp / Stand Alone
Magic Chef M41D-10P Mwave - Cntrtp / Stand Alone
Magic Chef M41D-10P-B8 Mwave - Cntrtp / Stand Alone
Magic Chef M41D-3 Mwave - Cntrtp / Stand Alone
Magic Chef M41D-3P Mwave - Cntrtp / Stand Alone
Magic Chef M41D-6 Mwave - Cntrtp / Stand Alone
Magic Chef M41D-6-X9 Mwave - Cntrtp / Stand Alone
Magic Chef M41D-6P Mwave - Cntrtp / Stand Alone
Magic Chef M41D-6P-W7 Mwave - Cntrtp / Stand Alone
Magic Chef M41D-6P-X9 Mwave - Cntrtp / Stand Alone
Magic Chef M41D-9P Mwave - Cntrtp / Stand Alone
Magic Chef M41E-10P Mwave - Cntrtp / Stand Alone
Magic Chef M41E-3 Mwave - Cntrtp / Stand Alone
Magic Chef M41E-6P Mwave - Cntrtp / Stand Alone
Magic Chef M41E-9 Mwave - Cntrtp / Stand Alone
Magic Chef M41E-9P Mwave - Cntrtp / Stand Alone
Magic Chef M41F-10P Mwave - Cntrtp / Stand Alone
Magic Chef M41F-14T Mwave - Cntrtp / Stand Alone
Jenn-Air M420 Mwave - Mounted Under Cabinet
Frigidaire M420B2SA Kel(v0) / Room Air Conditioner
Frigidaire M420C2SB Kel(v0) / Room Air Conditioner
Frigidaire M420T2SA Kel(v1) / Room Air Conditioner
Frigidaire M421D2SA Kel(v1) / Room Air Conditioner
Frigidaire M422F2SA Kel(v1) / Room Air Conditioner
Frigidaire M423T3SA Kel(v2) / Room Air Conditioner
Jenn-Air M426 Mwave - Mounted Under Cabinet
Frigidaire M428F2SA Kel(v1) / Air Conditioner
Jenn-Air M438B Mwave - Mounted Under Cabinet
Jenn-Air M438W Mwave - Mounted Under Cabinet
Jenn-Air M439B0 Mwave - Mounted Under Cabinet
Jenn-Air M439B1 Mwave - Mounted Under Cabinet
Jenn-Air M439W0 Mwave - Mounted Under Cabinet
Jenn-Air M439W1 Mwave - Mounted Under Cabinet
Jenn-Air M446 Mwave - Mounted Under Cabinet
Frigidaire M4521GNGW1 Frg(v1)
Magic Chef M46F-14T Mwave - Cntrtp / Stand Alone
Magic Chef M46FN-10-W9 Mwave - Cntrtp / Stand Alone
  #2 (permalink)
Old 03-24-2009, 03:30 PM
ebberjr3 ebberjr3 is offline
Junior Member
ebberjr3 is on a distinguished road
Default M169w
I have same piece of junk. Paid a lot of money to get what I thot was the best. It works OK for a year or 2 then has to be reset. Has cost me $225 over 10 yrs for Sears to come out to reset. Have you come up with a solution?
  #3 (permalink)
Old 04-23-2009, 07:28 PM
SpacemonkeyR SpacemonkeyR is offline
Junior Member
SpacemonkeyR is on a distinguished road
Default
What is it that Sear's resets? I have a JMC7000ADB doing the same. I turned the breaker off for 20min and it did not change. My display and controls work fine, and I hear a relay pull in.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Control Panel Touch Pad not working rtismeer Washer Repair 6 09-08-2008 11:30 AM
Replace control panel or just control panel housing? Max Strano Dishwasher Repair 1 08-26-2008 07:02 PM
Jenn Aire 27" oven keypad stopped responding GalanOfPT Oven Repair (including Ranges and Cooktops) 0 03-21-2008 06:12 PM
Jenn Aire Microwave stopped heating mmolhook Microwave Repair 0 12-26-2007 04:02 PM
Jenn Air sve47500 control panel light out... itr674 Oven Repair (including Ranges and Cooktops) 0 11-24-2007 08:38 AM
