Discuss
GE Microwave won't heat
 in
Microwave Repair
GE Microwave over the oven won't heat. What is the problem and is it worth the fix or should
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » GE Microwave won't heat
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 04-19-2008, 10:29 AM
Bburgi Bburgi is offline
Junior Member
Bburgi is on a distinguished road
Default GE Microwave won't heat
Model Number: JVM163WB 002   Brand: GE   Age: 5 - 10 years
GE Microwave over the oven won't heat. What is the problem and is it worth the fix or should I just buy a new one. This is an over the oven spacesaver.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-19-2008, 06:53 PM
glen65 glen65 is offline
Senior Expert
APP Volunteer
glen65 is on a distinguished road
Default
Whether it’s worth fixing will depend on what's actually
causing the problem you’re having with it. It would at least
be worth having it checked to determine the cause before
scrapping it. Does the display or interior light come on at all?
Or is the oven completely dead?
  #3 (permalink)
Old 04-19-2008, 10:26 PM
Junior Member
Default GE Microwave doesn't heat
Everything appears to work, display and interior light. When I do try to cook something though the microwave gives off a burning smell, food remains cold. Thanks for the information.
  #4 (permalink)
Old 04-20-2008, 09:24 AM
Senior Expert
APP Volunteer
Default
There all kinds of possibilities, I’ll just list a few.
Burnt wire connection
Bad high voltage components, such
as high voltage capacitor or diode.
Any of which could be brought on
by a bad magnetron.
A bad winding in the transformer.
These are just a few possibilities.
Some troubleshooting needs to be done
in order to isolate exactly what’s at the root
of the problem and determine how severe it is.
  #5 (permalink)
Old 04-21-2008, 10:20 AM
mcravey mcravey is offline
Junior Member
mcravey is on a distinguished road
Question microwave won't heat
De ja vu. This seems to be a recurring problem. My GE microwave is over 5 years old. Possibly one or more components have a short life span. It seems to be working properly, except that it obviously doesn't heat (a severe drawback). Since there are no odors or other indicators, is there one or more parts that are likely to be the problem? (coil, or transformer?)
  #6 (permalink)
Old 04-21-2008, 06:00 PM
gearhead1218 gearhead1218 is offline
Member
gearhead1218 is on a distinguished road
Default
For some reason, the magnetrons GE uses don't last.
Most likely that is your problem. But a proper diagnosis to eliminate any other possible causes is in order.
  #7 (permalink)
Old 04-22-2008, 05:08 PM
mikemisko mikemisko is offline
Junior Member
mikemisko is on a distinguished road
Default
I have the same model and the same problem but with a somewhat louder humm than normal. I replaced the magnatrom with no results, no heating.
Can you advise further?
  #8 (permalink)
Old 04-22-2008, 06:37 PM
Senior Expert
APP Volunteer
Default
Chances are you didnt need the mag.
You need to check the various components
such as HV diode and capacitor before purchasing
any other parts. One of them may be shorted.
  #9 (permalink)
Old 04-23-2008, 11:51 AM
Junior Member
Default
Thanks Glen--I have further INFO: Touch pad, turntable, fan, lights, all work but it will not heat. It loads up as if it were heating with a somewhat louder humming noise. I have replaced the Magnatron but with no results.(waveguide shows some discoloration from heat). With door closed i have 2 door switches with continuity and 1 without. All heat sensors appear to be working. I checked for continuity of the HV capasitor (two treminals)and got nothing. and on the HV Diode(does not appear to have been hot, nor blowing fuses) and got a reading of 16.6 BOTH ways. Can you suggest a cure? THANKS
  #10 (permalink)
Old 04-23-2008, 03:48 PM
Senior Expert
APP Volunteer
Default
Whats the make and model of your meter, and what
type of batteries does it take?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Microwave does not heat Kerryi Microwave Repair 3 04-21-2008 04:41 PM
microwave won't heat Lance Microwave Repair 0 03-20-2008 12:12 PM
GE Microwave No Heat sammyjk1 Microwave Repair 0 02-05-2008 04:02 AM
Microwave doesn't heat jstamb@comcast.net Microwave Repair 1 01-30-2008 09:25 AM
microwave does not heat all else is ok geo Microwave Repair 20 12-19-2007 06:31 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
