Discuss
GE Microwave won't heat
 in
Microwave Repair
Sounds like the type of microwave that I have. Sounds like the problems I'm having too. No heat, loud
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » GE Microwave won't heat
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #11 (permalink)
Old 05-01-2008, 09:07 AM
yorkc yorkc is offline
Junior Member
yorkc is on a distinguished road
Default GE space saver over-range
Sounds like the type of microwave that I have. Sounds like the problems I'm having too. No heat, loud buzzing, everything else normal. Any insight as to where I should look for the model number on this thing? I've been all over it, and under panels with no luck. They're usually quite easy to find. Hope it's not on a data plate that may have come loose and subsequently lost. Thanks...
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #12 (permalink)
Old 05-12-2008, 04:16 PM
traum traum is offline
Junior Member
traum is on a distinguished road
Default Same Microwave, Same Problem
Seems I have the same microwave. Over the range spacemaker XL 1800.
Everything seems to work fine. Just will NOT heat. I used it last night and have seen no symptoms of problems. It just quit heating.
I had the humming noise too and GE replace something last year.
It cost $80 to have GE come out and look. I just called. Plus parts and labor.
How much could it wind up costing???
  #13 (permalink)
Old 05-12-2008, 04:18 PM
Junior Member
Default
model # could be JVM1870SK03
mine is from nov 06
  #14 (permalink)
Old 05-12-2008, 04:28 PM
Junior Member
Default Wanted: Turntable Plate
If anyone wants to sell off the turntable plate from one of these non workig microwaves I'll take it. I will probably wind up getting my no heater fixed, but I broke the plate. What a day...
spacesaver 1800XL
This website wants $50.00 for one!!!!!!!!!!!!!!!!!!!!!!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Microwave does not heat Kerryi Microwave Repair 3 04-21-2008 04:41 PM
microwave won't heat Lance Microwave Repair 0 03-20-2008 12:12 PM
GE Microwave No Heat sammyjk1 Microwave Repair 0 02-05-2008 04:02 AM
Microwave doesn't heat jstamb@comcast.net Microwave Repair 1 01-30-2008 09:25 AM
microwave does not heat all else is ok geo Microwave Repair 20 12-19-2007 06:31 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
