| » Kenmore Microwave Fault Code F6 |
Model Number: 665-68602891 Brand: Kenmore Age: 5 - 10 years
I need a translation of fault code F6 on a Kenmore microwave. Unit is totally inoperable, low buzz when door is closed.
Related Models |
Try this test....
F6 Microwave relay failure 1. Unplug microwave oven or disconnect power. 2. Check wiring to Relay 4903 for short circuits. 3. If wiring is OK, replace electronic control. 4. Plug in microwave oven or reconnect power |
This unit is running on its own because of shorting contacts on the cook relay, ref # 4903 in this case.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire. So until it is repaired, please leave it unplugged or leave the door open. And do resist the temptation to slap it and consider it fixed. I'm sure you don't want your house to burn down in the middle of the night over that little joke. There's a much cheaper solution that buying the electronics control circuit board ("Microcptr") for $100.54 here. We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service with a full one year warranty.
__________________
William E. Miller † prototech@usa.net |
| Display Modes | |
| F3 error code | mich26 | Microwave Repair | 3 | 01-23-2008 07:28 PM |
| F2 - Error Code | Wilson | Oven Repair (including Ranges and Cooktops) | 3 | 08-23-2007 10:49 AM |
| F1 code persists after replacing the ERC | borick | Oven Repair (including Ranges and Cooktops) | 3 | 08-17-2007 09:55 PM |
| Ground Fault | DCHAR | Dishwasher Repair | 2 | 08-07-2007 07:45 AM |
| frigidaire range F31 code | Ruben Lucero | Oven Repair (including Ranges and Cooktops) | 0 | 08-05-2007 01:27 PM |
