Unfortunetly I relamped the under hood lights with 15w instead of 10w called for in the manual. It worked fine but when I walked by the micro later everything was dead, no lights or anything. Outlet tests good but not showing any continuity on the power cord. The schematic shows 2 fuses, a 20 amp ceramic fuse behind the control panel and another inline fuse, looks like .5 amp near the transformer. The 20amp shows good continuity, the .5 amp I'll have to remove the micro from the wall to get to.. My question is: Will a .5 amp fuse kill the whole microwave or did I do damage to something else? Thanks for reading! Dave
