Discuss
Microwave light blew and unit stopped working
 in
Microwave Repair
My microwave made by Goldstar, made a "po" noise and the bottom light (over the range) blew and
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Microwave light blew and unit stopped working
  #1 (permalink)
Old 04-05-2008, 03:01 PM
Sambo Sambo is offline
Junior Member
Sambo is on a distinguished road
Unhappy Microwave light blew and unit stopped working
Model Number: MV1526W   Brand: -other-   Age: 1 - 5 years
My microwave made by Goldstar, made a "po" noise and the bottom light (over the range) blew and the whole unit quit working. Can you help me solve this problem?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-09-2008, 02:16 PM
glen65 glen65 is offline
Senior Expert
APP Volunteer
glen65 is on a distinguished road
Default
From your description, I would say that trouble you have with the
light knocked out the main fuse, and cut power to the entire oven.
I may be just a case of getting the light fixed and replacing the main fuse.
  #3 (permalink)
Old 04-11-2008, 01:01 PM
Junior Member
Default I have checked the house breaker - not blown
I used an ammeter to check the fuse inside the yellow plastic snap box. this fuse is still intact. Does the lightbulb have to work for the whole microvave to get power?
  #4 (permalink)
Old 04-11-2008, 02:06 PM
Senior Expert
APP Volunteer
Default
No, the light wouldn’t keep it from working.
Based on the description you gave earlier it appeared that
the light developed a short which would have taken out
the main fuse and shut the entire oven down.
Did the main fuse look like this?
You said that you used an ammeter to check the fuse.
You actually would need an ohm meter to check
continuity of the fuse.
  #5 (permalink)
Old 04-11-2008, 06:54 PM
Junior Member
Default Yes, that is the fuse
I did try to test the continuity of the fuse. the ammeter I had on setting 1x. and It did register a charge. Or maybe I don't know how to properly test this fuse. If I replace this fuse. Will I have to track down the short? so this does not happen again? thanks for your help I just purchased this house and I would rather not spend money on a new microwave if this can be fixed with a simple fuse.
  #6 (permalink)
Old 04-11-2008, 07:12 PM
Senior Expert
APP Volunteer
Default
The reason I brought up your meter is
because ammeters are used to measure
electrical current not resistance. Although
some of them do have ohm meters built into them.
If you give me the make and model of your
meter I might be able to see whether or not
what your using is right for the job.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven / Microwave Combination Wall Unit LaVinnia Microwave Repair 4 03-10-2008 11:26 AM
radiant cooktop unit-on indicator light stays on muggy442 Oven Repair (including Ranges and Cooktops) 0 02-15-2008 04:01 PM
GE stopped working fixitgood Refrigerator & Freezer Repair 5 12-13-2007 07:34 PM
Microwave Light not working jlwbassman Microwave Repair 0 11-24-2007 07:50 PM
Light Switch Shorted- blew breaker gregjen Refrigerator & Freezer Repair 1 09-28-2007 03:39 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
