Discuss
blowing 15 amp fuse
 in
Microwave Repair
microwave makes load humming noise and has a smell of something electrical shorting out. i took it apart and tuned
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » blowing 15 amp fuse
  #1 (permalink)
Old 04-01-2008, 07:00 PM
Junior Member
foxie is on a distinguished road
Default blowing 15 amp fuse
Model Number: MH7115XBZ-4   Brand: Whirlpool   Age: More than 10 years
microwave makes load humming noise and has a smell of something electrical shorting out. i took it apart and tuned it on with the cover off and found that the transformmer was arcing and making sparks. i ordered a new transformer from you # WPL815095 and installed it and now when you turn it on it blows out the fuse on the power lead. i tried disconnecting the wires from the transformer to the capacitor and to the magnetron and then start it and the fuse will not blow out. then i hooked up wires to the capacitor but not to the magnetron and the fuse will blow out. i found that if i disconnect the diode on the one capacitor wire from the ground screw that the fuse will not blow out even if i hook up everything but the diode the unit will run but found out it will not heat up anything. i tested the diode and can not get any contiuity through the diode either way. tested the capacitor and there are 3 ohms at first then it will slowly go to 9.66 ohms. checked the magnetron ohm reading across terminals and had .3 ohms and no reading from case to terminals on either capacitor or magnetron. i reinstalled old transformer and is arcs when its on but will not blow out the fuse .
Related Models
Whirlpool MH7115XBZ0 OVER THE RANGE MICROWAVE
Whirlpool MH7115XBZ1 OVER THE RANGE MICROWAVE
Whirlpool MH7115XBZ2 OVER THE RANGE MICROWAVE
Whirlpool MH7115XBZ4 OVER THE RANGE MICROWAVE
Whirlpool MH7115XBZ5 OVER THE RANGE MICROWAVE
Whirlpool MH7115XBZ6 OVER THE RANGE MICROWAVE
Whirlpool MH7116XBB6 OVER THE RANGE MICROWAVE
Whirlpool MH7130XEB0 MICROWAVE HOOD COMBINATION
Whirlpool MH7130XEB1 MICROWAVE HOOD COMBINATION
Whirlpool MH7130XEB2 MICROWAVE HOOD COMBINATION
Whirlpool MH7130XEQ0 MICROWAVE HOOD COMBINATION
Whirlpool MH7130XEQ1 MICROWAVE HOOD COMBINATION
Whirlpool MH7130XEQ2 MICROWAVE HOOD COMBINATION
Whirlpool MH7130XEQ3 MICROWAVE HOOD COMBO
Whirlpool MH7130XEZ0 MICROWAVE HOOD COMBINATION
Whirlpool MH7130XEZ1 MICROWAVE HOOD COMBINATION
Whirlpool MH7130XEZ2 MICROWAVE HOOD COMBINATION
Whirlpool MH7135XEB0 MICROWAVE HOOD COMBINATION
Whirlpool MH7135XEB1 MICROWAVE HOOD COMBINATION
Whirlpool MH7135XEB2 MICROWAVE HOOD COMBINATION
Whirlpool MH7135XEQ0 MICROWAVE HOOD COMBINATION
Whirlpool MH7135XEQ1 MICROWAVE HOOD COMBINATION
Whirlpool MH7135XEQ2 MICROWAVE HOOD COMBINATION
Whirlpool MH7140XFB0 MICROWAVE
Whirlpool MH7140XFB1 MICROWAVE
Whirlpool MH7140XFQ0 MICROWAVE
Whirlpool MH7140XFQ1 MICROWAVE
Whirlpool MH7140XFZ0 MICROWAVE
Whirlpool MH7140XFZ1 MICROWAVE
Whirlpool MH7155XBZ0 MICROWAVE OVEN
Whirlpool MH7155XMB0 MICROWAVE HOOD COMBINATION
Whirlpool MH7155XMQ0 MICROWAVE HOOD COMBINATION
Whirlpool MH7155XMS0 MICROWAVE OVEN
Whirlpool MH7155XMT0 MICROWAVE HOOD COMBINATION
Whirlpool MH8150XJB0 MICROWAVE
Whirlpool MH8150XJB1 MICROWAVE HOOD COMBINATION
Whirlpool MH8150XJQ0 MICROWAVE
Whirlpool MH8150XJQ1 MICROWAVE HOOD COMBINATION
Whirlpool MH8150XJT0 MICROWAVE
Whirlpool MH8150XJT1 MICROWAVE HOOD COMBINATION
Whirlpool MH8150XJZ0 MICROWAVE
Whirlpool MH8150XJZ1 MICROWAVE HOOD COMBINATION
Whirlpool MH8150XMB0 MICROWAVE HOOD COMBINATION
Whirlpool MH8150XMB2 MICROWAVE HOOD COMBINATION
Whirlpool MH8150XMQ0 MICROWAVE HOOD COMBINATION
Whirlpool MH8150XMQ2 MICROWAVE HOOD COMBINATION
Whirlpool MH8150XMT0 MICROWAVE HOOD COMBINATION
Whirlpool MH8150XMT2 MICROWAVE HOOD COMBINATION
Whirlpool MH8150XMZ0 MICROWAVE HOOD COMBINATION
Whirlpool MH8150XMZ2 MICROWAVE HOOD COMBINATION
Whirlpool MH9115XBB0 OVER THE RANGE MICROWAVE
Whirlpool MH9115XBB1 OVER THE RANGE MICROWAVE
Whirlpool MH9115XBB2 OVER THE RANGE MICROWAVE
Whirlpool MH9115XBB4 OVER THE RANGE MICROWAVE
Whirlpool MH9115XBB5 OVER THE RANGE MICROWAVE
Whirlpool MH9115XBQ0 OVER THE RANGE MICROWAVE
Whirlpool MH9115XBQ1 OVER THE RANGE MICROWAVE
Whirlpool MH9115XBQ2 OVER THE RANGE MICROWAVE
Whirlpool MH9115XBQ4 OVER THE RANGE MICROWAVE
Whirlpool MH9115XBQ5 OVER THE RANGE MICROWAVE
Whirlpool MH9115XEB0 MICROWAVE
Whirlpool MH9115XEQ0 MICROWAVE
Whirlpool MH9180XLB0 MICROWAVE HOOD COMBO
Whirlpool MH9180XLB1 Microwave Oven 1.8 Cu. Ft.
Whirlpool MH9180XLQ0 MICROWAVE HOOD COMBO
Whirlpool MH9180XLQ1 Microwave Oven 1.8 Cu. Ft.
Whirlpool MH9180XLT0 MICROWAVE HOOD COMBO
Whirlpool MH9180XLT1 Microwave Oven 1.8 Cu. Ft.
Whirlpool MH9181XMB0 Microwave Oven 1.8 Cu. Ft.
Whirlpool MH9181XMB1 Microwave Oven 1.8 Cu. Ft.
Whirlpool MH9181XMQ0 Microwave Oven 1.8 Cu. Ft.
Whirlpool MH9181XMQ1 Microwave Oven 1.8 Cu. Ft.
Whirlpool MH9181XMS0 Microwave Oven 1.8 Cu. Ft.
Whirlpool MH9181XMS1 Microwave Oven 1.8 Cu. Ft.
Whirlpool MH9181XMT0 Microwave Oven 1.8 Cu. Ft.
Whirlpool MH9181XMT1 Microwave Oven 1.8 Cu. Ft.
Magic Chef MHA100-30D HOOD
Magic Chef MHA100-36 HOOD
Magic Chef MHA100-42 HOOD
Magic Chef MHB100-24 HOOD
Magic Chef MHB100-30 HOOD
Magic Chef MHB100-36 HOOD
Magic Chef MHB100-42 HOOD
Magic Chef MHB100D-24 HOOD
Magic Chef MHB100D-30 HOOD
Magic Chef MHB100D-36 HOOD
Magic Chef MHB100D-42 HOOD
Roper MHE10RW0 Microwaves*
Roper MHE10RX0 Microwaves*
Roper MHE10RXB0 MICROWAVE HOOD COMBINATION
Roper MHE10RXQ0 MICROWAVE HOOD COMBINATION
Roper MHE10VW0 Microwaves*
Roper MHE11RDB0 MICROWAVE HOOD COMBINATION
Roper MHE11RDB4 MICROWAVE HOOD COMBINATION
Roper MHE11RDB5 MICROWAVE HOOD COMBINATION
Whirlpool MHE11RDB6 MICROWAVE
Roper MHE11RDQ0 MICROWAVE HOOD COMBINATION
Roper MHE11RDQ4 MICROWAVE HOOD COMBINATION
Roper MHE11RDQ5 MICROWAVE HOOD COMBINATION
Whirlpool MHE11RDQ6 MICROWAVE
Roper MHE11REB0 MICROWAVE
Roper MHE11REB1 MICROWAVE OVEN
Roper MHE11REQ0 MICROWAVE
Roper MHE11REQ1 MICROWAVE OVEN
Roper MHE13XHB0 MICROWAVE HOOD COMBINATION
Roper MHE13XHB1 MICROWAVE HOOD COMBINATION
Roper MHE13XHQ0 MICROWAVE HOOD COMBINATION
Roper MHE13XHQ1 MICROWAVE HOOD COMBINATION
Roper MHE13XKB0 MICROWAVE HOOD COMBO
Roper MHE13XKQ0 MICROWAVE
Roper MHE14RFB0 MICROWAVE HOOD COMBO
Roper MHE14RFQ0 MICROWAVE HOOD COMBO
Roper MHE14XKB0 MICROWAVE HOOD COMBO
Roper MHE14XKB1 MICROWAVE HOOD COMBINATION
Roper MHE14XKB2 MICROWAVE HOOD COMBINATION
Roper MHE14XKQ0 MICROWAVE HOOD COMBO
Roper MHE14XKQ1 MICROWAVE HOOD COMBINATION
Roper MHE14XKQ2 MICROWAVE HOOD COMBINATION
Roper MHE14XMB0 MICROWAVE HOOD COMBINATION
Roper MHE14XMB1 MICROWAVE HOOD COMBINATION
  #2 (permalink)
Old 04-01-2008, 08:07 PM
Senior Expert
APP Volunteer
glen65 is on a distinguished road
Default
First off you need to put the new transformer
back in.
Then disconnect both leads from the magnetron
and test the high voltage diode and capacitor.
You will need to make sure that
your meter has at least a 6volt battery (preferably 9v)
so that you donít get a (false open) reading on the diode.
You should get a reading with the meter probes
connected in one direction and nothing (or infinity) when you
reverse them.
Now check the capacitor again.
Have at least one terminal of the high voltage
capacitor completely disconnected when checking it.
You should briefly get a reading then it should go
to infinity.
If the readings you gave earlier are correct then the
cap is shorted. (or possibly the internal bleed resistor is
shorted).
Double check the magnetron,
Completely disconnected and check
for continuity between each terminal and the case.
You should get nothing, even on the highest setting.
Good luck
  #3 (permalink)
Old 04-02-2008, 07:06 PM
Junior Member
Default
i rechecked the diode and do not get a ohms reading either way. checked the capacitor and sometimes i will get a ohms reading when i test the two terminals but now i get nothing.the megnatron has no continuity from either terminals to the case but there is between the two terminals. i think it may need a new capacitor and the diode but dont know if i want to put a $100 more parts into it not knowing if that is going to fix it for sure. and it shows you dont have the diode instock
  #4 (permalink)
Old 04-02-2008, 08:03 PM
Senior Expert
APP Volunteer
Default
What is the make and model number or (if radioshack the catalog number) of your meter and what kind of batteries does it take?
  #5 (permalink)
Old 04-07-2008, 04:23 PM
Junior Member
Default
the meter i was using is a FLUKE #73 with a 9 volt battery. i found a used diode and capacitor and tried them and it will still blow out the fuse. it will dim the lights on the pannel with the clock and it makes a loud humming noise. if i disconnect the wire off the transformer that has the spade terminal on the transformer that connects to the capacitor it will not hum loud and will not blow fuse.
  #6 (permalink)
Old 04-07-2008, 05:25 PM
Senior Expert
APP Volunteer
Default
From the way you describe it,
it looks like you have a bad magnetron.
If your pulling the high voltage wire that
goes to the transformer and the fuse stays in
tact, and you are certain that the high voltage
cap and diode are good, then the only thing in the
high voltage section on this unit thats left is the mag.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
mircowave blowing fuse danny_one Microwave Repair 0 01-27-2010 10:15 AM
Blowing 1 amp fuse john neer Washer Repair 0 09-06-2009 07:18 AM
keeps blowing fuse. ofblong Dryer Repair 12 04-23-2009 12:04 PM
My 192 thermal fuse keeps blowing harleyfatboy Dryer Repair 0 03-21-2009 04:47 PM
fuse blowing when lid opens ronv Washer Repair 1 03-19-2008 01:36 PM
