| » GE Microwave F3 error |
Model Number: JVM3660SD001 Brand: GE Age: 5 - 10 years
The display says F3 and the touchpad will not work.
Which part do I likely need? The pcb (power control board assembly) or the control panel? or both? Would like to try to fix it myself... Thanks! Ads By Google Related Models |
It's almost certainly the keypad, but there should be a "mini-manual" hidden behind the control panel. It contains a chart to help you test the keypad.
You'll want to use a hair dryer to heat up the old keypad so you can peel it off easier. And be sure to get all the glue / residue off. I use mineral spirits or paint thinner, then clena it squeaky with alcohol. It has to be squeaky clean so the new keypad will stick. You can't apply it then peel it back up to realign it. You can get the keypad here: Appliance Parts Pros.com Discount Appliance Parts – Appliance Repair Parts Feel free to contact me directly if you need more tips. William E. Miller |
| Display Modes | |
| F3 Error on GE Over the counter microwave | editor2b | Microwave Repair | 0 | 12-07-2009 06:56 PM |
| GE Microwave F3 Error Code | AprilVMills | Microwave Repair | 0 | 11-09-2009 06:13 AM |
| Microwave with F2 error | walkergirl11 | Microwave Repair | 2 | 07-27-2009 07:38 PM |
| F3 Error On GE Microwave Display | mpotter | Microwave Repair | 1 | 03-21-2009 03:32 PM |
| f3 error -Microwave dead | Rob W | Microwave Repair | 3 | 07-30-2008 05:01 PM |
