Discuss
Replacing outer door frame
 in
Microwave Repair
The outer door frame of my JVM1840WD001 was cracked and eventually broken on the bottom. I ordered the replacement part
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Replacing outer door frame
  #1 (permalink)
Old 03-27-2008, 02:13 PM
yiwen yiwen is offline
Junior Member
yiwen is on a distinguished road
Default Replacing outer door frame
Model Number: JVM1840WD001   Brand: GE   Age: 5 - 10 years
The outer door frame of my JVM1840WD001 was cracked and eventually broken on the bottom. I ordered the replacement part from appliancepartspros.com for JVM1840BD001 since I don't want to pay $200 for the whole door (GE does not make individual part for JVM1840WD001, so I settle with a different color: bisque instead of white). To replace the outer door frame, you would need to use putty knife (the one you use for dry walling) to remove the inside door frame by prying against the inside metal frame. Once you remove the inside door frame, you will see two screws that secure the door handle. Unscrew them to remove the door handle. Once the handle is out of the way, you will see (from outside) there are 2 more screws that secure the outer door frame to the door assembly. Unscrew them (be careful not to let the outer door frame drop because there is the glass attached to it) and use the putty knife to remove the outer door frame. From this point on, the removal and installation should be straightforward.
Related Models
General Electric JVM1840WD001 Counter top microwave
General Electric JVM1840WD002 Counter top microwave
General Electric JVM1841BD001 Counter top microwave
General Electric JVM1841BD002 Counter top microwave
General Electric JVM1841CD001 Counter top microwave
General Electric JVM1841CD002 Counter top microwave
General Electric JVM1841WD001 Counter top microwave
General Electric JVM1841WD002 Counter top microwave
General Electric JVM1842BD001 Counter top microwave
General Electric JVM1842BD002 Counter top microwave
General Electric JVM1842BF001 Counter top microwave
General Electric JVM1842BF02 Counter top microwave
General Electric JVM1842CD001 Counter top microwave
General Electric JVM1842CD002 Counter top microwave
General Electric JVM1842CF001 Counter top microwave
General Electric JVM1842CF02 Counter top microwave
General Electric JVM1842WD001 Counter top microwave
General Electric JVM1842WD002 Counter top microwave
General Electric JVM1842WF001 Counter top microwave
General Electric JVM1842WF02 Counter top microwave
General Electric JVM1850BD001 Counter top microwave
General Electric JVM1850BD002 Counter top microwave
General Electric JVM1850BF001 Counter top microwave
General Electric JVM1850BH01 Counter top microwave
General Electric JVM1850BH02 Counter top microwave
General Electric JVM1850BH03 Counter top microwave
General Electric JVM1850BH04 Counter top microwave
General Electric JVM1850BH05 Counter top microwave
General Electric JVM1850BH06 Counter top microwave
General Electric JVM1850CD001 Counter top microwave
General Electric JVM1850CD002 Counter top microwave
General Electric JVM1850CF001 Counter top microwave
General Electric JVM1850CH01 Counter top microwave
General Electric JVM1850CH02 Counter top microwave
General Electric JVM1850CH03 Counter top microwave
General Electric JVM1850CH04 Counter top microwave
General Electric JVM1850CH05 Counter top microwave
General Electric JVM1850CH06 Counter top microwave
General Electric JVM1850DMBB01 Counter top microwave
General Electric JVM1850DMCC01 Counter top microwave
General Electric JVM1850DMWW01 Counter top microwave
General Electric JVM1850SH01 Counter top microwave
General Electric JVM1850SH02 Counter top microwave
General Electric JVM1850SH03 Counter top microwave
General Electric JVM1850SH04 Counter top microwave
General Electric JVM1850SH05 Counter top microwave
General Electric JVM1850SH06 Counter top microwave
General Electric JVM1850SMSS01 Counter top microwave
General Electric JVM1850WD001 Counter top microwave
General Electric JVM1850WD002 Counter top microwave
General Electric JVM1850WF001 Counter top microwave
General Electric JVM1850WH01 Counter top microwave
General Electric JVM1850WH02 Counter top microwave
General Electric JVM1850WH03 Counter top microwave
General Electric JVM1850WH04 Counter top microwave
General Electric JVM1850WH05 Counter top microwave
General Electric JVM1850WH06 Counter top microwave
General Electric JVM1851BD001 Counter top microwave
General Electric JVM1851BD002 Counter top microwave
General Electric JVM1851BF001 Counter top microwave
General Electric JVM1851BH01 Counter top microwave
General Electric JVM1851BH02 Counter top microwave
General Electric JVM1851BH03 Counter top microwave
General Electric JVM1851BH04 Counter top microwave
General Electric JVM1851BH05 Counter top microwave
General Electric JVM1851BH06 Counter top microwave
General Electric JVM1851CD001 Counter top microwave
General Electric JVM1851CD002 Counter top microwave
General Electric JVM1851CF001 Counter top microwave
General Electric JVM1851CH01 Counter top microwave
General Electric JVM1851CH02 Counter top microwave
General Electric JVM1851CH03 Counter top microwave
General Electric JVM1851CH04 Counter top microwave
General Electric JVM1851CH05 Counter top microwave
General Electric JVM1851CH06 Counter top microwave
General Electric JVM1851SH01 Counter top microwave
General Electric JVM1851SH02 Counter top microwave
General Electric JVM1851SH03 Counter top microwave
General Electric JVM1851SH04 Counter top microwave
General Electric JVM1851SH05 Counter top microwave
General Electric JVM1851SH06 Counter top microwave
General Electric JVM1851WD001 Counter top microwave
General Electric JVM1851WD002 Counter top microwave
General Electric JVM1851WF001 Counter top microwave
General Electric JVM1851WH01 Counter top microwave
General Electric JVM1851WH02 Counter top microwave
General Electric JVM1851WH03 Counter top microwave
General Electric JVM1851WH04 Counter top microwave
General Electric JVM1851WH05 Counter top microwave
General Electric JVM1851WH06 Counter top microwave
General Electric JVM1860BD001 Counter top microwave
General Electric JVM1860BD002 Counter top microwave
General Electric JVM1860BF001 Counter top microwave
General Electric JVM1860BF02 Counter top microwave
General Electric JVM1860CD001 Counter top microwave
General Electric JVM1860CD002 Counter top microwave
General Electric JVM1860CF001 Counter top microwave
General Electric JVM1860CF02 Counter top microwave
General Electric JVM1860SD001 Counter top microwave
General Electric JVM1860SD002 Counter top microwave
General Electric JVM1860SF001 Counter top microwave
General Electric JVM1860SF02 Counter top microwave
General Electric JVM1860WD001 Counter top microwave
General Electric JVM1860WD002 Counter top microwave
General Electric JVM1860WF001 Counter top microwave
General Electric JVM1860WF02 Counter top microwave
General Electric JVM1861BD001 Counter top microwave
General Electric JVM1861BD002 Counter top microwave
General Electric JVM1861BF001 Counter top microwave
General Electric JVM1861BF02 Counter top microwave
General Electric JVM1861CD001 Counter top microwave
General Electric JVM1861CD002 Counter top microwave
General Electric JVM1861CF001 Counter top microwave
General Electric JVM1861CF02 Counter top microwave
General Electric JVM1861SD001 Counter top microwave
General Electric JVM1861SD002 Counter top microwave
General Electric JVM1861SF001 Counter top microwave
General Electric JVM1861SF02 Counter top microwave
General Electric JVM1861WD001 Counter top microwave
General Electric JVM1861WD002 Counter top microwave
  #2 (permalink)
Old 03-27-2008, 02:24 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Thank you. Very helpful information.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchenaid Refrigerator Hot Door Frame billiardlo Refrigerator & Freezer Repair 9 08-29-2008 09:45 AM
outer glass door shattered phill44 Oven Repair (including Ranges and Cooktops) 3 01-16-2008 09:18 PM
Outer oven door Jimmmy Oven Repair (including Ranges and Cooktops) 3 12-21-2007 05:49 PM
replacing oven light switch on frame kitchenaidguy Oven Repair (including Ranges and Cooktops) 0 12-15-2007 02:46 PM
Replacing Exterior Door Frame lpalmer Microwave Repair 0 11-21-2007 05:37 PM
