| » Replacing outer door frame |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: JVM1840WD001 Brand: GE Age: 5 - 10 years
The outer door frame of my JVM1840WD001 was cracked and eventually broken on the bottom. I ordered the replacement part from appliancepartspros.com for JVM1840BD001 since I don't want to pay $200 for the whole door (GE does not make individual part for JVM1840WD001, so I settle with a different color: bisque instead of white). To replace the outer door frame, you would need to use putty knife (the one you use for dry walling) to remove the inside door frame by prying against the inside metal frame. Once you remove the inside door frame, you will see two screws that secure the door handle. Unscrew them to remove the door handle. Once the handle is out of the way, you will see (from outside) there are 2 more screws that secure the outer door frame to the door assembly. Unscrew them (be careful not to let the outer door frame drop because there is the glass attached to it) and use the putty knife to remove the outer door frame. From this point on, the removal and installation should be straightforward.
Thank you. Very helpful information.
__________________
Professional appliance repair services in Orange County, California. |
| Display Modes | |
| Kitchenaid Refrigerator Hot Door Frame | billiardlo | Refrigerator & Freezer Repair | 8 | 06-18-2008 02:27 AM |
| outer glass door shattered | phill44 | Oven Repair (including Ranges and Cooktops) | 3 | 01-16-2008 08:18 PM |
| Outer oven door | Jimmmy | Oven Repair (including Ranges and Cooktops) | 3 | 12-21-2007 04:49 PM |
| replacing oven light switch on frame | kitchenaidguy | Oven Repair (including Ranges and Cooktops) | 0 | 12-15-2007 01:46 PM |
| Replacing Exterior Door Frame | lpalmer | Microwave Repair | 0 | 11-21-2007 04:37 PM |
