Discuss
Replacing outer door frame
 in
Microwave Repair
Never thought of fixing the outer door frame in this way. This is really helpful thanks for sharing it. view
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Replacing outer door frame
  #11 (permalink)
Old 01-11-2014, 12:58 AM
Junior Member
markedward is on a distinguished road
Default Outer Door Frame
view all builders
  #12 (permalink)
Old 01-17-2014, 09:59 PM
Junior Member
MikeWolfes is on a distinguished road
Default
good suggestion it is .. i was too looking for it
  #13 (permalink)
Old 03-19-2014, 01:52 AM
Junior Member
avswindows is on a distinguished road
Default
Thanks For it information
  #14 (permalink)
Old 09-04-2015, 02:03 PM
Junior Member
djpenn is on a distinguished road
Unhappy Replacing outer frame.
Quote:
Originally Posted by yiwen View Post
The outer door frame of my JVM1840WD001 was cracked and eventually broken on the bottom. I ordered the replacement part from appliancepartspros.com for JVM1840BD001 since I don't want to pay $200 for the whole door (GE does not make individual part for JVM1840WD001, so I settle with a different color: bisque instead of white). To replace the outer door frame, you would need to use putty knife (the one you use for dry walling) to remove the inside door frame by prying against the inside metal frame. Once you remove the inside door frame, you will see two screws that secure the door handle. Unscrew them to remove the door handle. Once the handle is out of the way, you will see (from outside) there are 2 more screws that secure the outer door frame to the door assembly. Unscrew them (be careful not to let the outer door frame drop because there is the glass attached to it) and use the putty knife to remove the outer door frame. From this point on, the removal and installation should be straightforward.
Do you have to remove the door first? If so, then how do you do that?I don't want to break the new frame before I get the old one out so don't want to pry and poke until I know for sure.
  #15 (permalink)
Old 08-28-2016, 09:13 PM
Junior Member
mayallen is on a distinguished road
Default
Thanks for sharing the information, I had a similar problem with the microwave oven I bought from best brand appliance Premium Home & Kitchen Appliances Store Vaughan, Toronto | Best Brand Appliance but I had some professionals come in and fix the door for me. I was a bit cautious of working it on my own because microwave ovens have very high voltages and can have very high currents while operating. The high voltage capacitor can retain the charge for a long time.
  #16 (permalink)
Old 06-06-2017, 10:32 PM
Junior Member
McGear10 is on a distinguished road
Default
Nice info.
  #17 (permalink)
Old 08-30-2017, 10:40 PM
Junior Member
IJenkins is on a distinguished road
Default
Can you post some pictures of your door frame?
  #18 (permalink)
Old 12-23-2017, 10:37 PM
Junior Member
richbanks1 is on a distinguished road
Default
Nice thread... Thanks for sharing..
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing Door Frame on a Microwave bogey62 Microwave Repair 0 11-22-2009 03:50 PM
Outer door frame replacement edcronin Microwave Repair 1 11-12-2008 12:58 PM
replacing outer door glass Christopher Nelson Oven Repair (including Ranges and Cooktops) 0 04-14-2008 02:16 PM
Outer Door Frame Replacement Dixxieray Microwave Repair 1 04-11-2008 08:59 PM
Replacing Exterior Door Frame lpalmer Microwave Repair 0 11-21-2007 04:37 PM
