Discuss
Microwave fuses & door switches
 in
Microwave Repair
This is a generic Korean-made oven and seems to be nicely made. It blows fuses when opening the door --
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Microwave fuses & door switches
  #1 (permalink)
Old 01-05-2010, 05:05 PM
Junior Member
davjones is on a distinguished road
Default Microwave fuses & door switches
Brand: -other-   Age: 5 - 10 years
This is a generic Korean-made oven and seems to be nicely made. It blows fuses when opening the door -- and only at that time. Started out intermittent but now seems to be a "hard" condition, at least till I took it all apart.
From other posts I see, I should suspect a door interlock or monitor switch problem. So I took the switches out, tested them (perfect) and then opened each one to see what's inside. Found the two interlock switches to have perfect contacts. The one that I believe is the monitor switch has some signs of arcing but not bad at all. Nothing burnt or anything.
Examined the switch actuating cams (for lack of the proper word) and they are in good shape and are free. Fingers on door seem fine and downspring tension seems good, but if there was some distortion I don't know how you could tell, but there's no visible alignment problem.
Am I trying to climb the wrong tree?
Thanks very much for any help!
...Dave
Dave Jones
Fort McCoy, Florida USA
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
microwave stop working fuses? steve morin Microwave Repair 0 11-03-2009 06:37 PM
GE Profile spacemaker microwave fuses rbinthesouth Microwave Repair 1 10-08-2009 01:09 PM
Accessing Microwave Door Switches candrewb Microwave Repair 0 08-21-2009 06:17 PM
microwave blows fuses kenjadog Microwave Repair 0 08-07-2009 07:38 AM
Whirlpool microwave blows fuses jclawman Microwave Repair 5 01-27-2008 05:46 PM
