Discuss
Microwave hums & heats when turned off & door closed
 in
Microwave Repair
The GE microwave continues to heat (cup of water gets hot) with a continuous hum after it has been turned
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Microwave hums & heats when turned off & door closed
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 03-22-2008, 08:38 PM
platypook platypook is offline
Junior Member
platypook is on a distinguished road
Default Microwave hums & heats when turned off & door closed
Model Number: JKP76G   Brand: GE   Age: More than 10 years
The GE microwave continues to heat (cup of water gets hot) with a continuous hum after it has been turned off and door closed. The control panel does not respond. When the door opens, everything stops (no humming, no heat) and light comes on. This happened before and after a few days, the microwave worked normally. We could not find the schematics inside the control panel. What could be the problem and are there schematics available on line?
Platypook
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-23-2008, 02:17 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Remove the control panel and look for an envelope with the wiring information.
In order to provide most accurate advise we need the rest of the model number.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 03-23-2008, 06:25 PM
Junior Member
Default
Thanks Gene, there is no envelope with wiring information behind the control panel (we checked), but the model number inside the Microwave is: JKP76GOV1BB. It's a built in combination electric oven with microwave on top. The oven portion works. Any insights will be appreciated.
  #4 (permalink)
Old 03-24-2008, 02:40 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely the problem is a bad control board.
Also I would recommend to check the door switches.
- The part number for the control board is AP2025119
__________________
  #5 (permalink)
Old 03-24-2008, 06:11 PM
Junior Member
Default
How do you check the door switches ? Also, if the control board is not the right one, is there a return policy? Thanks. Went ahead and ordered the part anyways.
  #6 (permalink)
Old 03-24-2008, 06:56 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Open the control panel, remove wires from the switch before testing.
The interlock switch should be open with the door open and closed when the door is closed.
The monitor switch should be closed with the door open and open with the door closed.
__________________
  #7 (permalink)
Old 03-28-2008, 09:35 PM
Junior Member
Default
We replaced the control board as you suggested and the microwave is working properly again. There was an initial hum but it went away after we opened and closed the door. Thank you for you assistance - this was most helpful, and saved us from having to pay extra for a technician to come!
  #8 (permalink)
Old 03-29-2008, 10:23 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad you were able to fix it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas dryer starts when door is closed DonnySchepp Dryer Repair 8 06-22-2008 12:31 PM
Oven buzzing when turned on julsbythesea Oven Repair (including Ranges and Cooktops) 1 02-06-2008 03:42 PM
Leaking after washer is turned on JohnMathapha Dishwasher Repair 3 01-16-2008 10:09 AM
Duet Washer Door Locked Closed. Lucresha Washer Repair 1 01-07-2008 04:18 AM
Cycles On When Door Is Closed GEARHEAD Dishwasher Repair 1 10-23-2007 02:50 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
