| » "Door" message on display, unit won't start |
Model Number: GMC305PDB07 Brand: Whirlpool Age: 1 - 5 years
When troubleshooting a light problem on this microwave I pushed the two door latches in to see if the light would work. I then managed to pull the latches back out to what I think is their original position. But now, when I try to use the microwave, the door seems to close okay, but when I press start the "door" message appears and the microwave won't start.
Is there a reset or something I need to do? Help. Richard J Ads By Google Related Models |
Richard,
Looks like your "experiments" caused the 20 amps fuse behind the control panel to blow out. Check it for continuity and replace if it's open. If this fuse is fine, check the 15 amps line fuse on the right side on the back of the microwave. In such situation the microwave has to be removed from the oven cabinet. - The 20 amps fuse Part number: AP4307253 - The 15 amps fuse Part number: AP2929269 Here is the Tech sheet. Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GMC305PDB07 30" Built - in Electric Combo Sensor/sc (gold Line) | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Thanks Gene, and for being so quick on a Friday late afternoon. I'll give your solution a shot.
Next question then is how to get at the 20amp fuse behind the control panel? Can I just pull the whole combo unit partially out to get at it? Any instructions on pulling it out? Richard J |
__________________
Same problem with my Whirlpool combo. My model # is GMC305PRS01. I also made a same mistake of pushing latches in and pulling back out. May be 20 amp fuse is blown as mentioned in your note. Did you get instruction on how to get to fuse. Instruction on the link is from Kitchen aid combo not Whirlpool. Thanks
Kitchen Aid is a part of Whirlpool. You can use the same service manual.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GMC305PRS01 30`` BUILT-IN ELECTRIC COMBO SENSOR/SC (GOLD LINE) | AppliancePartsPros.com Gene.
__________________
| Display Modes | |
| Mocrowave gives "door" error message | swanson | Microwave Repair | 1 | 07-15-2011 10:27 AM |
| micro displays "DOOR", wont start | kicknbutt | Microwave Repair | 1 | 12-11-2009 05:32 PM |
| self cleaning "door" display on control panel | japdx | Oven Repair (including Ranges and Cooktops) | 0 | 10-19-2009 09:22 AM |
| Fashing "door open" and will not start | Sammy | Washer Repair | 1 | 12-14-2007 11:50 AM |
| Oven oesn't bake/heat and displays a "FS" error message | jnymdnyt | Oven Repair (including Ranges and Cooktops) | 5 | 08-06-2007 06:36 PM |
