| » Door Replacement Help!!! |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: JVM1331WW002 Brand: GE Age: 5 - 10 years
The door and handle on my GE Spacemaker XL OTR (Model JVM1331WW02) are cracked and broken. I rencently purchased the complete door assembly (Part # 1800 http://www.appliancepartspros.com/pa...e l_id=216802) but am unsure on how to do the repair.
Could someone help me with some advice/tips/tecniques on how to remove the old door and put on the new one? Thanks in advance! -jD |
We have the same model, and the same thing happened. I searched for the replacement part, and I decided that it cost too much, and the instructions involved too much to replace the door handle. We have been using a ribbon to open the latch for over a year now. I found the instructions online, and they involved taking the door apart. Since you had the same problem, I now believe that the door was defective. It just broke with simple use by two grown adults.
1st, you need to remove the vent grille above the door, 2 screws in front as your looking at it, next remove the bottom access panel, under the micro, take all screws out. now the bottom door hinge is attached with two 5/16 screws, remove those. At the top door hinge there may or may not be a phillips screw at the frame where the door hinge is, remove it if it's there, now look inside the micro where the door hinge goes into the cavity, and there are two 5/16 screws holding the hinge in place, remove those and remove the door. I find it easier to use a socket and ratchet to get the top hinge screws out....hope this helps
__________________
I won $12,000 last year playing FantasyFootball on WWW.Dimesports.net, this was my first year playing fantasy football. Sign up and use Promocode 152, and my e-mail abadfish66@cox.net for special pricing. My team name is Hawks, and My testimonial is on the main page
| Display Modes | |
| Oven door trim replacement | FranklinD | Oven Repair (including Ranges and Cooktops) | 1 | 01-22-2008 12:40 PM |
| Replacement door handle installation | manushand | Microwave Repair | 0 | 01-05-2008 11:24 AM |
| Door gasket replacement in GE dishwash | Bdeming | Dishwasher Repair | 0 | 12-30-2007 07:25 PM |
| Microwave Door Replacement | smc6429 | Microwave Repair | 0 | 11-04-2007 06:03 PM |
| Oven Outer Door Replacement | cnowen | Oven Repair (including Ranges and Cooktops) | 1 | 09-08-2007 01:15 AM |
