Discuss
Microwave Turntable will not turn
 in
Microwave Repair
The turntable starts to turn about 1/2 a revolution and stops. I am thinking that it is the turntable
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Microwave Turntable will not turn
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 03-10-2008, 07:14 PM
John G John G is offline
Junior Member
John G is on a distinguished road
Default Microwave Turntable will not turn
Model Number: J VM1860SD1   Brand: GE   Age: 1 - 5 years
The turntable starts to turn about 1/2 a revolution and stops. I am thinking that it is the turntable motor that needs replaced on this unit that is mounted in our kitchen. The glass tray turns freely with no resistance. Could it be some other problem?
If I purchase a replacement motor, is it hard to install? Can it be replaced from under the unit without removing it from the wall bracket?
Do you have any replacement instructions to follow?
I know this is a lot of questions, but any help would be appreciated.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-11-2008, 02:41 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi John,
The first thing I would check is the coupler (#37 on the break down diagram).
Remove the glass tray and pull the coupler up. Check it for any cracks.
If the coupler is fine then the turntable motor has to be replaced.
It can be easy replaced after the bottom panel removed - just two screws and the wire plug.
- The part number for the coupler is AP2016754
- The part number for the turntable motor is AP2024962
Here are the break down diagrams for the GE microwave Model JVM1860SD001
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 03-12-2008, 07:22 AM
Junior Member
Gene:
Thanks for the quick response.
John G
  #4 (permalink)
Old 06-10-2008, 09:33 AM
rahulbpatel rahulbpatel is offline
Junior Member
rahulbpatel is on a distinguished road
Default JMC7000ADB Turn table not work
We're having the same problem with our Jenn-Air JMC7000ADB microwave -- the turn table does not turn. The spindle turns when the glass tray is off but will not turn when it's on there. I'm pretty sure the motor needs to be replaced. Is this something that can be performed by a weekend DIYer or does it need to be done by a professional? Here is the part:
MAYTAG Motor, turntable, part number: 56001231
Thanks...
  #5 (permalink)
Old 06-10-2008, 03:45 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
This part is not too difficult to replace yourself if you know how to handle a simple hand tools.
Here are the break down diagrams for the Jenn Air microwave Model JMC7000ADB
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Buying the right microwave turntable motor rcollison Microwave Repair 2 02-01-2008 04:42 AM
Microwave turntable mbuckeye Microwave Repair 2 02-01-2008 04:39 AM
Glass Turntable in Microwave Bob Piersall Microwave Repair 0 01-12-2008 08:25 AM
Microwave Turntable doesn't work Muldoon Microwave Repair 1 12-12-2007 07:10 PM
Microwave turntable turns erratically mrnester@charter.net Microwave Repair 0 10-23-2007 04:17 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
