Discuss
Microwave Turntable will not turn
 in
Microwave Repair
Originally Posted by Gene Denny, What is the complete model number of the microwave? Gene. Hi Gene, Model# GLMV168KS4 mfg:
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Microwave Turntable will not turn
  #31 (permalink)
Old 10-14-2009, 02:25 AM
Junior Member
DLB3 is on a distinguished road
Default
Quote:
Originally Posted by Gene View Post
Denny,
Hi Gene,
Model# GLMV168KS4
mfg: July 2002
TKS
Denny
  #32 (permalink)
Old 06-22-2013, 06:43 PM
Junior Member
melmeinhardt is on a distinguished road
Default
Hi John,
The first thing I would check is the coupler (#37 on the break down diagram).
Remove the glass tray and pull the coupler up. Check it for any cracks.
If the coupler is fine then the turntable motor has to be replaced.
It can be easy replaced after the bottom panel removed - just two screws and the wire plug.
- The part number for the coupler is AP2016754
- The part number for the turntable motor is AP2024962
Here are the break down diagrams for the GE microwave Model JVM1860SD001
Gene,
First, thank you for your concise advice posts on this site. They're perfect.
Secondly, I'm trying to follow your advice to repair/replace a GE microwave turntable motor. Can you please advise on how the coupler is removed? On the model I have, JVM1640WB, it does not lift out, as I know it does on some other designs.
The parts diagram provides insufficient detail (the photo of the coupler's underside is obscured).
Huge thanks.
  #33 (permalink)
Old 06-23-2013, 11:45 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by melmeinhardt View Post
Gene,
Huge thanks.
You are welcome.
You may want to remove the bottom panel first. Then remove the turntable motor. In such case the coupler will come off easily.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #34 (permalink)
Old 07-15-2013, 09:16 AM
Junior Member
glewisnc is on a distinguished road
Default Microwave - No Heat, Turntable stopped spinning
I have recently had the same problem, and found this thread. We have a GE PT970S. At first, we noticed the turntable would turn when the door was opened. This lasted a few weeks, and then we noticed the turntable would stop turning and nothing would heat, but sporadically, the turntable would start again and then it heated food fine. Now, the turntable no longer spins and if I check it, the motor seems to be turning freely (there is not the normal motor sound you should hear if you spin it by hand). I checked the coupler, and it looks fine. I am curious:
1) Could a bad motor also stop the microwave from heating?
2) If not, does it seem plausible for a motor and a switch to go out at the same time on a 4 year old microwave?
3) Is it hard to separate the microwave from the oven in order to service it?
THANKS!!!
  #35 (permalink)
Old 12-26-2013, 11:59 AM
Junior Member
Joe_Q is on a distinguished road
Default Microwave Turntable will not turn
Hi Gene,
Can you help me please?
I also have a GE Microwave Oven, where the turntable will not turn anymore.
It stopped working, a couple of months ago. Everything else works fine, but now I have to manually (turn my food every 15 seconds), to get it to cook right.
The model number of my GE microwave oven is:
Model - JES1334WD
Can you tell me, what might be wrong, and how I can fix it?
Thank You
Joe Q
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Turntable won't turn Monica Bauernfeind Microwave Repair 0 10-09-2009 04:31 PM
Sharp microwave turntable won't turn retirednhapy Microwave Repair 2 09-24-2009 07:21 AM
Frigidaire Microwave turntable won't turn djo Microwave Repair 3 09-13-2009 09:38 AM
Microwave turntable will not turn janetlmo Microwave Repair 1 06-16-2009 01:11 PM
Turntable won't turn stlinden Microwave Repair 0 12-23-2008 05:25 PM
