Discuss
Microwave Turntable will not turn
 in
Microwave Repair
In that case most likely the problem is a bad coupler (under the glass plate). - The part number for
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Microwave Turntable will not turn
  #11 (permalink)
Old 09-15-2008, 05:17 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
- The part number for the coupler is AP2016754
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #12 (permalink)
Old 09-20-2008, 11:14 AM
Junior Member
skimaniac6 is on a distinguished road
Default
The coupler seems to be ok, should it just pop off, I don't want to pry it off and break it? My wife said she has heard a grinding noise which I have not heard.
Thanks for taking the time to answer my questions.
Scott
  #13 (permalink)
Old 09-20-2008, 02:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Scott,
Just pull it up and don't be afraid to break the coupler - it's just 7 bucks.
__________________
  #14 (permalink)
Old 09-20-2008, 10:24 PM
Junior Member
Default
I pulled it out and it was broken so either I broke it pulling it out or it was already broken. I will order the piece and see if that does it.
Thanks,
Scott
  #15 (permalink)
Old 09-22-2008, 01:29 PM
Junior Member
bluidqt is on a distinguished road
Default Microwave turntable not turning
I'm having the same trouble as well. The turntable will not rotate. I have a Frigidaire model# GLMV168KQ3 manufactured in January of 2002. Please help me troubleshoot. By the way the button to push to turn the turntable on and off does beep like it is trying to work and the display shows like it is being turned on and off, just not rotating!
  #16 (permalink)
Old 09-22-2008, 04:26 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove the bottom cover and unplug the plug from the turntable motor.
Check for 21VAC coming to the motor while the microwave is "on" and turntable option is "on" as well.
Post the results.
__________________
  #17 (permalink)
Old 11-08-2008, 01:38 PM
Junior Member
dutchie is on a distinguished road
Default Same problem with Frigidaire Gallery CFMT148GPB2
I am having the same problem with the Frigidaire Gallery CFMT148GPB2. Turns half a turn sometimes with the glass plate, turns very slowly without it.
Would someone be so kind to provide me with a diagram and the required part numbers for this model?
Thank you very much.
  #18 (permalink)
Old 11-08-2008, 06:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
dutchie,
The model number you posted does not come up. Is it American model? Verify and repost it, please.
__________________
  #19 (permalink)
Old 11-09-2008, 04:05 PM
Junior Member
Default Frigidaire CFMT
Hi Gene, thanks for your reply.
I'm actually in Canada. When I google part of the model number I find CFMT 148GPB1 which I assume must be the same unit. Date on the tag says Jan. 2000, don't know if that helps. It's an over the range microwave from the Frigidaire Professional line.
Hope you can help, thanks.
  #20 (permalink)
Old 11-27-2008, 06:00 AM
Junior Member
Default Motor for FMT148GPB2
Hi Gene,
I discovered that the model for my microwave is actually the FMT148GPB2, all I had to do was drop the C.
I took out the turntable motor which seems to be defective, the model is ST-16FE(EX73SAAA3). I could not find this part on your site, do you sell it under a differnt part#?
Thanks a lot for your help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Turntable won't turn Monica Bauernfeind Microwave Repair 0 10-09-2009 05:31 PM
Sharp microwave turntable won't turn retirednhapy Microwave Repair 2 09-24-2009 08:21 AM
Frigidaire Microwave turntable won't turn djo Microwave Repair 3 09-13-2009 10:38 AM
Microwave turntable will not turn janetlmo Microwave Repair 1 06-16-2009 02:11 PM
Turntable won't turn stlinden Microwave Repair 0 12-23-2008 06:25 PM
