Discuss
GE Lower Door Interlock switch
 in
Microwave Repair
In most cases problems with electrical and/or electronic parts are not visible and parts can be tested with a
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » GE Lower Door Interlock switch
  #11 (permalink)
Old 04-30-2008, 06:35 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
In most cases problems with electrical and/or electronic parts are not visible and parts can be tested with a special tools (like a multitester) only. Guessing is one of most inefficient and much more expensive way to fix appliances and a microwave is not the simplest one.
I can only try to guide you through the troubleshooting process if you feel ready to do it.
In order to perform the troubleshooting the microwave (I hope the microwave only) has to be removed from the cabinet. The wiring diagram should be inside the microwave if someone else did not remove it earlier.
__________________
Professional appliance repair in Los Angeles, California.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #12 (permalink)
Old 05-29-2008, 01:05 AM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
CBREILLY....Replace the monitor switch. On these models, the mag and turntable goes through the monitor switch, it is the middle switch. Replace it and you'll be good to go....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Lower Door Seal Installation DougB Dishwasher Repair 4 08-02-2008 02:12 PM
New lower door seal is too narrow and leaks kkayaker Dishwasher Repair 4 12-14-2007 12:04 AM
Door switch went bad, jumped out, now dead. barbalew Dryer Repair 1 11-11-2007 05:44 PM
Door Switch kicking breaker f5string Dishwasher Repair 2 08-15-2007 05:50 PM
How do I Get to My Dryer Door Switch aburwick Dryer Repair 1 08-08-2007 05:42 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
