| » Is old microwave repairable? |
For a microwave that old there is a good chance parts are discontinued but on some of those older microwaves the start switch was just a common micro-switch. We need a model number to know any of this for sure. Range Repair Guide
After seeing the model number and rereading your post I am almost sure the problem is a loose solder joint on the power module (#1473 on your parts breakdown). If this is the case you can repair the solder joint and the microwave will be repaired. Hope this helps!
I was pressed for time when I answered. It is very common for a solder joint to get loose on this control board. This will cause the problem you describe. Remove the board and look on the backside of it for a loose joint. If you are not comfortable soldering it replace it. Hope this helps!!
Microwave Repair Guide Here is a link to the part I am talking about Part Details - GE Power module, part number: AP2026570 |
| Display Modes | |
| Whirlpool microwave door will not open and microwave not working | bbowen | Microwave Repair | 5 | 07-21-2010 08:55 PM |
| Is it repairable or its a gonner? | boldeagl | Microwave Repair | 2 | 11-14-2009 11:36 PM |
| Repairable? | jeff.wright | Refrigerator & Freezer Repair | 1 | 09-25-2009 07:02 PM |
| microwave/convection oven blows fuse when trying to microwave | christop | Microwave Repair | 0 | 05-01-2009 06:40 PM |
| Need Microwave knobs for Gaffers/Sattler Combo Range/Microwave | afleer | Oven Repair (including Ranges and Cooktops) | 3 | 11-17-2008 04:46 PM |
