Discuss
microwave does not heat all else is ok
 in
Microwave Repair
sounds like a great idea !
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » microwave does not heat all else is ok
  #21 (permalink)
Old 12-19-2007, 06:31 AM
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
__________________
regards
jim
  #22 (permalink)
Old 01-29-2009, 06:10 PM
Junior Member
w001csm is on a distinguished road
Default GE model jkp62gok3 Dual Wave 2 microwave >No heating
Same problem, all control panel functions work, fan, and lights but the unit does not heat.
Any help?
  #23 (permalink)
Old 01-29-2009, 09:42 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Open the control panel and check the door switches for continuity with the door closed.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #24 (permalink)
Old 06-25-2011, 10:37 AM
Junior Member
wamsleyg is on a distinguished road
Default Kenmore Microwave runs but doesn't heat
Quote:
Originally Posted by Gene View Post
Hi trevlacxam
What part are talking about?
What exactly is wrong with your microwave?
All technical documentation for your Kenmore microwave should be behind the top panel or inside the control panel. If it's not there, you can buy it from Sears only.
Hello Gene,
Saw your post from 2007 and thought I would see if you could help me please?
We (home use) have a Kenmore microwave 1100 watt model 721.66339800 s/n 904TA00596 manufactured April 2009. Purchased Oct 2010 from Sears. Turns run and runs but will not heat. Capacitor checks out fine, Monitor,secondary and primary interlocks check out fine,HV diode checks out fine,Magnetron is checking out fine (according to Tech Sheet). Checked Transformer to ground it is fine,checked filament to ground it is fine but don't understand how to measure resistance for Primary,Secondary and Filament windings according to Tech Sheet. Have the Tech Sheet that tells me what to check and the readings I should obtain. Saw in an earlier post that if you check across Magnetron terminals and get continuity that it is shorted. Is this correct for all microwaves. If yes than this is the problem with this one. If this is not the case then what else can be the problem with thing not wanting to heat. Microwave should have lasted longer than this as we had a Tappan from Sears that kasted 17 Years.
Thanks for any help,
Greg Wamsley
Point Pleasant,WV. 25550
  #25 (permalink)
Old 06-28-2011, 01:48 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Greg,
Sorry for the delay.
If you purchased this microwave in Oct 2010 then it is still under the warranty. Call Sears for service.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Microwave - No Heat sandray68 Microwave Repair 9 02-01-2010 12:25 PM
microwave will not heat mdesai Microwave Repair 0 01-20-2010 04:35 PM
PLEASE HELP! Microwave will not heat tratra Microwave Repair 1 12-03-2009 08:37 AM
Microwave does not heat up. Aliens1 Microwave Repair 1 06-02-2009 08:31 PM
Microwave does not heat hattesn Microwave Repair 0 10-06-2007 11:09 AM
