| » microwave does not heat all else is ok |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Hi Joseph
What is the model number of your microwave? Does it make any unusual noises? Gene.
__________________
Professional appliance repair services in Orange County, California. |
I think I have the same issue. My microwave worked fine but made a crackling sound for about two months and now it just stopped heating. Everything else works fine. Any ideas? Do you know the part number is for the magnetron tube for a GE Profile microwave model: JVM1861SD002
Can you check any of the components inside with a multimeter ?
__________________
regards jim |
if you remove the control panel ( with power off, there should be some paperwork in an envelope ) it will tell you a little about the components inside .. need to check resistance of primary winding of High Voltage Transformer .. should also check High Voltage Capacitor as well ... ( and can also check the Mag Tube as well .. ) this is not necessarily easy and should remember that HV Cap's can store a lot of electricity so try to wear rubber gloves ( how old is unit ? ) sometimes it may be worth while calling a Frigi auth service tech ..
__________________
regards jim |
| Display Modes | |
| Microwave Handle | gmelkin | Microwave Repair | 14 | 07-07-2008 12:05 PM |
| Microwave Oven | PHIL | Microwave Repair | 1 | 08-21-2007 01:51 AM |
| Microwave | tastethecoffee | Microwave Repair | 2 | 08-07-2007 07:28 AM |
| Microwave | WHIRLPOOL | Microwave Repair | 1 | 08-01-2007 12:26 AM |
