Discuss
Need new handle
 in
Microwave Repair
Hi, The door handle bottom connection plastic cracked off. There is still a piece connected to the screw. I was
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Need new handle
  #1 (permalink)
Old 07-08-2018, 10:16 PM
Junior Member
tdolecek is on a distinguished road
Default Need new handle
Model Number: MMV5165BAS   Brand: Maytag   Age: 5 - 10 years
The door handle bottom connection plastic cracked off. There is still a piece connected to the screw. I was able to remove the plastic liner on the inside of the door and get access to the screws. I was successful in removing the top screw, but the bottom screw is so tight I cannot get it to turn while holding the broken piece of plastic still in the door. The screw head is starting to strip. Any ideas on extracting?
Is there a replacement handle available for this model?
If so, does it come with screws?
Related Models
Maytag MMV5165BAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165BAS14 Microwave Oven/Hood 1.6 Cu. Ft.
Maytag MMV5165BAS15 MICROWAVE OVEN/HOOD 1.6 Cu. Ft.
Maytag MMV5165BAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165BAW15 Microwave Oven/Hood 1.6 Cu. Ft.
Maytag MMV5165BAW16 MICROWAVE OVEN/HOOD 1.6 Cu. Ft.
Maytag MMV5186AAB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186AAQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186AAS MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186AAW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186ACB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186ACQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186ACS MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186ACW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5201DB00 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5201DS00 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5201DW00 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5207AAB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207AAQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207AAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207AAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207ACB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207ACQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207ACS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207ACW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BAB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BAB14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BAB17 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5207BAQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BAQ14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BAQ17 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5207BAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BAS14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BAS17 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5207BAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BAW15 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BAW18 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5207BCB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BCB14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCB17 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCB18 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BCQ14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCQ17 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCQ18 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BCS14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCS17 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCS18 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BCW15 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCW18 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCW19 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5208WB0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV5208WQ0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV5208WS0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV5208WW0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV6178AAB MICROWAVE - CONVECTION
Maytag MMV6178AAQ MICROWAVE - CONVECTION
Maytag MMV6178AAS MICROWAVE - CONVECTION
Maytag MMV6178AAW MICROWAVE - CONVECTION
Maytag MMV6180WB0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMV6180WS0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMV6180WW0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMV6186WB0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMV6186WS0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMV6186WW0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMW5527BAB WALLOVEN- S/C ELE
Maytag MMW5527BAW WALLOVEN- S/C ELE
Maytag MMW5527CAB WALLOVEN- S/C ELE
Maytag MMW5527CAW WALLOVEN- S/C ELE
Maytag MMW5530BAB WALLOVEN- S/C ELE
Maytag MMW5530BAW WALLOVEN- S/C ELE
Maytag MMW5530CAB WALLOVEN- S/C ELE
Maytag MMW5530CAW WALLOVEN- S/C ELE
Maytag MMW5530DAB WALLOVEN- S/C MWAVE ELE
Maytag MMW5530DAB20 30" BUILT-IN MICROWAVE/ELECTRIC OVEN COMBO SELF-CLEAN
Maytag MMW5530DAW WALLOVEN- S/C MWAVE ELE
Maytag MMW5530DAW21 30" BUILT-IN MICROWAVE/ELECTRIC OVEN COMBO SELF-CLEAN
Maytag MMW7530WDB01 30" BUILT-IN ELECTRIC COMBO SENSOR/SC
Maytag MMW7530WDS01 30" BUILT-IN ELECTRIC COMBO SENSOR/SC
Maytag MMW7530WDW01 30" BUILT-IN ELECTRIC COMBO SENSOR/SC
Norge MN15E-5 MWAVE- CNTRTP / STAND ALONE
Norge MN15F-14T MWAVE- CNTRTP / STAND ALONE
Norge MN15FN-14T MWAVE- CNTRTP / STAND ALONE
Norge MN46G-14T MWAVE- CNTRTP / STAND ALONE
Norge MN46GN-14T MWAVE- CNTRTP / STAND ALONE
 MO1450BA MWAVE- MOUNTED OVER RANGE/WO
 MO1450CA MWAVE- MOUNTED OVER RANGE/WO
 MO1450WA MWAVE- MOUNTED OVER RANGE/WO
 MO1650BA MWAVE- MOUNTED OVER RANGE/WO
 MO1650CA MWAVE- MOUNTED OVER RANGE/WO
 MO1650WA MWAVE- MOUNTED OVER RANGE/WO
Magic Chef MOD61AD MWAVE- MOUNTED OVER RANGE/WO
Magic Chef MOD61WH MWAVE- MOUNTED OVER RANGE/WO
Magic Chef MOD62AD MWAVE- MOUNTED OVER RANGE/WO
Magic Chef MOD62WH MWAVE- MOUNTED OVER RANGE/WO
Magic Chef MOD62WOW MWAVE- MOUNTED OVER RANGE/WO
Magic Chef MOD64WOW MWAVE- MOUNTED OVER RANGE/WO
Magic Chef MOD65B MWAVE- MOUNTED OVER RANGE/WO
Magic Chef MOD65WOW MWAVE- MOUNTED OVER RANGE/WO
Whirlpool MODEL_PBK0190
Magic Chef MODW1A MWAVE- MOUNTED OVER RANGE/WO
Magic Chef MODW1V MWAVE- MOUNTED OVER RANGE/WO
Amana MP1.A COMMERCIAL MICROWAVES
Amana MP1.B COMMERCIAL MICROWAVES
Amana MPD218-02 MWAVE - FAMILY SIZE (60 HZ)
Frigidaire MPF200PBDA Frg(v2) / Gas Range
Frigidaire MPF200PBWA Frg(v1) / Gas Range
Frigidaire MPF240GSA GAS RANGE
Frigidaire MPF300BPDA Gib(v9) / Gas Range
Frigidaire MPF300PBDA Frg(v1) / Gas Range
Frigidaire MPF300PBDB Wwh(v1) / Gas Range
Frigidaire MPF300PBDC Frg(v1) / Gas Range
Frigidaire MPF300PBDD Frg(v1) / Gas Range
Frigidaire MPF300PBDE Frg(v1) / Gas Range
Frigidaire MPF300PBDF Frg(v1) / Gas Range
Frigidaire MPF300PBWA Frg(v2) / Gas Range
Frigidaire MPF300PBWB Wwh(v2) / Gas Range
Frigidaire MPF300PBWC Frg(v2) / Gas Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replace handle brianbar Microwave Repair 1 07-26-2012 02:36 PM
Handle replacement Prlambert Microwave Repair 0 11-25-2011 11:23 AM
handle JenniferRBailey Microwave Repair 0 01-12-2009 07:39 AM
Replacing GE Handle cpaulis Microwave Repair 0 06-18-2008 03:44 PM
How to put new handle on shelly Microwave Repair 1 07-24-2007 12:03 PM
