Discuss
Microwave Making Loud Humming Sound after Replacing Thermal Flame/Sensor
 in
Microwave Repair
My GE microwave (JE1860SB 002) made a cracking sound and stopped working. After some research, I removed the cover and
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Microwave Making Loud Humming Sound after Replacing Thermal Flame/Sensor
  #1 (permalink)
Old 01-29-2018, 04:38 PM
Junior Member
BayouDude is on a distinguished road
Default Microwave Making Loud Humming Sound after Replacing Thermal Flame/Sensor
Model Number: JE1860SB002   Brand: GE   Age: Less than 1 year
My GE microwave (JE1860SB 002) made a cracking sound and stopped working. After some research, I removed the cover and checked the fuse and it was good. I then checked the thermal flame/sensor and discovered it was burned out. I replaced the thermal flame/sensor and now the unit comes on but makes a loud humming sound and has a burnt smell. The next step (according to my research) is checking the diode (cable) which is attached to the capacitor. It appears I need to discharge the capacitor before proceeding? --- BEFORE replacing the sensor, the unit had been unplugged for over one week….AFTER replacing the sensor, the unit was plugged in for about 5 minutes on Jan 25, 2018.
- What is the best/safest way to discharge the capacitor? Is an insulated screw driver or pliers needed or will a rubber handle tool work considering the time it has been unplugged?
- Should I remove the two connecting wires and diode before attempting to discharge the capacitor?
- If the diode is bad should I still check the Magnetron?
- If the diode is good, what is the next item to check/test?
Related Models
General Electric JE1860SB002 Counter top microwave
General Electric JE1860SB003 Counter top microwave
General Electric JE1860SB01 Counter top microwave
General Electric JE1860SH001 Counter top microwave
General Electric JE1860SH02 Counter top microwave
General Electric JE1860SH03 Counter top microwave
General Electric JE1860SH04 Counter top microwave
General Electric JE1860WB001 MICROWAVE
General Electric JE1860WB002 Counter top microwave
General Electric JE1860WB003 Counter top microwave
General Electric JE1860WB01 Counter top microwave
General Electric JE1860WH001 Counter top microwave
General Electric JE1860WH02 Counter top microwave
General Electric JE1860WH03 Counter top microwave
General Electric JE1860WH04 Counter top microwave
General Electric JE2160BF01 MICROWAVE
General Electric JE2160BF02 Counter top microwave
General Electric JE2160BF03 Counter top microwave
General Electric JE2160CF001 Counter top microwave
General Electric JE2160CF02 Counter top microwave
General Electric JE2160CF03 Counter top microwave
General Electric JE2160SF001 Counter top microwave
General Electric JE2160SF02 Counter top microwave
General Electric JE2160SF03 Counter top microwave
General Electric JE2160SF04 MICROWAVE
General Electric JE2160WF001 Counter top microwave
General Electric JE2160WF02 Counter top microwave
General Electric JE2160WF03 MICROWAVE
General Electric JE280001 Counter top microwave
General Electric JE2800A01 Counter top microwave
General Electric JE2800A02 Counter top microwave
General Electric JE2800A03 Counter top microwave
General Electric JE2810A01 Counter top microwave
General Electric JE2810A02 Counter top microwave
General Electric JE2810A03 Counter top microwave
General Electric JE282101 Counter top microwave
General Electric JE2821H01 Counter top microwave
General Electric JE2821H02 Counter top microwave
General Electric JE2821H03 Counter top microwave
General Electric JE285101 Counter top microwave
General Electric JE2851H01 Counter top microwave
General Electric JE2851H02 Counter top microwave
General Electric JE2851H03 Counter top microwave
General Electric JE3001 Counter top microwave
General Electric JE3002 Counter top microwave
General Electric JE320GA01 Counter top microwave
General Electric JE320WA01 Counter top microwave
Jenn-Air JE3510PRW RANGE- F/S STD ELE
Jenn-Air JE3521WRV RANGE- F/S STD ELE
Jenn-Air JE3521XRA RANGE- F/S STD ELE
Jenn-Air JE3521XRW RANGE- F/S STD ELE
Jenn-Air JE3842VRV RANGE- S/C F/S ELE
Jenn-Air JE3842XRA RANGE- S/C F/S ELE
Jenn-Air JE3842XRW RANGE- S/C F/S ELE
General Electric JE3A001 Counter top microwave
General Electric JE3A002 Counter top microwave
General Electric JE40001 Counter top microwave
General Electric JE40002 Counter top microwave
General Electric JE40003 Counter top microwave
General Electric JE41A01 Counter top microwave
General Electric JE41A02 Counter top microwave
General Electric JE41A03 Counter top microwave
General Electric JE41A04 Counter top microwave
General Electric JE41A05 Counter top microwave
General Electric JE42001 Counter top microwave
General Electric JE42002 Counter top microwave
General Electric JE42003 Counter top microwave
General Electric JE42004 Counter top microwave
General Electric JE42005 Counter top microwave
General Electric JE42A01 Counter top microwave
General Electric JE42A02 Counter top microwave
General Electric JE42A03 Counter top microwave
General Electric JE42A04 Counter top microwave
General Electric JE42A05 Counter top microwave
General Electric JE43001 Counter top microwave
General Electric JE43002 Counter top microwave
General Electric JE43003 Counter top microwave
General Electric JE43004 Counter top microwave
General Electric JE43005 Counter top microwave
General Electric JE45001 Counter top microwave
General Electric JE45002 Counter top microwave
General Electric JE45003 Counter top microwave
General Electric JE45004 Counter top microwave
General Electric JE45005 Counter top microwave
General Electric JE45A01 Counter top microwave
General Electric JE45A02 Counter top microwave
General Electric JE45A03 Counter top microwave
General Electric JE45A04 Counter top microwave
General Electric JE45A05 Counter top microwave
General Electric JE47001 Counter top microwave
General Electric JE47A01 Counter top microwave
General Electric JE47A02 Counter top microwave
General Electric JE47A03 Counter top microwave
General Electric JE47H01 Counter top microwave
General Electric JE48001 Counter top microwave
General Electric JE48002 Counter top microwave
General Electric JE48003 Counter top microwave
General Electric JE48004 Counter top microwave
General Electric JE48A01 Counter top microwave
General Electric JE48A02 Counter top microwave
General Electric JE48A03 Counter top microwave
General Electric JE48A04 Counter top microwave
General Electric JE48A05 Counter top microwave
General Electric JE49A01 Counter top microwave
General Electric JE510BW005 Counter top microwave
General Electric JE510BW01 Counter top microwave
General Electric JE510BW02 Counter top microwave
General Electric JE510BW03 Counter top microwave
General Electric JE510WC001 Counter top microwave
General Electric JE520BW005 Counter top microwave
General Electric JE520BW01 Counter top microwave
General Electric JE520BW02 Counter top microwave
General Electric JE520BW03 Counter top microwave
General Electric JE520WC001 Counter top microwave
General Electric JE610BF001 Counter top microwave
General Electric JE610WF001 Counter top microwave
General Electric JE62001 Counter top microwave
General Electric JE62002 Counter top microwave
General Electric JE620BF001 Counter top microwave
General Electric JE620WF001 Counter top microwave
  #2 (permalink)
Old 01-30-2018, 03:06 AM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Always discharge the capacitor before you touch anything near it or the magnetron. The capacitor can store 2000 volts. Most of the time they will be discharged, but its not worth the risk to find out the hard way.
You can use a screwdriver with an insulated handle. Just be careful and use the old radio repairman's trick, keep one hand in your pocket and make sure your body isn't touching anything, then use the screwdriver in your other hand to discharge the capacitor. That way you can't stop your own heart.
Take pictures as you disassemble the microwave, that makes it a lot easier later.
The crackling noise and now the burning smell makes me think you should check the magnetron for a burnt antenna. Its the round part that sticks into the waveguide. You will need to take the magnetron off to check it. Also check the waveguide for burnt or arced areas.
I have seen the diodes crack and arc, but its rare.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Igniter, flame sensor, soleniods, thermal sensor all OK - but no heat silentrunningpc Dryer Repair 2 09-01-2016 07:59 PM
Thermal fuse and Flame sensor wiring cwizzards Dryer Repair 2 05-08-2010 08:37 AM
Kenmore 17039 making loud humming sound RobWestergaard Dishwasher Repair 0 11-28-2009 10:27 AM
loud humming sound dryerasap2 Dryer Repair 2 11-30-2008 06:15 PM
GE Microwave making humming sound, trips trips fuse cadena16 Microwave Repair 1 07-07-2008 01:30 PM
