chaplainmurph
#1 Posted : Friday, December 1, 2017 6:38:50 AM(UTC)
chaplainmurph
I can not get the door to close and latch for it to work. The door shuts but the light will not go off and it will not operate. By moving and putting pressure on thee handle I can sometimes make connection. The latch on the door appears to be OK but will not latch
ThatGuy
#2 Posted : Friday, December 1, 2017 5:55:07 PM(UTC)
ThatGuy
Groups: Expert
United States
Part no. 67 on this diagram is the latch. Its spring loaded and should be hard to push up and spring back down when released. If not its broken or has a broken spring. It it works OK it might be a bad door switch.
Parts for Frigidaire FGMV174KFC: Control Panel,door,miscellaneous Parts - AppliancePartsPros.com
chaplainmurph
#3 Posted : Tuesday, December 5, 2017 3:38:07 PM(UTC)
chaplainmurph
Thanks for the advice. I ordered replacement parts but then saw a video on how to replace parts and the spring had come off. Fixed the problem and it now is working again. Now I guess I need to find a place to keep the parts that I ordered.
GE Oven - Microwave/Oven PT7800SH2SSA (Oven Repair (including Ranges and Cooktops))
by Guest 2/13/2024 11:22:12 AM(UTC)
Kenmore Pizza Oven Microwave (Microwave Repair)
by mwjkmail 2/3/2024 5:10:49 PM(UTC)
Kitchenaid (Whirlpool) Microwave door switches (Microwave Repair)
by ForumUser1 1/11/2024 1:11:07 PM(UTC)
Whirlpool Microwave Lower Bulb will not turn on (WMH31017HS08) (Microwave Repair)
by Axtell 1/2/2024 3:49:44 PM(UTC)
Kitchen aid electric wall microwave and oven (Microwave Repair)
by Guest 11/9/2023 8:15:09 AM(UTC)
Frigidaire Microwave PLMVZ169HCA (Microwave Repair)
by Guest 10/25/2023 11:02:01 AM(UTC)
KitcheAid Microwave/Oven Wall Combo KOCE500ESS05 Error Code F6E8 (Microwave Repair)
by tjperlman 10/19/2023 10:07:59 PM(UTC)
Microwave Advantium 120 display blank (Microwave Repair)
by tod.colbert@gmail.com 8/6/2023 9:13:49 AM(UTC)
Litton model 1800 microwave (Microwave Repair)
by Guest 7/14/2023 7:08:12 PM(UTC)
Microwave touchpad (Microwave Repair)
by duguyisheng 7/6/2023 5:12:28 PM(UTC)
Over range Microwave exhaust fan slows (Microwave Repair)
by Mmetzinger 6/3/2023 7:19:23 AM(UTC)
Dim Light on Microwave (Microwave Repair)
by Guest 5/15/2023 8:31:44 AM(UTC)
Kitchenaid kbms1454bbl microwave (Microwave Repair)
by Guest 4/1/2023 10:24:42 AM(UTC)
Microwave Parts Cannot Be Returned and Microwave Still Has The Problem (Microwave Repair)
by atlantic 3/31/2023 12:42:43 PM(UTC)
Apollo convection microwave (Microwave Repair)
by Guest 2/21/2023 12:14:33 PM(UTC)
