Discuss
Jenn-Air combo wall oven microwave - light bulb
 in
Microwave Repair
I have a Jenn-Air combination wall oven and microwave (with a common control panel on top) - model is JMW3430.
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Jenn-Air combo wall oven microwave - light bulb
  #1 (permalink)
Old 11-27-2017, 05:48 PM
Junior Member
rschleicher is on a distinguished road
Default Jenn-Air combo wall oven microwave - light bulb
Model Number: JMW3430   Brand: Jenn-Air   Age: 1 - 5 years
The microwave actually has a convection oven burner element on the ceiling, and the light bulb housing is just above this burner element. (Basically the bulb is in the middle of the ceiling, somewhat towards the front.
The bulb has gone out, and I don't see any way to remove the bulb. There is what appears to be a small glass dome over the bulb, but I don't see any way to remove it. Maybe it unscrews, but it's not turning.
Is it really possible that you have to pull the unit, or, alternatively, pull the control panel from the wall, to get at the bulb from the top? That seems incredibly stupid, to require significant disassembly just to replace a light bulb....
There are also Kitchen-Aid (and maybe Whirpool Gold) units that are essentially the same as this one, if that helps.
Am I missing something? If anyone can direct me to a source for the service manual, I'd also appreciate that. Thx!
Related Models
Maytag JMW3430WB00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WB01 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WP00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WP01 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WR00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WR01 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WS00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WS01 30" MICROWAVE / WALL OVEN COMBO
Jenn-Air JMW8130AAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8130AAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8130DAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8130DAS WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8130DAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8330DAB WALLOVEN- S/C MWAVE ELE
Maytag JMW8330DAB15 30" BUILT-IN MICROWAVE/ELECTRIC OVEN COMBO SELF-CLEAN
Jenn-Air JMW8330DAS WALLOVEN- S/C MWAVE ELE
Maytag JMW8330DAS16 30" BUILT-IN MICROWAVE/ELECTRIC OVEN COMBO SELF-CLEAN
Jenn-Air JMW8330DAW WALLOVEN- S/C MWAVE ELE
Maytag JMW8330DAW16 30" BUILT-IN MICROWAVE/ELECTRIC OVEN COMBO SELF-CLEAN
Jenn-Air JMW8527AAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8527AAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8527BAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8527BAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8527CAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8527CAS WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8527CAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8527DAB WALLOVEN- S/C MWAVE ELE
Maytag JMW8527DAB27 27" BUILT-IN ELECTRIC OVEN NON-CONVECTION
Jenn-Air JMW8527DAQ WALLOVEN- S/C MWAVE ELE
Maytag JMW8527DAQ27 27" BUILT-IN ELECTRIC OVEN NON-CONVECTION
Jenn-Air JMW8527DAS WALLOVEN- S/C MWAVE ELE
Maytag JMW8527DAS28 27" BUILT-IN ELECTRIC OVEN NON-CONVECTION
Jenn-Air JMW8527DAW WALLOVEN- S/C MWAVE ELE
Maytag JMW8527DAW27 27" BUILT-IN ELECTRIC OVEN NON-CONVECTION
Jenn-Air JMW8530AAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8530AAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8530BAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8530BAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8530CAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8530CAS WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8530CAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8530DAB WALLOVEN- S/C MWAVE ELE
Maytag JMW8530DAB28 30" BUILT-IN ELECTRIC COMBO NON-CONVECTION
Jenn-Air JMW8530DAQ WALLOVEN- S/C MWAVE ELE
Maytag JMW8530DAQ28 30" BUILT-IN ELECTRIC COMBO NON-CONVECTION
Jenn-Air JMW8530DAS WALLOVEN- S/C MWAVE ELE
Maytag JMW8530DAS28 30" BUILT-IN ELECTRIC COMBO NON-CONVECTION
Jenn-Air JMW8530DAW WALLOVEN- S/C MWAVE ELE
Maytag JMW8530DAW29 30" BUILT-IN ELECTRIC COMBO NON-CONVECTION
Jenn-Air JMW9130DAB WALLOVEN- STD MWAVE ELE
Jenn-Air JMW9130DAS WALLOVEN- STD MWAVE ELE
Jenn-Air JMW9130DAW WALLOVEN- STD MWAVE ELE
Jenn-Air JMW9330DAB WALLOVEN- S/C MWAVE ELE
Maytag JMW9330DAB16 30" BUILT-IN MICROWAVE/ELECTRIC OVEN COMBO SELF-CLEAN
Jenn-Air JMW9330DAS WALLOVEN- S/C MWAVE ELE
Maytag JMW9330DAS16 30" BUILT-IN MICROWAVE/ELECTRIC OVEN COMBO SELF-CLEAN
Jenn-Air JMW9330DAW WALLOVEN- S/C MWAVE ELE
Maytag JMW9330DAW16 30" BUILT-IN MICROWAVE/ELECTRIC OVEN COMBO SELF-CLEAN
Jenn-Air JMW9527AAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9527AAQ WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9527AAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9527BAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9527BAQ WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9527BAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9527CAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9527CAQ WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9527CAS WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9527CAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9527DAB WALLOVEN- S/C MWAVE ELE
Maytag JMW9527DAB29 27" BUILT-IN ELECTRIC OVEN CONVECTION
Jenn-Air JMW9527DAS WALLOVEN- S/C MWAVE ELE
Maytag JMW9527DAS30 27" BUILT-IN ELECTRIC OVEN CONVECTION
Jenn-Air JMW9527DAW WALLOVEN- S/C MWAVE ELE
Maytag JMW9527DAW29 27" BUILT-IN ELECTRIC OVEN CONVECTION
Jenn-Air JMW9530AAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9530AAQ WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9530AAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9530BAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9530BAQ WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9530BAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9530CAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9530CAQ WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9530CAS WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9530CAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9530DAB WALLOVEN- S/C MWAVE ELE
Maytag JMW9530DAB29 30" BUILT-IN ELECTRIC COMBO CONVECTION
Jenn-Air JMW9530DAS WALLOVEN- S/C MWAVE ELE
Maytag JMW9530DAS30 30" BUILT-IN ELECTRIC COMBO CONVECTION
Jenn-Air JMW9530DAW WALLOVEN- S/C MWAVE ELE
Maytag JMW9530DAW30 30" BUILT-IN ELECTRIC COMBO CONVECTION
General Electric JN30*01 Electric range
General Electric JN30*02 Electric range
General Electric JN319WIW Electric range
General Electric JN322*01 Electric range
General Electric JN322*02 Electric range
General Electric JN322*03 Electric range
General Electric JN322*J1 Electric range
General Electric JN322*J2 Electric range
General Electric JN322J3 Electric range
General Electric JN322S2 Gas range
General Electric JN322S3AD Range accessory
General Electric JN322S3WH Range accessory
General Electric JN322V1AD Range accessory
General Electric JN322V1WH Range accessory
General Electric JN327H1AA Electric range
General Electric JN327H1BB Electric range
General Electric JN327H1CC Electric range
General Electric JN327H1WW Electric range
General Electric JN327X1AD Range accessory
General Electric JN327X1CT Range accessory
General Electric JN327X1WH Range accessory
General Electric JN330*01 Electric range
General Electric JN330*02 Electric range
General Electric JN330*03 Electric range
General Electric JN334*01 Electric range
General Electric JN334*02 Electric range
General Electric JN334*03 Electric range
General Electric JN334*J1 Electric range
General Electric JN334*J2 Electric range
General Electric JN334J3 Electric range
  #2 (permalink)
Old 11-29-2017, 09:12 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
I don't know this microwave, but many microwaves have a grill above the door that comes off and the light compartment can be accessed through there.
Just make sure its unplugged before you change the bulb.
  #3 (permalink)
Old 11-30-2017, 10:19 AM
Junior Member
Default
Thanks for the comment, That Guy.
In my case, what's above the microwave is the control panel for both the microwave and the oven (it's a combo wall oven and microwave).
There is a front panel (exposed when the door is open) that frames the microwave cooking area. It has four Torx screws along it's top edge. It MIGHT be that removing these four Torx screws will allow the front panel to be removed, or tilted out, and that MIGHT expose the area above the cooking area, but I am a little leery of removing the Torx screws without knowing what will happen when I do.... The other way to access the bulb might be to remove the control panel that sits above it. It's just not obvious....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
replace bad microwave in Kenmore model 790.47853403 microwave/wall oven combo unit? Wildt Microwave Repair 3 07-30-2015 10:02 AM
How To Change The Bulb In Microwave Oven Combo Lax21 Oven Repair (including Ranges and Cooktops) 1 02-01-2014 11:26 AM
Microwave Wall Oven combo - Microwave repair Alexismyboy Microwave Repair 0 09-15-2012 09:39 AM
