Discuss
Microwave Turns On And Hums But No Heat
 in
Microwave Repair
The other day I went to heat up food in my Kenmore microwave and after about 15-20 seconds there was
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Microwave Turns On And Hums But No Heat
  #1 (permalink)
Old 06-27-2017, 09:53 AM
Junior Member
jimmy12345678 is on a distinguished road
Default Microwave Turns On And Hums But No Heat
Model Number: 566.8832980   Brand: Kenmore   Age: More than 10 years
The other day I went to heat up food in my Kenmore microwave and after about 15-20 seconds there was smoke rolling out of it. So I unplugged it and took the cover over to see what was wrong. I ran it with the cover off and noticed that the transformer was getting very hot and that's what was smoking, so I found another one that would fit and installed it. Now the microwave turns on and doesn't smoke, but it also doesn't make things hot. I put a cup of water in there for a minute and it was still ice cold.
I've searched online and found Microtech Factory Service and they had diagnostic procedures to test the various components inside a microwave. I'll post the results of those tests below;
Transformer
Between Primary Windings - 0.2 ohms (Old and New)
Between Primary Leads And Ground - Open
Between Filiment Wires - 0.2 ohms (Old and New)
Between Filiment Leads And Ground - Open (Old and New)
Between Voltage Tap and ground - Old One - 848 ohms (spec says 55-70 Ohms) New One - 102 Ohms I don't know if this is too far out of spec or not
Magnetron:
Between Both Terminals - 0.2 Ohms
Between Terminals And Ground - Open
Capacitor:
Between both terminals - Slowly climbs to OL, when switched goes back to zero and starts climbing back to OL
Between terminals and ground - Open
Diode:
0.2M Ohms one way
OL other way
Thermal Protectors (2)
Both 0.2 ohms across terminals
It just doesn't make any sense why it doesn't work now. It worked on Saturday, then yesterday I used it and that's when the transformer overheated. And I didn't touch anything else inside, just wired up the new transformer just as the old one was. Same specs on both of them (120v, 60 Hz). Unless this new transformer is also defective (as I said, the 102 Ohms on the high side is above the spec I found).
If anyone can help me or they need me to conduct more tests I'm more than happy to help. Thanks!!!
Related Models
Frigidaire 5695A AIR CONDITIONER
Frigidaire 57-2707-00-03 Tap(v2) / Electric Range
Frigidaire 57-2707-10-01 Tap(v1) / Microwave and Electric Wall Oven
Frigidaire 57-2707-10-02 Tap(v3) / Microwave and Electric Wall Oven
Frigidaire 57-2707-10-03 Tap(v1) / Electric Range
Frigidaire 57-2709-00-02 Tap(v1) / Wall Oven
Frigidaire 57-2709-00-06 Tap(v1) / Wall Oven
Frigidaire 57-2709-00-07 Tap(v1) / Wall Oven
Frigidaire 57-2709-10-01 Tap(v1) / Wall Oven
Frigidaire 57-2709-10-03 Tap(v1) / Wall Oven
Frigidaire 57-2709-10-04 Tap(v2) / Wall Oven
Frigidaire 57-2709-10-05 Tap(v3) / Wall Oven
Frigidaire 57-2729-00-01 Tap(v1) / Wall Oven
Frigidaire 57-2729-00-02 Tap(v1) / Wall Oven
Frigidaire 57-5709-10-03 Tap(v0) / Wall Oven
Frigidaire 57-6707-00-03 Tap(v4) / Electric Range
Frigidaire 57-6707-10-01 Tap(v2) / Microwave and Electric Wall Oven
Frigidaire 57-6707-10-02 Tap(v4) / Microwave and Electric Wall Oven
Frigidaire 57-6707-10-03 Tap(v3) / Electric Range
Frigidaire 57-6709-00-03 Tap(v1) / Wall Oven
Frigidaire 57-6709-10-01 Tap(v2) / Wall Oven
Admiral 570AH RANGE- F/S STD GAS
Admiral 570AH-K RANGE- F/S STD GAS
Admiral 570AJ RANGE- F/S STD GAS
Admiral 570AJ-K RANGE- F/S STD GAS
Admiral 570WH RANGE- F/S STD GAS
Admiral 570WH-K RANGE- F/S STD GAS
Admiral 570WJ RANGE- F/S STD GAS
Admiral 570WJ-K RANGE- F/S STD GAS
Admiral 571AH RANGE- F/S STD GAS
Admiral 571AHK RANGE- F/S STD GAS
Admiral 571WH RANGE- F/S STD GAS
Admiral 571WHK RANGE- F/S STD GAS
Hoover 574
Hoover 576
General Electric 57731H7WW WASHER
General Electric 57731H8WW WASHER
General Electric 57731H9WW WASHER
General Electric 57751H3WW WASHER
Kenmore 58051300 DEHUMIDIFIER
Kenmore 58051300000 DEHUMIDIFIER
Kenmore 58051450 DEHUMIDIFIER
Kenmore 58051450100 DEHUMIDIFIER
Kenmore 58051650000 DEHUMIDIFIER
Kenmore 58052300200 DEHUMIDIFIER
Kenmore 58052450000 DEHUMIDIFIER
Kenmore 58052450200 DEHUMIDIFIER
Kenmore 58052650 DEHUMIDIFIER
Kenmore 58052650000 DEHUMIDIFIER
Kenmore 58052650100 DEHUMIDIFIER
Kenmore 58053301300 DEHUMIDIFIER
Kenmore 58053509300 DEHUMIDIFIER
Kenmore 58053650200 DEHUMIDIFIER
Kenmore 58053701300 DEHUMIDIER
Kenmore 58054351400 DEHUMIDIFIER
Kenmore 58054351500 DEHUMIDIFIER
Kenmore 58054351700 DEHUMIDIFIER
Kenmore 58054351800 DEHUMIDIFIER
Kenmore 58054351900 DEHUMIDIFIER
Kenmore 58054501400 DEHUMIDIFIER
Kenmore 58054501500 DEHUMIDIFIER
Kenmore 58054501700 DEHUMIDIFIER
Kenmore 58054501800 DEHUMIDIFIER
Kenmore 58054501801 DEHUMIDIFIER
Kenmore 58054701400 DEHUMIDIFIER
Kenmore 58054701500 DEHUMIDIFIER
Kenmore 58054701700 DEHUMIDIFIER
Kenmore 58054701800 DEHUMIDIFIER
Kenmore 58059600890 DEHUMIDIFIER
Kenmore 58066291690 MICROWAVE
Kenmore 58070074000 AIR CONDITIONER
Kenmore 58070122000 AIR CONDITIONER
Kenmore 58070188000 ROOM AIR CONDITIONER
Kenmore 58071056100 AIR CONDITIONER
Kenmore 58071073100 AIR CONDITIONER
Kenmore 58071082100 AIR CONDITIONER
Kenmore 58071121100 AIR CONDITIONER
Kenmore 58071122100 AIR CONDITIONER
Kenmore 58071184100 AIR CONDITIONER
Kenmore 58072053100 AIR CONDITIONER
Kenmore 58072056200 AIR CONDITIONER
Kenmore 58072059200 AIR CONDITIONER
Kenmore 58072066200 AIR CONDITIONER
Kenmore 58072077200 AIR CONDITIONER
Kenmore 58072082200 AIR CONDITIONER
Kenmore 58072083200 AIR CONDITIONER
Kenmore 58072087200 ROOM A/C
Kenmore 58072089200 ROOM A/C
Kenmore 58072093200 AIR CONDITIONER
Kenmore 58072104200 AIR CONDITIONER
Kenmore 58072124200 AIR CONDITIONER
Kenmore 58072124300 AIR CONDITIONER
Kenmore 58072126200 AIR CONDITIONER
Kenmore 58072127200 AIR CONDITIONER
Kenmore 58072128200 AIR CONDITIONER
Kenmore 58072144200 AIR CONDITIONER
Kenmore 58072184200 AIR CONDITIONER
Kenmore 58072187200 AIR CONDITIONER
Kenmore 58072187300 AIR CONDITIONER
Kenmore 58072189200 AIR CONDITIONER
Kenmore 58073053200 AIR CONDITIONER
Kenmore 58073069300 AIR CONDITIONER
Kenmore 58073069301 AIR CONDITIONER
Kenmore 58073082300 AIR CONDITIONER
Kenmore 58073083300 AIR CONDITIONER
Kenmore 58073089300 AIR CONDITIONER
Kenmore 58073093300 AIR CONDITIONER
Kenmore 58073103200 AIR CONDITIONER
Kenmore 58073104300 AIR CONDITIONER
Kenmore 58073123200 AIR CONDITIONER
Kenmore 58073144300 AIR CONDITIONER
Kenmore 58073184300 AIR CONDITIONER
Kenmore 58073189300 AIR CONDITIONER
Kenmore 58074053300 AIR CONDITIONER
Kenmore 58074054400 AIR CONDITIONER
Kenmore 58074055400 AIR CONDITIONER
Kenmore 58074066400 ROOM A/C
Kenmore 58074082400 AIR CONDITIONER
Kenmore 58074083400 AIR CONDITIONER
Kenmore 58074085400 AIR CONDITIONER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Microwave hums when door is closed and won't heat jbergman Microwave Repair 0 05-30-2014 09:32 AM
GE profile microwave turns on will not heat JOHNWIN69 Microwave Repair 1 05-13-2013 07:52 PM
Microwave hums, no heat. cesarsavi Microwave Repair 0 01-16-2009 11:53 AM
Microwave hums, no heat. cesarsavi Microwave Repair 0 01-16-2009 11:51 AM
Kenmore Microwave Hums - No Heat bobmcg Microwave Repair 0 12-06-2008 04:15 PM
