Door Interlock Repair - Fixed It!
Microwave Repair
For the past year, about once a month, my 20+ year-old Amana RSW659P microwave would trip the circuit breaker (the
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Door Interlock Repair - Fixed It!
  #1 (permalink)
Old 04-08-2017, 03:59 PM
Junior Member
johnmeyer is on a distinguished road
Default Door Interlock Repair - Fixed It!
Model Number: RSW659P   Brand: Amana   Age: More than 10 years
For the past year, about once a month, my 20+ year-old Amana RSW659P microwave would trip the circuit breaker (the one in my breaker box, not anything inside the oven itself). This always happened at the very instant I pressed the start button.
Each time this happened, I went to the breaker box and reset the breaker. When I returned to the microwave oven, it would then work normally and usually continue to work for weeks or months until, out of the blue, it would happen again.
A quick Internet search turned up lots of information about this symptom, and every single post claimed that the problem was almost certainly the door interlock.
Since it was so infrequent, I lived with the problem for over a year, but two days ago, after resetting the house circuit breaker, when I returned to the microwave, when I pressed start, the timer started counting down, and I thought I could hear the sound of the "flyback" (the HV driving the magnetron), but the main relay didn't click, and I got no fan or heat.
Now it was dead.
I searched high and low for a place that carried a replacement interlock switch, but they appear to have all been sold. I even searched for the Cherry generic version (they manufactured the switch for Amana), and did find one part, but it was in Italy, and I didn't want to deal with an overseas purchase.
I was going to buy another oven, but this is built in, with a nifty trim kit that includes duct work to route air to the oven. I was having a tough time finding something that would fit, was designed for use as a built-in, and which did all the things this great appliance does.
So, in desperation, I decided to try to repair the interlock switch.
It turns out that this is really simple to do. The switch is manufactured with a cover on one side which has half a dozen posts which fit into holes and female posts on the other side. A few of these posts are held in place with a dollop of glue. The cover itself is NOT glued around the edges. This made disassembly quite simple.
I simply drilled out the glue on the four holes the on the back side of the switch and was then able to pry open the cover. Once opened, the problem was obvious: 100,000 cycles (my estimate of how many times we've used it since 1994) had left the almost one dozen contacts on the various switches (there are about six separate switches inside) pitted and blackened, and the contacts were no longer able to conduct electricity. There are no springs inside, so unlike repairing some switches, where the whole thing springs apart the moment you open it, this item is totally stable and completely simple to deal with. There are a few posts inside which hold the copper pieces in place, and you would be well advised to take a picture as soon as you open it up, so that you can get the pieces on the correct side of each support post. You'll figure it out eventually, even if you don't do this (which I forgot to do), but it will save time and also boost your confidence to have the picture.
I didn't bother to disconnect any of the spade lugs (which speeds things up) and was able to do all my work with the unit just sitting in midair, supported by the wires, after I had unscrewed the four mounting screws.
To refurbish it, I lifted out, one at a time, each of the seven contacts and then cleaned them with a Dremel wire brush. Following that I dressed them (flattened them out) with a standard ignition file (like we used to use on distributor contacts). I used compressed air to make sure all metal shavings were removed from the interior. I reassembled the switch and used some "extra-strength" hot glue to tack the cover in place, and to replace the glue that I had drilled out.
I then put it back in service, making sure to pay attention to the adjustment to get the door closed snugly.
Everything is working now, and I expect that I will no longer be blowing fuses.
So, it was a $0 fix. It took awhile because I was being slow and cautious, but if I had to do it again, I think I could do the whole thing in under fifteen minutes.
I thought others who might come up against this same problem (of no longer being able to purchase a replacement interlock switch) might find it useful to know that, at least with the one on my Amana, it can be repaired, and it isn't very difficult.
Related Models
Admiral RSWA228AAE REF - SXS/I&W
Admiral RSWA228AAM REF - SXS/I&W
Admiral RSWA248AAE REF - SXS/I&W
Admiral RSWA248AAM REF - SXS/I&W
Admiral RSWA278AAE REF - SXS/I&W
Admiral RSWA278AAM REF - SXS/I&W
Frigidaire RT114GCD1 Wwh(v1) / Top Mount Refrigerator
Frigidaire RT114GCD2 Wwh(v2) / Top Mount Refrigerator
Frigidaire RT114GCD3 Wwh(v3) / Top Mount Refrigerator
Frigidaire RT114GCD5 Wwh(v4) / Top Mount Refrigerator
Frigidaire RT114GCH1 Wwh(v5) / Top Mount Refrigerator
Frigidaire RT114GCH2 Wwh(v6) / Top Mount Refrigerator
Frigidaire RT114GCH3 Wwh(v7) / Top Mount Refrigerator
Frigidaire RT114GCH5 Wwh(v8) / Top Mount Refrigerator
Frigidaire RT114GCV1 Wwh(v9) / Top Mount Refrigerator
Frigidaire RT114GCV2 Wwh(v10) / Top Mount Refrigerator
Frigidaire RT114GCV3 Wwh(v11) / Top Mount Refrigerator
Frigidaire RT114GCV5 Wwh(v12) / Top Mount Refrigerator
Frigidaire RT114GCW1 Wwh(v13) / Top Mount Refrigerator
Frigidaire RT114GCW2 Wwh(v14) / Top Mount Refrigerator
Frigidaire RT114GCW3 Wwh(v15) / Top Mount Refrigerator
Frigidaire RT114GCW5 Wwh(v16) / Top Mount Refrigerator
Frigidaire RT114GLD5 Wwh(v17) / Top Mount Refrigerator
Frigidaire RT114GLH5 Wwh(v18) / Top Mount Refrigerator
Frigidaire RT114GLV5 Wwh(v19) / Top Mount Refrigerator
Frigidaire RT114GLW5 Wwh(v20) / Top Mount Refrigerator
Frigidaire RT114LCD1 Wwh(v3) / Top Mount Refrigerator
Frigidaire RT114LCD2 Wwh(v3) / Top Mount Refrigerator
Frigidaire RT114LCD3 Wwh(v3) / Top Mount Refrigerator
Frigidaire RT114LCD4 Wwh(v3) / Top Mount Refrigerator
Frigidaire RT114LCD5 Wwh(v2) / Top Mount Refrigerator
Frigidaire RT114LCD6 Wwh(v2) / Top Mount Refrigerator
Frigidaire RT114LCD7 Wwh(v2) / Top Mount Refrigerator
Frigidaire RT114LCH1 Wwh(v2) / Top Mount Refrigerator
Frigidaire RT114LCH2 Wwh(v2) / Top Mount Refrigerator
Frigidaire RT114LCH3 Wwh(v2) / Top Mount Refrigerator
Frigidaire RT114LCH4 Wwh(v2) / Top Mount Refrigerator
Frigidaire RT114LCW1 Wwh(v1) / Top Mount Refrigerator
Frigidaire RT114LCW2 Wwh(v1) / Top Mount Refrigerator
Frigidaire RT114LCW3 Wwh(v1) / Top Mount Refrigerator
Frigidaire RT114LCW4 Wwh(v1) / Top Mount Refrigerator
Frigidaire RT114LCW5 Wwh(v1) / Top Mount Refrigerator
Frigidaire RT114LCW6 Wwh(v1) / Top Mount Refrigerator
Frigidaire RT114LCW7 Wwh(v1) / Top Mount Refrigerator
Frigidaire RT114LLD1 Wwh(v6) / Top Mount Refrigerator
Frigidaire RT114LLD2 Wwh(v6) / Top Mount Refrigerator
Frigidaire RT114LLD3 Wwh(v6) / Top Mount Refrigerator
Frigidaire RT114LLD4 Wwh(v6) / Top Mount Refrigerator
Frigidaire RT114LLD5 Wwh(v4) / Top Mount Refrigerator
Frigidaire RT114LLD6 Wwh(v4) / Top Mount Refrigerator
Frigidaire RT114LLD7 Wwh(v4) / Top Mount Refrigerator
Frigidaire RT114LLH1 Wwh(v5) / Top Mount Refrigerator
Frigidaire RT114LLH2 Wwh(v5) / Top Mount Refrigerator
Frigidaire RT114LLH3 Wwh(v5) / Top Mount Refrigerator
Frigidaire RT114LLH4 Wwh(v5) / Top Mount Refrigerator
Frigidaire RT114LLW1 Wwh(v4) / Top Mount Refrigerator
Frigidaire RT114LLW2 Wwh(v4) / Top Mount Refrigerator
Frigidaire RT114LLW3 Wwh(v4) / Top Mount Refrigerator
Frigidaire RT114LLW4 Wwh(v4) / Top Mount Refrigerator
Frigidaire RT114LLW5 Wwh(v3) / Top Mount Refrigerator
Frigidaire RT114LLW6 Wwh(v3) / Top Mount Refrigerator
Frigidaire RT114LLW7 Wwh(v3) / Top Mount Refrigerator
Frigidaire RT11F2WRJE Gib(v1) / Refrigerator
Frigidaire RT11F2WVJA Gib(v1) / Refrigerator
Frigidaire RT11F2WVJB Gib(v1) / Refrigerator
Frigidaire RT11F2WVJC Gib(v1) / Refrigerator
Frigidaire RT120GCD1 Wwh(v5) / Top Mount Refrigerator
Frigidaire RT120GCD2 Wwh(v10) / Top Mount Refrigerator
Frigidaire RT120GCD3 Wwh(v15) / Top Mount Refrigerator
Frigidaire RT120GCD4 Wwh(v5) / Top Mount Refrigerator
Frigidaire RT120GCF1 Wwh(v4) / Top Mount Refrigerator
Frigidaire RT120GCF2 Wwh(v9) / Top Mount Refrigerator
Frigidaire RT120GCF3 Wwh(v14) / Top Mount Refrigerator
Frigidaire RT120GCF4 Wwh(v4) / Top Mount Refrigerator
Frigidaire RT120GCH1 Wwh(v3) / Top Mount Refrigerator
Frigidaire RT120GCH2 Wwh(v8) / Top Mount Refrigerator
Frigidaire RT120GCH3 Wwh(v13) / Top Mount Refrigerator
Frigidaire RT120GCH4 Wwh(v3) / Top Mount Refrigerator
Frigidaire RT120GCV1 Wwh(v2) / Top Mount Refrigerator
Frigidaire RT120GCV2 Wwh(v7) / Top Mount Refrigerator
Frigidaire RT120GCV3 Wwh(v12) / Top Mount Refrigerator
Frigidaire RT120GCV4 Wwh(v2) / Top Mount Refrigerator
Frigidaire RT120GCW1 Wwh(v1) / Top Mount Refrigerator
Frigidaire RT120GCW2 Wwh(v6) / Top Mount Refrigerator
Frigidaire RT120GCW3 Wwh(v11) / Top Mount Refrigerator
Frigidaire RT120GCW4 Wwh(v1) / Top Mount Refrigerator
Frigidaire RT120GLD4 Wwh(v10) / Top Mount Refrigerator
Frigidaire RT120GLF4 Wwh(v9) / Top Mount Refrigerator
Frigidaire RT120GLH4 Wwh(v8) / Top Mount Refrigerator
Frigidaire RT120GLV4 Wwh(v7) / Top Mount Refrigerator
Frigidaire RT120GLW4 Wwh(v6) / Top Mount Refrigerator
Frigidaire RT120LCD0 Wwh(v5) / Top Mount Refrigerator
Frigidaire RT120LCF0 Wwh(v4) / Top Mount Refrigerator
Frigidaire RT120LCH0 Wwh(v3) / Top Mount Refrigerator
Frigidaire RT120LCV0 Wwh(v2) / Top Mount Refrigerator
Frigidaire RT120LCW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire RT120LLD0 Wwh(v10) / Top Mount Refrigerator
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Door interlock? PJRedmond Dishwasher Repair 0 08-12-2015 04:40 AM
interlock door switch zurkster Microwave Repair 0 01-29-2011 05:09 PM
door interlock acess bigtruck57 Washer Repair 3 05-25-2009 08:16 AM
Interlock door switch repair mgatto Microwave Repair 3 04-07-2009 02:40 PM
Is it the door interlock switch? DS@home Dishwasher Repair 0 09-23-2008 09:31 PM
