Discuss
Is it safe to replace a microwave outer door
 in
Microwave Repair
In replacing the springs in this unit, my friend dropped the outer door and broke the glass. He had really
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Is it safe to replace a microwave outer door
  #1 (permalink)
Old 01-21-2017, 07:10 AM
Junior Member
ragmop is on a distinguished road
Default Is it safe to replace a microwave outer door
Model Number: KEMC378KSS0   Brand: Kitchen Aid   Age: More than 10 years
In replacing the springs in this unit, my friend dropped the outer door and broke the glass. He had really taken off a lot of parts that didn't need to be removed - the door frame, the side fillers, the control panel vent, the oven door vent.
I have purchased a new outer door and we replaced everything and it all looks fine.
My question is whether or not I should hire a repair person with a microwave meter to check if the unit is OK before I actually use it.
Thanks for the info.
Related Models
Whirlpool KEMC378KSS0 OVEN WITH MICROWAVE
Whirlpool KEMC378KSS01 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KSS02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KSS03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KSS04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KWH0 OVEN WITH MICROWAVE
Whirlpool KEMC378KWH01 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KWH02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KWH03 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMC378KWH04 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION LOWER MICROWAVE CONVECTION
Whirlpool KEMI300SBL0 BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI300SBL1 BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI300VBL0 BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI300VBL1 BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI300VBL2 BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI300VBL3 BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI300VBL4 BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI300VBL5 BUILT-IN OVEN WITH MICROWAVE
KitchenAid KEMI300WBL0 ELEC. BUILT-IN OVEN / MICROWAVE OVEN
Whirlpool KEMI300WBL1 ELEC BUILT-IN OVEN / MICROWAVE OVEN
Whirlpool KEMI300WBL2 ELEC BUILT IN OVEN / MICROWAVE OVEN
Whirlpool KEMI300WBL3 30" BUILT-IN COMBINATION OVEN
Whirlpool KEMI301BWH0 30" ELECTRIC BUILT-IN OVEN WITH MICROWAVE
Whirlpool KEMI301GBL0 30" BUILT-IN ELECTRIC OVEN
Whirlpool KEMI301GWH0 30" BUILT-IN ELECTRIC OVEN
Whirlpool KEMI371BBL0 27" BUILT-IN OVEN W/MICROWAVE
Whirlpool KEMI371BBL1 27" BUILT-IN OVEN
Whirlpool KEMI371BBL2 27" BUILT-IN OVEN
Whirlpool KEMI371BWH0 27" BUILT-IN OVEN W/MICROWAVE
Whirlpool KEMI371BWH1 27" BUILT-IN OVEN
Whirlpool KEMI371BWH2 27" BUILT-IN OVEN
Whirlpool KEMI371GBL0 27" BUILT-IN ELECTRIC WALL OVEN
Whirlpool KEMI371GWH0 27" BUILT-IN ELECTRIC WALL OVEN
Whirlpool KEMI371SBL0 Ranges, Electric*
Whirlpool KEMI371TBL0 Ranges, Electric*
Whirlpool KEMI371TBL1 ELECTRIC RANGE
Whirlpool KEMI371TBL2 ELECTRIC RANGE
Whirlpool KEMI371TBL3 Ranges, Electric*
Whirlpool KEMI371XBL0 Ranges, Electric*
Whirlpool KEMI371XBL1 Ranges, Electric*
Whirlpool KEMI371XBL2 Ranges, Electric*
Whirlpool KEMI371YWH0 Ranges, Electric*
Whirlpool KEMS306BAL0 BUILT IN OVEN & MICROWAVE OVEN
Whirlpool KEMS306BAL1 BUILT-IN OVEN/MICROWAVE
Whirlpool KEMS306BAL2 BUILT-IN-OVEN/MICROWAVE
Whirlpool KEMS306BAL3 BUILT-IN-OVEN/MICROWAVE
Whirlpool KEMS306BBL0 BUILT IN OVEN & MICROWAVE OVEN
Whirlpool KEMS306BBL1 BUILT-IN OVEN/MICROWAVE
Whirlpool KEMS306BBL2 BUILT-IN-OVEN/MICROWAVE
Whirlpool KEMS306BBL3 BUILT-IN-OVEN/MICROWAVE
Whirlpool KEMS306BWH0 BUILT IN OVEN & MICROWAVE OVEN
Whirlpool KEMS306BWH1 BUILT-IN OVEN/MICROWAVE
Whirlpool KEMS306BWH2 BUILT-IN-OVEN/MICROWAVE
Whirlpool KEMS306BWH3 BUILT-IN-OVEN/MICROWAVE
Whirlpool KEMS306XAL0
Whirlpool KEMS306XAL1
Whirlpool KEMS306XAL3 ELECTRIC WALL OVEN / MICROWAVE COMBINATION
Whirlpool KEMS306XAL4 30" OVEN / CONVECTION MICROWAVE
Whirlpool KEMS306XAL5 30" ELECTRIC BUILT-IN COMBINATION OVEN
Whirlpool KEMS306XAL6 30" SELF-CLEAN OVEN WITH CONVECTION MICROWAVE
Whirlpool KEMS306XBL0 ELEC BUILT-IN OVEN / MICROWAVE OVEN
Whirlpool KEMS306XBL1 ELEC BUILT-IN OVEN / MICROWAVE OVEN
Whirlpool KEMS306XBL2 ELECTRIC BUILT-IN COMBINATION OVEN
Whirlpool KEMS306XBL3 ELECTRIC WALL OVEN / MICROWAVE COMBINATION
Whirlpool KEMS306XBL4 30" OVEN / CONVECTION MICROWAVE
Whirlpool KEMS306XBL5 30" ELECTRIC BUILT-IN COMBINATION OVEN
Whirlpool KEMS306XBL6 30" SELF-CLEAN OVEN WITH CONVECTION MICROWAVE
Whirlpool KEMS306XWH0 Ranges, Electric*
Whirlpool KEMS306XWH1 Ranges, Electric*
Whirlpool KEMS306XWH2 ELECTRIC BUILT-IN COMBINATION OVEN
Whirlpool KEMS306XWH3 ELECTRIC WALL OVEN / MICROWAVE COMBINATION
Whirlpool KEMS306XWH4 30" OVEN / CONVECTION MICROWAVE
Whirlpool KEMS306XWH5 30" ELECTRIC BUILT-IN COMBINATION OVEN
Whirlpool KEMS306XWH6 30" SELF-CLEAN OVEN WITH CONVECTION MICROWAVE
Whirlpool KEMS307DAL1 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEMS307DAL2 30" BUILTIN ELECTRIC DOUBLE OVEN
Whirlpool KEMS307DAL4 30" BUILT-IN ELECTRIC OVEN/MW
Whirlpool KEMS307DAL6 BUILT - IN ELECTRIC OVEN
Whirlpool KEMS307DBL1 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEMS307DBL2 30" BUILTIN ELECTRIC DOUBLE OVEN
Whirlpool KEMS307DBL4 30" BUILT-IN ELECTRIC OVEN/MW
Whirlpool KEMS307DBL6 BUILT - IN ELECTRIC OVEN
Whirlpool KEMS307DBS2 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEMS307DBS4 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEMS307DBS6 BUILT - IN ELECTRIC OVEN
Whirlpool KEMS307DBT6 BUILT - IN ELECTRIC OVEN
Whirlpool KEMS307DWH1 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEMS307DWH2 30" BUILTIN ELECTRIC DOUBLE OVEN
Whirlpool KEMS307DWH4 30" BUILT-IN ELECTRIC OVEN/MW
Whirlpool KEMS307DWH6 BUILT - IN ELECTRIC OVEN
Whirlpool KEMS307GAL0 BUILT-IN ELECTRIC OVEN/MW
Whirlpool KEMS307GAL1 ELECTRIC OVEN/MW COMBO
Whirlpool KEMS307GAL2 30" BUILT IN OVEN/MW
Whirlpool KEMS307GBL0 BUILT-IN ELECTRIC OVEN/MW
Whirlpool KEMS307GBL1 ELECTRIC OVEN/MW COMBO
Whirlpool KEMS307GBL2 30" BUILT IN OVEN/MW
Whirlpool KEMS307GBL3 BUILT-IN OVEN, ELECTRIC
Whirlpool KEMS307GBL4 OVEN/ELECTRIC MICROWAVE
Whirlpool KEMS307GBS0 BUILT-IN ELECTRIC OVEN
Whirlpool KEMS307GBS1 ELECTRIC OVEN/MW COMBO
Whirlpool KEMS307GBS2 30" BUILT IN OVEN/MW
Whirlpool KEMS307GBS3 BUILT-IN OVEN, ELECTRIC
Whirlpool KEMS307GBS4 OVEN/ELECTRIC MICROWAVE
Whirlpool KEMS307GBT0 BUILT-IN ELECTRIC OVEN/MW
Whirlpool KEMS307GBT1 ELECTRIC OVEN/MW COMBO
Whirlpool KEMS307GBT2 30" BUILT IN OVEN/MW
Whirlpool KEMS307GBT3 BUILT-IN OVEN, ELECTRIC
Whirlpool KEMS307GBT4 OVEN/ELECTRIC MICROWAVE
Whirlpool KEMS307GWH0 BUILT-IN ELECTRIC OVEN/MW
Whirlpool KEMS307GWH1 ELECTRIC OVEN/MW COMBO
Whirlpool KEMS307GWH2 30" BUILT IN OVEN/MW
Whirlpool KEMS307GWH3 BUILT-IN OVEN, ELECTRIC
Whirlpool KEMS307GWH4 OVEN/ELECTRIC MICROWAVE
Whirlpool KEMS308GBL0 BUILT-IN ELECTRIC OVEN/MW
Whirlpool KEMS308GBL1 ELECTRIC OVEN/MW COMBO
Whirlpool KEMS308GBL2 OVEN/MW
Whirlpool KEMS308GBL3 BUILT-IN OVEN, ELECTRIC
Whirlpool KEMS308GSS0 BUILT-IN ELECTRIC OVEN/MW
Whirlpool KEMS308GSS1 OVEN/MW
Whirlpool KEMS308GSS2 BUILT-IN OVEN, ELECTRIC W/MICROWAVE
  #2 (permalink)
Old 01-21-2017, 06:01 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
As long as the door is assembled correctly and all the parts are in it, everything should be fine.
If the door closes easily, its square with the frame, and there are no large gaps between the door and the microwave body it should be OK.
The biggest mistake you could make would be to remove that "screen" inside the door. Thats what keeps the radio wave energy inside the MW. As long as the door gaps are smaller or about the same size as the holes in the screen, it should safe enough.
That said, microwave energy is very weak after more than a couple of feet. So unless you stand right next to the MW while its cooking, its very safe.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How to Replace Outer Door Handle sbiehler Microwave Repair 1 07-15-2015 03:26 PM
Replace outer door Mabrell Microwave Repair 0 02-01-2015 09:12 AM
How to replace outer glass door cheryllove79@hotmail.com Oven Repair (including Ranges and Cooktops) 0 05-04-2013 10:23 AM
Replace Microwave Outer Door Glass Panel ahovde Microwave Repair 0 11-01-2010 07:22 PM
Is microwave safe with hole in inner door? dpepsi Microwave Repair 0 10-29-2010 02:21 PM
