Discuss
shorted out the MW control panel
 in
Microwave Repair
I had the light bulb blow out, I then removed the glass light bulb cover and found the halogen bulb
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » shorted out the MW control panel
  #1 (permalink)
Old 01-11-2017, 01:50 PM
Junior Member
artmra is on a distinguished road
Default shorted out the MW control panel
Model Number: 721.80822   Brand: Kenmore   Age: More than 10 years
I had the light bulb blow out, I then removed the glass light bulb cover and found the halogen bulb had exploded, I cleaned up all the broken glass and I then attempted to remove that was left of the bulb socket and the two metal prongs.
MY ERROR was that I did NOT unplug the MW and touched both prongs with the needle nose pliers I used to try and remove the bulb socket. There was a flash and ALL of the digital displays have gone blank.
Have I fried the electronics in the MW ??? Any suggestions of what to do now ??? The circuit breaker did NO close and that appears to be okay. If I replace the bulb will that complete the electrical connection ??? Is there an internal fuse somewhere within the MW ???
Sears has said their service call charge to repair the MW is $ 249.00 and if it needs parts, that is extra. If I chose not to have it repaired I will still be billed the $ 249.00.
At plus ten years old should I just go get a NEW MW ???
The other problem I have is that ALL our appliances are bisque in color and there are not a lot of options out there now in the color.
Related Models
Kenmore 72160102000 MICROWAVE OVEN
Kenmore 72160109000 MICROWAVE OVEN
Kenmore 72160282000 MICROWAVE OVEN
Kenmore 72160289000 MICROWAVE OVEN
Kenmore 72160483000 MICROWAVE
Kenmore 72161102100 MICROWAVE
Kenmore 72161109100 MICROWAVE
Kenmore 72161282000 MICROWAVE
Kenmore 72161282100 MICROWAVE
Kenmore 72161283100 MICROWAVE
Kenmore 72161289000 MICROWAVE
Kenmore 72161289100 MICROWAVE
Kenmore 72162002200 MICROWAVE
Kenmore 72162102200 MICROWAVE
Kenmore 72162102201 MICROWAVE
Kenmore 72162109200 MICROWAVE
Kenmore 72162212200 MICROWAVE
Kenmore 72162219200 MICROWAVE
Kenmore 72162219201 MICROWAVE
Kenmore 72162222300 MICROWAVE
Kenmore 72162222301 MICROWAVE
Kenmore 72162223200 MICROWAVE
Kenmore 72162229300 MICROWAVE
Kenmore 72162252200 MICROWAVE
Kenmore 72162252201 MICROWAVE OVEN
Kenmore 72162253200 MICROWAVE
Kenmore 72162253201 MICROWAVE OVEN
Kenmore 72162259200 MICROWAVE
Kenmore 72162259201 MICROWAVE OVEN
Kenmore 72162292200 MICROWAVE
Kenmore 72162299200 MICROWAVE
Kenmore 72162342200 MICROWAVE
Kenmore 72162342201 MICROWAVE
Kenmore 72162342202 MICROWAVE
Kenmore 72162342203 MICROWAVE
Kenmore 72162344203 MICROWAVE
Kenmore 72162344300 MICROWAVE
Kenmore 72162344301 MICROWAVE
Kenmore 72162349200 MICROWAVE
Kenmore 72162349202 MICROWAVE
Kenmore 72162349203 MICROWAVE
Kenmore 72162362200 MICROWAVE
Kenmore 72162364200 MICROWAVE
Kenmore 72162365200 MICROWAVE
Kenmore 72162369200 MICROWAVE
Kenmore 72162369201 MICROWAVE
Kenmore 72162462200 MICROWAVE
Kenmore 72162463200 MICROWAVE
Kenmore 72162464200 MICROWAVE
Kenmore 72162469200 MICROWAVE
Kenmore 72162622200 MICROWAVE HOOD COMBO
Kenmore 72162624200 MICROWAVE HOOD COMBO
Kenmore 72162629200 MICROWAVE HOOD COMBO
Kenmore 72162642200 MICROWAVE HOOD COMBO
Kenmore 72162643200 MICROWAVE HOOD COMBO
Kenmore 72162644200 MICROWAVE HOOD COMBO
Kenmore 72162649200 MICROWAVE HOOD COMBO
Kenmore 72162752100 MICROWAVE
Kenmore 72162752200 MICROWAVE
Kenmore 72162759200 MICROWAVE
Kenmore 72162772100 MICROWAVE
Kenmore 72162772200 MICROWAVE
Kenmore 72162774100 MICROWAVE
Kenmore 72162774200 MICROWAVE
Kenmore 72162779100 MICROWAVE
Kenmore 72162779200 MICROWAVE
Kenmore 72163102300 MICROWAVE OVEN
Kenmore 72163109300 MICROWAVE OVEN
Kenmore 72163252300 MICROWAVE
Kenmore 72163252301 MICROWAVE
Kenmore 72163259300 MICROWAVE
Kenmore 72163259301 MICROWAVE
Kenmore 72163263300 MICROWAVE
Kenmore 72163263301 MICROWAVE
Kenmore 72163292300 MICROWAVE
Kenmore 72163292301 MICROWAVE
Kenmore 72163292303 MICROWAVE
Kenmore 72163293301 MICROWAVE
Kenmore 72163299300 MICROWAVE
Kenmore 72163299301 MICROWAVE
Kenmore 72163299303 MICROWAVE
Kenmore 72163352300 MICROWAVE
Kenmore 72163359300 MICROWAVE
Kenmore 72163652300 MICROWAVE HOOD COMBO
Kenmore 72163652301 MICROWAVE
Kenmore 72163653300 MICROWAVE HOOD COMBO
Kenmore 72163653301 MICROWAVE
Kenmore 72163654300 MICROWAVE HOOD COMBO
Kenmore 72163654301 MICROWAVE
Kenmore 72163659300 MICROWAVE HOOD COMBO
Kenmore 72163659301 MICROWAVE
Kenmore 72163662300 MICROWAVE HOOD COMBO
Kenmore 72163663300 MICROWAVE HOOD COMBO
Kenmore 72163664300 MICROWAVE HOOD COMBO
Kenmore 72163669300 MICROWAVE HOOD COMBO
Kenmore 72163682300 MICROWAVE HOOD COMBO
Kenmore 72163683300 MICROWAVE HOOD COMBO
Kenmore 72163684300 MICROWAVE HOOD COMBO
Kenmore 72163689300 MICROWAVE HOOD COMBO
Kenmore 72163762300 MICROWAVE HOOD COMBO
Kenmore 72163763300 MICROWAVE HOOD COMBO
Kenmore 72163764300 MICROWAVE HOOD COMBO
Kenmore 72163769300 MICROWAVE HOOD COMBO
Kenmore 72163992300 MICROWAVE
Kenmore 72163992302 MICROWAVE
Kenmore 72163992303 MICROWAVE
Kenmore 72163993300 MICROWAVE
Kenmore 72163993301 MICROWAVE
Kenmore 72163993302 MICROWAVE
Kenmore 72163993303 MICROWAVE
Kenmore 72163999300 MICROWAVE
Kenmore 72163999301 MICROWAVE
Kenmore 72163999302 MICROWAVE
Kenmore 72163999303 MICROWAVE
Kenmore 72164002300 MICROWAVE
Kenmore 72164002301 MICROWAVE
Kenmore 72164282300 MICROWAVE
Kenmore 72164282301 MICROWAVE
Kenmore 72164283300 MICROWAVE
Kenmore 72164283301 MICROWAVE
  #2 (permalink)
Old 01-12-2017, 02:25 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Putting a new bulb in probably won't do anything.
Yes there is a fuse in the microwave, its probably blown from the short.
I can tell you this: changing the bulb live on any of these modern microwaves, ovens, and refrigerators can damage the main board or kill it. Always shut the power off.
Is it going to cost more to repair it than the MW is worth? Probably. It depends on how much stuff is damaged and if the parts are even available.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Control Board Shorted - why? sfengr Dishwasher Repair 0 02-22-2015 02:41 PM
GE gas dryer control panel fails (dead/shorted) dennyh289 Dryer Repair 0 01-29-2012 11:45 PM
shorted control panel? junilim6264 Oven Repair (including Ranges and Cooktops) 0 01-25-2012 05:25 PM
Ref. Water Control Valve Question - Shorted? teddbere Refrigerator & Freezer Repair 3 03-31-2011 02:22 PM
Bosch SHU5315 UC12 control module shorted tbosch Dishwasher Repair 5 02-20-2009 01:07 AM
