Discuss
GE Microwave JVM1440WH01 - no heat and no turn table
 in
Microwave Repair
Hi, I have GE microwave JVM1440WH01. Following is the history of the problem... It started with fan running when you
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » GE Microwave JVM1440WH01 - no heat and no turn table
  #1 (permalink)
Old 12-01-2016, 08:11 AM
Junior Member
titaniclocket6 is on a distinguished road
Default GE Microwave JVM1440WH01 - no heat and no turn table
Model Number: JVM1440WH01   Brand: GE   Age: 5 - 10 years
It started with fan running when you simply open the door Microwave still used to work no other problem
After sometime the inline fuse blue-off I replaced that couple of times
Found Bottom Door Switch was faulty replaced it and it worked for couple of days
Now there is power but no heat and no turn table, no humming sound.
I have checked following parts and all seems correct
Diode, Capacitor, Magenatron, Fuse, Door Switches
MICROWAVE THERMOSTAT CUT-OUT WB27X10195 it has zero resistance and closed by default, however MICROWAVE HOOD THERMOSAT WB27X10194 is open by default (is this correct?). I assumed it should be like THERMOSTAT CUT-OUT WB27X10195 but I bought the new one and it is also by default open. Now I am not sure what part is faulty. I will appreciate your guidance.
The GE microwave parts details can be found https://www.geapplianceparts.com/sto.../0/0/MICROWAVE
Related Models
General Electric JVM1440WH01 Counter top microwave
General Electric JVM1440WH02 Counter top microwave
General Electric JVM1440WH03 Counter top microwave
General Electric JVM1440WH04 Counter top microwave
General Electric JVM1441BD001 Counter top microwave
General Electric JVM1441BD002 Counter top microwave
General Electric JVM1441BD003 Counter top microwave
General Electric JVM1441BH01 Counter top microwave
General Electric JVM1441BH02 Counter top microwave
General Electric JVM1441BH03 Counter top microwave
General Electric JVM1441BH04 Counter top microwave
General Electric JVM1441CJ01 Counter top microwave
General Electric JVM1441CJ02 Counter top microwave
General Electric JVM1441CJ03 Counter top microwave
General Electric JVM1441CJ04 Counter top microwave
General Electric JVM1441SH001 Counter top microwave
General Electric JVM1441SH01 Counter top microwave
General Electric JVM1441SH02 Counter top microwave
General Electric JVM1441SH03 Counter top microwave
General Electric JVM1441WD001 Counter top microwave
General Electric JVM1441WD002 Counter top microwave
General Electric JVM1441WD003 Counter top microwave
General Electric JVM1441WH01 Counter top microwave
General Electric JVM1441WH02 Counter top microwave
General Electric JVM1441WH03 Counter top microwave
General Electric JVM1441WH04 Counter top microwave
General Electric JVM1442AA01 Counter top microwave
General Electric JVM1442BA01 Counter top microwave
General Electric JVM1442WA01 Counter top microwave
General Electric JVM1443BK01 Counter top microwave
General Electric JVM1443BK02 Counter top microwave
General Electric JVM1443LK01 Counter top microwave
General Electric JVM1443LK02 Counter top microwave
General Electric JVM1443WK01 Counter top microwave
General Electric JVM1443WK02 Counter top microwave
General Electric JVM1450AA01 Counter top microwave
General Electric JVM1450BA01 Counter top microwave
General Electric JVM1450BC001 Counter top microwave
General Electric JVM1450BC002 Counter top microwave
General Electric JVM1450WA01 Counter top microwave
General Electric JVM1450WC001 Counter top microwave
General Electric JVM1450WC002 Counter top microwave
General Electric JVM1451AA01 Counter top microwave
General Electric JVM1451BA01 Counter top microwave
General Electric JVM1451WA01 Counter top microwave
General Electric JVM1460AA01 Counter top microwave
General Electric JVM1460BA01 Counter top microwave
General Electric JVM1460SA01 Counter top microwave
General Electric JVM1460WA01 Counter top microwave
General Electric JVM1490BD002 Counter top microwave
General Electric JVM1490BD003 Counter top microwave
General Electric JVM1490BD03 Counter top microwave
General Electric JVM1490BH01 Counter top microwave
General Electric JVM1490BH02 Counter top microwave
General Electric JVM1490CD002 Counter top microwave
General Electric JVM1490CD003 Counter top microwave
General Electric JVM1490CD03 Counter top microwave
General Electric JVM1490CH01 Counter top microwave
General Electric JVM1490CH02 Counter top microwave
General Electric JVM1490SD002 Counter top microwave
General Electric JVM1490SD003 Counter top microwave
General Electric JVM1490SD03 Counter top microwave
General Electric JVM1490SH01 Counter top microwave
General Electric JVM1490SH02 Counter top microwave
General Electric JVM1490WD002 Counter top microwave
General Electric JVM1490WD003 Counter top microwave
General Electric JVM1490WD03 Counter top microwave
General Electric JVM1490WH01 Counter top microwave
General Electric JVM1490WH02 Counter top microwave
General Electric JVM150001 Hi-low range
General Electric JVM150G01 Hi-low range
General Electric JVM150H01 Hi-low range
General Electric JVM150H02 Hi-low range
General Electric JVM150J01 Counter top microwave
General Electric JVM150J02 Hi-low range
General Electric JVM150J03 Hi-low range
General Electric JVM150J04 Hi-low range
General Electric JVM150K01 Counter top microwave
General Electric JVM150K02 Counter top microwave
General Electric JVM150K03 Counter top microwave
General Electric JVM150K04 Counter top microwave
General Electric JVM152G01 Hi-low range
General Electric JVM152H01 Hi-low range
General Electric JVM152H02 Hi-low range
General Electric JVM152J01 Hi-low range
General Electric JVM152J02 Hi-low range
General Electric JVM152J03 Hi-low range
General Electric JVM152J04 Counter top microwave
General Electric JVM152K01 Counter top microwave
General Electric JVM152K02 Counter top microwave
General Electric JVM152K03 Counter top microwave
General Electric JVM152K04 Counter top microwave
General Electric JVM1530DM1BB Counter top microwave
General Electric JVM1530DM1WW Counter top microwave
General Electric JVM1533BD05 Counter top microwave
General Electric JVM1533WD05 Counter top microwave
General Electric JVM153K01 Counter top microwave
General Electric JVM153K02 Counter top microwave
General Electric JVM1540DM1BB Counter top microwave
General Electric JVM1540DM1CC Counter top microwave
General Electric JVM1540DM1WW Counter top microwave
General Electric JVM1540DM2BB MICROWAVE
General Electric JVM1540DM2CC MICROWAVE
General Electric JVM1540DM2WW MICROWAVE
General Electric JVM1540DM3BB MICROWAVE
General Electric JVM1540DM3CC MICROWAVE
General Electric JVM1540DM3WW MICROWAVE
General Electric JVM1540DM4BB MICROWAVE
General Electric JVM1540DM4CC MICROWAVE
General Electric JVM1540DM4WW MICROWAVE
General Electric JVM1540DM5BB MICROWAVE
General Electric JVM1540DM5CC MICROWAVE
General Electric JVM1540DM5WW MICROWAVE
General Electric JVM1540DN1BB MICROWAVE
General Electric JVM1540DN1CC MICROWAVE
General Electric JVM1540DN1WW MICROWAVE
General Electric JVM1540DN2BB MICROWAVE
General Electric JVM1540DN2CC MICROWAVE
General Electric JVM1540DN2WW MICROWAVE
General Electric JVM1540DP1BB MICROWAVE
  #2 (permalink)
Old 12-01-2016, 08:37 AM
Junior Member
Sbond005 is on a distinguished road
Default
Very interested to see what answers pop up. Having the exact same issue on my GE Profile PVM1790SR1SS and everything I saw pointed to the lower door switch, ended up just replacing all 3 switches and still having the same issue.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
microwave turn table john goddard Microwave Repair 0 01-04-2015 02:49 PM
GE Microwave turn table not working bgrotenhuis Microwave Repair 0 05-12-2014 10:03 PM
GE Microwave turn table and fan don't work VmanLir Microwave Repair 0 10-09-2010 03:20 PM
Sharp-table won't turn, doesn't microwave chanhall Microwave Repair 1 10-17-2009 02:49 PM
GE Turn Table Microwave, Above Oven u305167 Microwave Repair 0 08-22-2009 02:01 PM
