Discuss
Sharp microwave hood lights don't work
 in
Microwave Repair
I have a Sharp R-1480 over-the-range microwave. It works great with the exception that several years ago the hood lights
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Sharp microwave hood lights don't work
  #1 (permalink)
Old 11-22-2016, 02:48 PM
Junior Member
br647257 is on a distinguished road
Default Sharp microwave hood lights don't work
Model Number: R-1480   Brand: -other-   Age: More than 10 years
I have a Sharp R-1480 over-the-range microwave. It works great with the exception that several years ago the hood lights stopped working even after replacing the light bulbs. I decided to try to fix the issue which I thought was related to the sockets. Luckily the supplier mailed the wrong part. Before reordering the part, I decided to check the wiring for power. Using a voltage tester, I touched the leads to the wires connected to the socket and the tester showed there was power. I got the same result when touching the leads to the metal connecters inside the socket. A friend suggested I might have a contact issue, so I disconnected the plug from the outlet and the wires from the sockets, and using a flat-head screwdriver proceeded to retract the metal contacts located at the top and side of the socket. After reconnecting and securing the sockets, I installed brand new GE 25w T7 Bulb Type E17 Base light bulbs. I plugged the microwave back into the socket and pressed the "Work Light" and "Night Light" keys on the touch pad and nothing. I rechecked for power using the voltage tester and now there is no power to either sockets. The bulbs did not burn out and the microwave continues to work as before. Based on my very limited knowledge, if I had to guess I would have to assume that I blew a fuse.
Question 1) Is my assumption correct? If yes, then
Question 2) I'm assuming I used the incorrect light bulb. The manual only says to use a 30w incadescent light bulb. I did encounter a slight resistance when screwing in the bulb, and figured it was related to getting past the metal contacts I retracted. There was nothing to indicate that I was using the incorrect bulb. I had no issues securing the bulb. What bulb should I have used?
Question 3) If I did blow a fuse, where is it located? How do I access it? What size/type fuse should I get for a replacement?
From reading various articles I understand that just unplugging the appliance will not protect me from getting shock. I could also use help locating and discharging the high voltage capacitor.
Thank you so much for any assistance!
Brad
Related Models
Amana R-1H RANGE- S/C S/I DDRAFT GAS
Amana R-1J RANGE- S/C S/I DDRAFT GAS
Amana R-1J MWAVE - FAMILY SIZE (60 HZ)
Amana R-2 RANGE- S/C S/I DDRAFT GAS
Amana R-3 RANGE- S/C S/I DDRAFT GAS
Amana R-3 MWAVE - FAMILY SIZE (60 HZ)
Amana R0-24-8 MWAVE - FAMILY SIZE (60 HZ)
Amana R0-24-8 MWAVE- MOUNTED OVER RANGE/WO
Whirlpool R101 Air-conditioner/heat pump
Whirlpool R1011 Air-conditioner/heat pump
Whirlpool R1012 Air-conditioner/heat pump
Whirlpool R1013 AIR CONDITIONER
Whirlpool R1014 AIR CONDITIONER
Whirlpool R121 Air-conditioner/heat pump
Whirlpool R1211 Air-conditioner/heat pump
Whirlpool R1212 AIR CONDITIONER
Whirlpool R1213 AIR CONDITIONER
Whirlpool R1231 Air-conditioner/heat pump
 R1404 Air Conditioner
Whirlpool R141A AIR CONDITIONER
Whirlpool R141A1 AIR CONDITIONER
Whirlpool R141F0 AIR CONDITIONER
Whirlpool R141G0 AIR CONDITIONER
Amana R15 MISC / ACCESSORY
Whirlpool R153 Air-conditioner/heat pump
Amana R15A MISC / ACCESSORY
Amana R15L MISC / ACCESSORY
Amana R15LA MISC / ACCESSORY
Whirlpool R183 AIR CONDITIONER
Whirlpool R183A AIR CONDITIONER
Whirlpool R183A1 AIR CONDITIONER
Whirlpool R183A2 AIR CONDITIONER
Whirlpool R183A3 AIR CONDITIONER
Whirlpool R183F0 AIR CONDITIONER
Whirlpool R183G0 AIR CONDITIONER
Whirlpool R183G1 AIR CONDITIONER
Amana R1E MWAVE - FAMILY SIZE (60 HZ)
Jenn-Air R200 SURFACE UNIT- DDRAFT ELE
Frigidaire R2000DL0 Frg(v1) / Electric Range
Frigidaire R2000DW0 Frg(v2) / Electric Range
Frigidaire R2000LL1 Frg(v1) / Electric Range
Frigidaire R2000LW1 Frg(v2) / Electric Range
Jenn-Air R201 SURFACE UNIT- DDRAFT ELE
Jenn-Air R201-C SURFACE UNIT- DDRAFT ELE
Frigidaire R21CL0 Frg(v1) / Free Standing Electric Range
Frigidaire R21CL1 Frg(v1) / Free Standing Electric Range
Frigidaire R21CL2 Frg(v2) / Electric Range
Frigidaire R21CL3 Frg(v4) / Electric Range
Frigidaire R21CL4 Frg(v6) / Electric Range
Frigidaire R21CL5 Frg(v2) / Electric Range
Frigidaire R21CL6 Frg(v4) / Electric Range
Frigidaire R21CW0 Frg(v2) / Free Standing Electric Range
Frigidaire R21CW1 Frg(v2) / Free Standing Electric Range
Frigidaire R21CW2 Frg(v1) / Electric Range
Frigidaire R21CW3 Frg(v3) / Electric Range
Frigidaire R21CW4 Frg(v5) / Electric Range
Frigidaire R21CW5 Frg(v1) / Electric Range
Frigidaire R21CW6 Frg(v3) / Electric Range
Hoover R226D011 REF - SXS/I&W
Frigidaire R22CW1
Frigidaire R22CW10
Crosley R22CW11 ARCTIC AIR/REFRIGERATOR
Crosley R22CW12 ARCTIC AIR/REFRIGERATOR
Crosley R22CW13 ARTIC AIR/REFRIGERATOR
Frigidaire R22CW2
Frigidaire R22CW3
Frigidaire R22CW4
Frigidaire R22CW5
Frigidaire R22CW6
Frigidaire R22CW7
Frigidaire R22CW8
Frigidaire R22CW9
Crosley R22CWF0 ARCTIC AIR/REFRIGERATOR
Crosley R22CWF1 ARCTIC AIR/REFRIGERATOR
Crosley R22CWF2 ARTIC AIR/REFRIGERATOR
Crosley R22CWF3 ARCTIC AIR/REFRIGERATOR
Whirlpool R243 Air-conditioner/heat pump
Whirlpool R243A AIR CONDITIONER
Whirlpool R243A1 AIR CONDITIONER
Whirlpool R243A2 AIR CONDITIONERS
Whirlpool R243B AIR CONDITIONER
Frigidaire R24CL0 Frg(v3) / Free Standing Electric Range
Frigidaire R24CL1 Frg(v3) / Free Standing Electric Range
Frigidaire R24CL2 Frg(v2) / Electric Range
Frigidaire R24CL3 Frg(v4) / Electric Range
Frigidaire R24CL4 Frg(v6) / Electric Range
Frigidaire R24CL5 Frg(v8) / Electric Range
Frigidaire R24CW0 Frg(v4) / Free Standing Electric Range
Frigidaire R24CW1 Frg(v4) / Free Standing Electric Range
Frigidaire R24CW2 Frg(v1) / Electric Range
Frigidaire R24CW3 Frg(v3) / Electric Range
Frigidaire R24CW4 Frg(v5) / Electric Range
Frigidaire R24CW5 Frg(v7) / Electric Range
Whirlpool R253F0 AIR CONDITIONER
Whirlpool R253G1 AIR CONDITIONER
Whirlpool R293F0 AIR CONDITIONER
Frigidaire R30AA2 Frg(v4) / Electric Range
Frigidaire R30AA3 Frg(v9) / Electric Range
Frigidaire R30AA4 Frg(v3) / Electric Range
Frigidaire R30AF2 Frg(v3) / Electric Range
Frigidaire R30AF3 Frg(v8) / Electric Range
Frigidaire R30AF4 Frg(v2) / Electric Range
Frigidaire R30AH2 Frg(v5) / Electric Range
Frigidaire R30AH3 Frg(v10) / Electric Range
Frigidaire R30AH4 Frg(v4) / Electric Range
Frigidaire R30AL1 Frg(v1) / Free Standing Electric Range
Frigidaire R30AL2 Frg(v2) / Electric Range
Frigidaire R30AL3 Frg(v7) / Electric Range
Frigidaire R30AL4 Frg(v5) / Electric Range
Frigidaire R30AW1 Frg(v2) / Free Standing Electric Range
Frigidaire R30AW2 Frg(v1) / Electric Range
Frigidaire R30AW3 Frg(v6) / Electric Range
Frigidaire R30AW4 Frg(v1) / Electric Range
Frigidaire R30BCH1 Frg(v1) / Free Standing Electric Range
Frigidaire R30BCH2 Frg(v3) / Electric Range
Frigidaire R30BCH3 Frg(v6) / Electric Range
  #2 (permalink)
Old 11-23-2016, 02:40 AM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
The wires from the light sockets goes to neutral and the other goes to the computer control board B9. Probably something fried on the board. Maybe the SSR. (Solid State Relay)
Changing the light bulb live can fry sensitive parts on the board.
Its still available from $ears.part. no. 46-356723-3
The lights are part. no.
504150
  #3 (permalink)
Old 11-26-2016, 10:57 AM
Junior Member
Default
ThatGuy,
Thanks so much for the quick reply. Based on your comment re: SSR, I disconnected all the everything from the control panel and took it out to look at it in better light. See the attached pics to what I found. Looks like I did fry the SSR. I believe I have only 2 options....1) Leave as is as everything appears to be working or 2) Buy a new control board. Would you agree?
  #4 (permalink)
Old 11-26-2016, 05:06 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
There are two more options. You could send it out to one of these board repair places or you could try fixing it yourself.
The part is a SHARP S101D01
If you search that part no. on Epay you will find some for under $7 here in the USA and even lower from China. If you are good at soldering, its fairly simple to de-solder the old chip and solder on the new one.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Range Hood lights/2 work 2 now do not/not a bulb issue buddy6713 Oven Repair (including Ranges and Cooktops) 3 12-17-2014 03:00 PM
Under-hood lights don't work right revans Microwave Repair 0 01-24-2010 05:53 AM
Range hood lights won't work SheriEvenson Oven Repair (including Ranges and Cooktops) 0 08-02-2008 10:53 AM
Sharp microwave wont work, all else does?? janarmour Microwave Repair 0 05-24-2008 09:51 AM
Sharp Microwave Lights but no Heat sweet Microwave Repair 0 12-05-2007 07:13 AM
