Discuss
Whirlpool won't heat - tested most parts
 in
Microwave Repair
Wondering if anyone can help with a busted microwave. Whirlpool GMH3204XVS-2 - built in 2010 - put in service 2012.
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Whirlpool won't heat - tested most parts
  #1 (permalink)
Old 10-17-2016, 02:56 PM
Junior Member
vancod is on a distinguished road
Default Whirlpool won't heat - tested most parts
Model Number: GMH3204XVS-2   Brand: Whirlpool   Age: 5 - 10 years
Stopped working during a cooking cycle. At the time no noticeable noise, or smell.
If I run it at a lower power level (like "5") I can hear the "swell" of the transformer that I usually hear when it pulses for lower power levels.
I pulled the diode (CL04-12) and tested it - based on what I've read it seemed like it might be OK - but the voltage drop across it was high (I was reading about 5.3 volts through a 9V battery). Resistance was rather as I've read as well (high both directions, really high in one).
I tested the cap - not swollen, it seemed within rage (I forget the rating - maybe 1.05 and I was reading 1.03), internal resistor appeared to be draining as designed.
I tested the magnetron - and again it seemed to be OK (no opens, no shorts, about .3ohm resistance). No visible cracks, etc - but there is some minor discoloration near the base (the metal mesh) of the "tip"
So I put the diode back in - and when I powered it there was a single arc to ground from "near" the diode. I could have been from the diode itself - or it could have been from the wires on the cap that were on the same terminal as the diode (more on this below).
Thinking the arc was from the diode I decided to replace it since it's cheap.
As soon as I powered it on with the new diode there was again a single quick arc - this time it looked like it came possibly from the transformer (what looks like a tap in the windings to a thermal switch on the magnetron??) - OR - from one of the leads into the magnetron, the bottom most lead being the same one that comes out of the cap where the diode connected (and it arced previously).
So I really have no idea what could be wrong. But I am wondering it it's not the magnetron based on the 2 times I've seen an arc and the arc coming from a wire that attached to the HV cap.
Any advice appreciated.
Cheers -
Don
Related Models
Whirlpool GMH3204XVS0 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool GMH3204XVS1 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Whirlpool GMH3204XVS2 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Whirlpool GMH5184VAQ0 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool GMH5184XVB0 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool GMH5184XVB1 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Whirlpool GMH5184XVQ0 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool GMH5184XVQ1 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Whirlpool GMH5184XVS0 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool GMH5184XVS1 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Whirlpool GMH5184XVT0 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool GMH5184XVT1 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Whirlpool GMH5205XVB0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Whirlpool GMH5205XVQ0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Whirlpool GMH5205XVS0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Whirlpool GMH5205XVT0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Whirlpool GMH6185XVB0 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool GMH6185XVB1 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Whirlpool GMH6185XVB2 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Whirlpool GMH6185XVQ0 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool GMH6185XVQ1 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Whirlpool GMH6185XVQ2 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Whirlpool GMH6185XVS0 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool GMH6185XVS1 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Whirlpool GMH6185XVS2 MICROWAVE OVEN/HOOD 1.8 CU. FT.
General Electric GMR02AAMABB Refrigerator
General Electric GMR02AAMAWW Refrigerator
General Electric GMR02BANABB Refrigerator
General Electric GMR02BANAWW Refrigerator
General Electric GMR02BANBBB Refrigerator
General Electric GMR02BANBWW Refrigerator
General Electric GMR02BANCBB Refrigerator
General Electric GMR02BANCWW Refrigerator
General Electric GMR02BANDBB Refrigerator
General Electric GMR02BANDWW Refrigerator
General Electric GMR02BAVABB REFRIGERATOR
General Electric GMR02BAVAWW REFRIGERATOR
General Electric GMR02CANBWW Refrigerator
General Electric GMR03DAMAWW Refrigerator
General Electric GMR04AAMABB Refrigerator
General Electric GMR04AAMAWW Refrigerator
General Electric GMR04AAVABB REFRIGERATOR
General Electric GMR04AAVAWW REFRIGERATOR
General Electric GMR04BANABB Refrigerator
General Electric GMR04BANAWW Refrigerator
General Electric GMR04BANBBB Refrigerator
General Electric GMR04BANBWW Refrigerator
General Electric GMR04BANCBB Refrigerator
General Electric GMR04BANCWW Refrigerator
General Electric GMR04BANDBB Refrigerator
General Electric GMR04BANDWW Refrigerator
General Electric GMR04BANEBB REFRIGERATOR
General Electric GMR04BANEWW REFRIGERATOR
General Electric GMR04BARABS Refrigerator
General Electric GMR04BARBBS Refrigerator
General Electric GMR04BARCBS Refrigerator
General Electric GMR04HANBBS Refrigerator
General Electric GMR04HANCBS Refrigerator
General Electric GMR04HANDBS Refrigerator
General Electric GMR04HASACS Refrigerator
General Electric GMR04HASBCS Refrigerator
General Electric GMR06AAMARWW Refrigerator
General Electric GMR06AAMBRWW Refrigerator
General Electric GMR06AAPBB Refrigerator
General Electric GMR06AAPBBB REFRIGERATOR P SERIES
General Electric GMR06AAPBWW REFRIGERATOR P SERIES
General Electric GMR06AAPWW Refrigerator
General Electric GMR06AAZABB REFRIGERATOR
General Electric GMR06AAZAWW REFRIGERATOR
General Electric GMS10AAMALWW Refrigerator
General Electric GMS10AAMARWW Refrigerator
Frigidaire GMT1670AS0 Frigidaire/washer
Frigidaire GMWS1339CS0 Frigidaire/washer
General Electric GN1S15CBL Uc filtration-carbon
Norge GN31113WAV RANGE- F/S STD GAS
Norge GN3177WUA RANGE- F/S STD GAS
Norge GN3177WUW RANGE- F/S STD GAS
Norge GN3277XUA RANGE- F/S STD GAS
Norge GN3277XUW RANGE- F/S STD GAS
Norge GN3531WUA RANGE- F/S STD ELE
Norge GN3531WUW RANGE- F/S STD ELE
General Electric GNCF02H Home cond
General Electric GNCF04H Home cond
Gibson GNEM30NWMWA ELECTRIC RANGE
Thermador GNG12M COOKTOP
Thermador GNG12MW GRIDDLE
General Electric GNLD681N10BB DISHWASHER
General Electric GNLD681N10SS DISHWASHER
General Electric GNLD681N10WW DISHWASHER
General Electric GNLD681N20BB DISHWASHER
General Electric GNLD681N20SS DISHWASHER
General Electric GNLD681N20WW DISHWASHER
General Electric GNPR40L00 Softners
General Electric GNPR48L00 Softners
General Electric GNRP40L00 Softners
General Electric GNRP48L00 Softners
Admiral GNS20M82 REF - SXS
General Electric GNSF18Z01 Uc filtration-carbon
General Electric GNSF23Z01 Uc filtration-carbon
General Electric GNSF35Z01 Uc filtration-carbon
General Electric GNSF35Z02 Water softeners
General Electric GNSF35Z03 Water softeners
General Electric GNSF35Z04 Softners
General Electric GNSF39A01 Uc filtration-carbon
General Electric GNSF48A01 Uc filtration-carbon
General Electric GNSH45E01 Water softeners
General Electric GNSH45E02 Softners
General Electric GNSH45E03 Softners
General Electric GNSL05CBL Uc filtration-carbon
General Electric GNSL60FBL Wh filt sys
General Electric GNSM48F02 Softners
General Electric GNSM48F03 Softners
General Electric GNSR2090T9WW WASHER
General Electric GNSR3150H0WW Washer
General Electric GNSR3150H1WW WASHER
General Electric GNSR3150H2WW WASHER
General Electric GNSR3150H3WW WASHER
General Electric GNSR3150H4WW WASHER
General Electric GNSR3150H5WW WASHER
General Electric GNSR3150H6WW WASHER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer overflows, have tested parts traksta15 Washer Repair 0 02-24-2016 01:58 PM
Replaced/tested everything - still no heat - Snug Harbor Dryer Repair 1 02-23-2015 09:11 AM
No Heat, Tested parts for Continuity crappyone Dryer Repair 3 03-19-2014 02:08 AM
replaced/tested lots still no heat oootwigzooo Dryer Repair 1 07-25-2010 02:45 AM
Whirlpoo Dryer won't heat, tested most parts everythingman Dryer Repair 1 08-09-2009 09:32 PM
