Discuss
Removing Microwave Control Panel
 in
Microwave Repair
I have a a PLEB27M9EC oven / microwave combination. My microwave is not working, the timer counts down and the
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Removing Microwave Control Panel
  #1 (permalink)
Old 09-25-2016, 06:31 AM
Junior Member
bradf79 is on a distinguished road
Default Removing Microwave Control Panel
Model Number: PLEB27M9EC   Brand: Electrolux   Age: 5 - 10 years
I have a a PLEB27M9EC oven / microwave combination. My microwave is not working, the timer counts down and the light comes on but no heating or spinning. I figured out if I press on the door open button slightly, it will begin heating. I assume this means the door sensor switch needs replaced but I cannot figure out how to get the panel off. I've uploaded some pictures:
Imgur: The most awesome images on the Internet
I've removed the stainless steel think piece that wraps the control panel. I see no screws that are securing the panel from sliding up and being removed. When I pry on the right side I see The clips and it definitely looks like it must slide up to come out. I cannot slide it up because the black metal lip on the top of the unit is blocking it.
Does anyone have any experience on removing this panel?
Can anyone help?
Related Models
Frigidaire PLEB27M9ECA Frigidaire/wall Oven/microwave Combo
Frigidaire PLEB27M9ECB Frigidaire/wall Oven
Frigidaire PLEB27M9ECC Frigidaire/walloven - Microwave Combo
Frigidaire PLEB27M9ECD WALLOVEN-MICROWAVE COMBO
Frigidaire PLEB27M9ECE WALLOVEN-MICROWAVE COMBO
Frigidaire PLEB27S8ACA Frigidaire/electric Range
Frigidaire PLEB27S8ACB Frigidaire/electric Wall Oven
Frigidaire PLEB27S8CCA Frigidaire/electric Wall Oven
Frigidaire PLEB27S8CCB Frigidaire/electric Wall Oven
Frigidaire PLEB27S8CCC Frigidaire/wall Oven
Frigidaire PLEB27S9DCA Frigidaire/walloven
Frigidaire PLEB27S9DCB Frigidaire/electric Walloven
Frigidaire PLEB27S9FCA Frigidaire/wall Oven
Frigidaire PLEB27S9FCB Frigidaire/walloven
Frigidaire PLEB27S9FCC ELECTRIC OVEN
Frigidaire PLEB27S9FCD ELECTRIC OVEN
Frigidaire PLEB27S9FCE ELECTRIC OVEN
Frigidaire PLEB27S9FCF ELECTRIC OVEN
Frigidaire PLEB27T8ACA Frigidaire/electric Wall Oven
Frigidaire PLEB27T8ACB Frigidaire/electric Wall Oven
Frigidaire PLEB27T8CCA Frigidaire/electric Wall Oven
Frigidaire PLEB27T8CCB Frigidaire/electric Wall Oven
Frigidaire PLEB27T9DCA Frigidaire/walloven
Frigidaire PLEB27T9DCB Frigidaire/electric Walloven
Frigidaire PLEB27T9DCC Frigidaire/walloven
Frigidaire PLEB27T9FCA Frigidaire/wall Oven
Frigidaire PLEB27T9FCB Frigidaire/walloven
Frigidaire PLEB27T9FCC ELECTRIC OVEN
Frigidaire PLEB27T9FCD ELECTRIC OVEN
Frigidaire PLEB30M9ECA Frigidaire/wall Oven/microwave Combo
Frigidaire PLEB30M9ECC Frigidaire/wall Oven/microwave
Frigidaire PLEB30M9ECD Frigidaire/walloven - Microwave Combo
Frigidaire PLEB30M9ECE ELECTRIC OVEN W/MICROWAVE
Frigidaire PLEB30M9ECF ELECTRIC OVEN W/MICROWAVE
Frigidaire PLEB30S8ACA Frigidaire/electric Range
Frigidaire PLEB30S8ACB Frigidaire/electric Wall Oven
Frigidaire PLEB30S8CCA Frigidaire/electric Wall Oven
Frigidaire PLEB30S8CCB Frigidaire/wall Oven
Frigidaire PLEB30S8CCC Frigidaire/wall Oven
Frigidaire PLEB30S9DCA Frigidaire/walloven
Frigidaire PLEB30S9DCB Frigidaire/electric Walloven
Frigidaire PLEB30S9FCA Frigidaire/wall Oven
Frigidaire PLEB30S9FCB Frigidaire/wall Oven
Frigidaire PLEB30S9FCC ELECTRIC OVEN
Frigidaire PLEB30S9FCD ELECTRIC OVEN
Frigidaire PLEB30S9FCF ELECTRIC OVEN
Frigidaire PLEB30T8ACA Frigidaire/electric Wall Oven
Frigidaire PLEB30T8ACB Frigidaire/electric Wall Oven
Frigidaire PLEB30T8CCA Frigidaire/wall Oven
Frigidaire PLEB30T8CCB Frigidaire/electric Wall Oven
Frigidaire PLEB30T9DCA Frigidaire/electric Walloven
Frigidaire PLEB30T9DCB Frigidaire/wall Oven
Frigidaire PLEB30T9DCC Frigidaire/walloven
Frigidaire PLEB30T9FCA Frigidaire/wall Oven
Frigidaire PLEB30T9FCB Frigidaire/walloven
Frigidaire PLEB30T9FCC ELECTRIC OVEN
Frigidaire PLEB30T9FCD ELECTRIC OVEN
Frigidaire PLEB30T9FCE ELECTRIC OVEN
Frigidaire PLEC30S9ECA Frigidaire/electric Cooktop
Frigidaire PLEC30S9ECB Frigidaire/electric Cooktop
Frigidaire PLEC30S9ECC Frigidaire/cooktop
Frigidaire PLEC36S9ECA Frigidaire/electric Cooktop
Frigidaire PLEC36S9ECB Frigidaire/electric Cooktop
Frigidaire PLEC36S9ECC Frigidaire/cooktop
Frigidaire PLEF398ACA Frigidaire/range
Frigidaire PLEF398ACB Frigidaire/electric Range
Frigidaire PLEF398ACC Frigidaire/electric Range
Frigidaire PLEF398CCA Frigidaire/electric Range
Frigidaire PLEF398CCB Frigidaire/electric Range
Frigidaire PLEF398CCC Frigidaire/electric Range
Frigidaire PLEF398CCD Frigidaire/electric Range
Frigidaire PLEF398CCE Frigidaire/electric Range
Frigidaire PLEF398DCA Frigidaire/electric Range
Frigidaire PLEF398DCB Frigidaire/electric Range
Frigidaire PLEF398DCC Frigidaire/electric Range
Frigidaire PLEF398DCD Frigidaire/range
Frigidaire PLEF398DCE Frigidaire/range
Frigidaire PLEF398DCH Frigidaire/range
Frigidaire PLEF398DCJ Frigidaire/electric Range
Frigidaire PLEF489ACA Frigidaire/electric Range
Frigidaire PLEF489ACB Frigidaire/electric Range
Frigidaire PLEF489ACC Frigidaire/electric Range
Frigidaire PLEF489ACD Frigidaire/electric Range
Frigidaire PLEF489CCA Frigidaire/electric Range
Frigidaire PLEF489CCB Frigidaire/electric Range
Frigidaire PLEF489CCC Frigidaire/electric Range
Frigidaire PLEF489CCD Frigidaire/electric Range
Frigidaire PLEF489CCE Frigidaire/electric Range
Frigidaire PLEF489CCF Frigidaire/electric Range
Frigidaire PLEF489CCG Frigidaire/electric Range
Frigidaire PLEF489CCH ELECTRIC RANGE
Frigidaire PLEF489GCA ELECTRIC RANGE
Frigidaire PLEFM399DCA Frigidaire/electric Range
Frigidaire PLEFM399DCB Frigidaire/electric Range
Frigidaire PLEFM399DCC Frigidaire/electric Range
Frigidaire PLEFM399DCD Frigidaire/range
Frigidaire PLEFMZ99ECA Frigidaire/range
Frigidaire PLEFMZ99ECC Frigidaire/range
Frigidaire PLEFMZ99ECE Frigidaire/electric Range
Frigidaire PLEFMZ99ECF Frigidaire/electric Range
Frigidaire PLEFMZ99ECG Frigidaire/range
Frigidaire PLEFMZ99ECJ Frigidaire/electric Range
Frigidaire PLEFMZ99ECK Frigidaire/range
Frigidaire PLEFMZ99ECM ELECTRIC RANGE
Frigidaire PLEFMZ99ECN ELECTRIC RANGE
Frigidaire PLEFMZ99GCA ELECTRIC RANGE
Frigidaire PLEFMZ99GCB ELECTRIC RANGE
Frigidaire PLEFMZ99GCC ELECTRIC RANGE
Frigidaire PLEFMZ99GCD ELECTRIC RANGE
Frigidaire PLEFMZ99GCE ELECTRIC RANGE
Frigidaire PLEFZ398ECA Frigidaire/electric Range
Frigidaire PLEFZ398ECB Frigidaire/electric Range
Frigidaire PLEFZ398ECC Frigidaire/range
Frigidaire PLEFZ398ECD Frigidaire/electric Range
Frigidaire PLEFZ398ECE Frigidaire/range
Frigidaire PLEFZ398ECF Frigidaire/range
Frigidaire PLEFZ398GCA ELECTRIC RANGE
Frigidaire PLEFZ398GCB ELECTRIC RANGE
Frigidaire PLEFZ398GCC ELECTRIC RANGE
Frigidaire PLES389ACA Frigidaire/electric Range
  #2 (permalink)
Old 09-29-2016, 06:13 AM
Junior Member
Default
Damn this is frustrating... I really don't want to just pry the panel off and break it, it's $125 just for it... Only thing I can see is removing the whole over+microwave and remove the top panel on the microwave so the control panel cover can slide up...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Removing Control Panel DIY-Pete Dishwasher Repair 0 07-28-2015 04:46 PM
Removing control panel and installing new control board devronh Oven Repair (including Ranges and Cooktops) 2 03-05-2014 07:51 AM
Need help removing control panel and front panel to get at the drain pump jthenne Washer Repair 2 02-16-2011 02:15 PM
Removing control panel One More Try Refrigerator & Freezer Repair 0 02-02-2010 02:37 PM
Removing the control panel - how to do it???? sean_lui Microwave Repair 1 07-28-2008 10:19 AM
