Discuss
Need help identify problem for Panasonic inverter.
 in
Microwave Repair
The microwave stops working the other day. When I opened the door, the light came on then popped. The timer
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Need help identify problem for Panasonic inverter.
  #1 (permalink)
Old 06-11-2016, 06:42 PM
Junior Member
t53864 is on a distinguished road
Default Need help identify problem for Panasonic inverter.
Model Number: 668b   Brand: -other-   Age: 1 - 5 years
The timer still works. It starts counting down.
But, the microwave is not doing anything. Fan and turntable not moving.
I tested all 3 switches... Looks OK.
The bulb is burnt out. When I open the door and test for any voltage between the bulb connectors and found no voltage!!!
Is it a problem with the circuit board?
Any feedback is appreciated.
Thanks,
Terry
Related Models
Admiral 668WJ-ASAW RANGE- S/C F/S ELE
Admiral 668WK-TSAW RANGE- S/C F/S ELE
Maytag 66CB MAYTAG LAUNDRY (DRYER GAS)
Hoover 67
Hoover 671
Admiral 671AH RANGE- F/S STD GAS
Admiral 671AH-K RANGE- F/S STD GAS
Admiral 671WH RANGE- F/S STD GAS
Admiral 671WH-K RANGE- F/S STD GAS
Admiral 673AJ-KV RANGE- F/S STD GAS
Admiral 673WJ-KV RANGE- F/S STD GAS
Admiral 674AJ-EKLVW RANGE-F/S CONT CLEAN GAS
Admiral 674AJ-EKVW RANGE- F/S STD GAS
Admiral 674AJ-EKW RANGE- F/S STD GAS
Admiral 674WJ-EKLVW RANGE-F/S CONT CLEAN GAS
Admiral 674WJ-EKVW RANGE- F/S STD GAS
Admiral 674WJ-EKW RANGE- F/S STD GAS
Admiral 675AJ-KVW RANGE- F/S STD GAS
Admiral 675AK-KLVW RANGE-F/S CONT CLEAN GAS
Admiral 675AK-KVW RANGE- F/S STD GAS
Admiral 675AM-KSVW RANGE- F/S STD GAS
Admiral 675WJ-KVW RANGE- F/S STD GAS
Admiral 675WK-KLVW RANGE-F/S CONT CLEAN GAS
Admiral 675WK-KVW RANGE- F/S STD GAS
Admiral 675WM-KSVW RANGE- F/S STD GAS
Admiral 676AJ-KSVW RANGE- F/S STD GAS
Admiral 676AK-KLSVW RANGE-F/S CONT CLEAN GAS
Admiral 676AK-KSVW RANGE- F/S STD GAS
Admiral 676AM-KLSVW RANGE-F/S CONT CLEAN GAS
Admiral 676AM-KSVW RANGE- F/S STD GAS
Admiral 676WJ-KSVW RANGE- F/S STD GAS
Admiral 676WK-KLSVW RANGE-F/S CONT CLEAN GAS
Admiral 676WK-KSVW RANGE- F/S STD GAS
Admiral 676WM-KLSVW RANGE-F/S CONT CLEAN GAS
Admiral 676WM-KSVW RANGE- F/S STD GAS
Maytag 67C DRYER- GAS
Hoover 68
Frigidaire 68-1075 TAPPAN DISHWASHER
Frigidaire 68-1085 TAPPAN 24" BUILT-IN DISHWASHER
Magic Chef 68-2534-40 GAS RANGE
Magic Chef 68-253657 GAS RANGE
Magic Chef 68-2543-80 GAS RANGE
Magic Chef 68-2543-87 GAS RANGE
Magic Chef 68-2558-40 GAS RANGE
Magic Chef 68-255850 GAS RANGE
Magic Chef 68-255857 GAS RANGE
Magic Chef 68-2563-87 GAS RANGE
Magic Chef 68-2593-80 GAS RANGE
Magic Chef 68-2593-81 GAS RANGE
Magic Chef 68-2593-87 GAS RANGE
Hardwick 68-2598 GAS RANGE
Magic Chef 68-454650 ELECTRIC RANGE
Magic Chef 68-454657 ELECTRIC RANGE
Magic Chef 68-4567-40 ELECTRIC RANGE
Magic Chef 68-456750 ELECTRIC RANGE
Magic Chef 68-456751 ELECTRIC RANGE
Magic Chef 68-456757 ELECTRIC RANGE
Magic Chef 68-4585-40 ELECTRIC RANGE
Magic Chef 68-4587-87 ELECTRIC RANGE
Hoover 681
Admiral 684AJ-CKV RANGE- S/C F/S GAS
Admiral 684WJ-CKV RANGE- S/C F/S GAS
Admiral 685AJ-CKV RANGE- S/C F/S GAS
Admiral 685AJ-CKVW RANGE- S/C F/S GAS
Admiral 685WJ-CKV RANGE- S/C F/S GAS
Admiral 685WJ-CKVW RANGE- S/C F/S GAS
Admiral 686AJ-EKSVW RANGE- S/C F/S GAS
Admiral 686AJ-TKSVW RANGE- S/C F/S GAS
Admiral 686AK-EKSVW RANGE- S/C F/S GAS
Admiral 686AM-CKSV RANGE- S/C F/S GAS
Admiral 686AM-TKS RANGE- S/C F/S GAS
Admiral 686WJ-EKSVW RANGE- S/C F/S GAS
Admiral 686WJ-TKSVW RANGE- S/C F/S GAS
Admiral 686WK-EKSVW RANGE- S/C F/S GAS
Admiral 686WM-CKSV RANGE- S/C F/S GAS
Admiral 686WM-TKS RANGE- S/C F/S GAS
Admiral 687AF-CKVW RANGE- S/C F/S GAS
Admiral 687AJ-EKZW RANGE- S/C F/S GAS
Admiral 687AJ-TKSAW RANGE- S/C F/S GAS
Admiral 687AK-TKSAW RANGE- S/C F/S GAS
Admiral 687AM-TKSAW RANGE- S/C F/S GAS
Admiral 687WF-CKVW RANGE- S/C F/S GAS
Admiral 687WJ-EKZW RANGE- S/C F/S GAS
Admiral 687WJ-TKSAW RANGE- S/C F/S GAS
Admiral 687WK-TKSAW RANGE- S/C F/S GAS
Admiral 687WM-TKSAW RANGE- S/C F/S GAS
Magic Chef 6892VRA RANGE- S/C S/I ELE
Magic Chef 6892VRV RANGE- S/C S/I ELE
Magic Chef 6892VVA RANGE- S/C S/I ELE
Magic Chef 6892VVV RANGE- S/C S/I ELE
Magic Chef 6892XRA RANGE- S/C S/I ELE
Magic Chef 6892XRS RANGE- S/C S/I ELE
Magic Chef 6892XRW RANGE- S/C S/I ELE
Magic Chef 6892XVA RANGE- S/C S/I ELE
Magic Chef 6892XVB RANGE- S/C S/I ELE
Magic Chef 6892XVS RANGE- S/C S/I ELE
Magic Chef 6892XVW RANGE- S/C S/I ELE
Magic Chef 6893VVD RANGE- S/C S/I ELE
Magic Chef 6893VVV RANGE- S/C S/I ELE
Magic Chef 6893XVB RANGE- S/C S/I ELE
Magic Chef 6895VRA RANGE- S/C S/I ELE
Magic Chef 6895VRV RANGE- S/C S/I ELE
Magic Chef 6896VVD RANGE- S/C S/I ELE
Magic Chef 6896VVV RANGE- S/C S/I ELE
Magic Chef 6896XVB RANGE- S/C S/I ELE
Magic Chef 6898VRA RANGE- S/C S/I ELE
Magic Chef 6898VRV RANGE- S/C S/I ELE
Magic Chef 6898VVA RANGE- S/C S/I ELE
Magic Chef 6898VVD RANGE- S/C S/I ELE
Magic Chef 6898VVV RANGE- S/C S/I ELE
Magic Chef 6898XRA RANGE- S/C S/I ELE
Magic Chef 6898XRB RANGE- S/C S/I ELE
Magic Chef 6898XVB RANGE- S/C S/I ELE
Magic Chef 68HA-3CW RANGE- S/C S/I ELE
Magic Chef 68HA-3CXW RANGE- S/C S/I ELE
Magic Chef 68HA-4TVW RANGE- S/C S/I ELE
Magic Chef 68HA-4TXW RANGE- S/C S/I ELE
Magic Chef 68HA-6TVW RANGE- S/C S/I ELE
Magic Chef 68HK-6TXW RANGE- S/C S/I ELE
Magic Chef 68HN-3CXW RANGE- S/C S/I ELE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Panasonic Inverter- Microwave Not Working Dan_G Microwave Repair 0 03-30-2014 02:47 PM
panasonic inverter microwave pawtastic Microwave Repair 1 07-23-2012 09:14 PM
panasonic inverter smokes ques221 Microwave Repair 0 10-01-2011 09:07 AM
panasonic inverter dimension 4 peter e lee Microwave Repair 0 06-10-2011 01:56 PM
Panasonic Inverter Microwave - perhaps the door latches are a problem akeen Microwave Repair 0 10-21-2009 07:21 AM
