Discuss
Panasonic genious inverter microwave stops working after 23 seconds
 in
Microwave Repair
My panasonic microwave just stop working after 23 seconds of use no matter what functions I use. I tested the
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Panasonic genious inverter microwave stops working after 23 seconds
  #1 (permalink)
Old 01-31-2016, 12:34 PM
Junior Member
scstar is on a distinguished road
Default Panasonic genious inverter microwave stops working after 23 seconds
Brand: -other-   Age: 5 - 10 years
My panasonic microwave just stop working after 23 seconds of use no matter what functions I use. I tested the power on the fuse, thermoprotector and door switch and they all give me 120 volts. I noticed that the magnetron doesn't go on nor does it heat for the 23 seconds in use. So I tested the power from the board to the magnetron and I don't get any power, but i also tested that the board receives power and it does.**Hence the reason that the magnetron isn't working. Is there a way to test that the board is faulty. Can it be the high voltage transformer on the board that got fried and thus doesn't send the power to the magnetron. I tested the magnetron and I get some power, so I don't think it's **the magnetron. Could it be that the magnetron is faulty and thus doesn't let the power reach the magnetron.
Thanks in advance for your help.**
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Panasonic microwave inverter starts but then stops barbaraturnage69.69@gmail Microwave Repair 0 12-28-2015 11:50 AM
Panasonic Inverter shuts off after 3 seconds, door issue? Help needed! puppy10014 Microwave Repair 0 03-04-2015 10:56 PM
Panasonic Inverter- Microwave Not Working Dan_G Microwave Repair 0 03-30-2014 02:47 PM
Panasonic Microwave inverter not heating SharonRedlick Microwave Repair 0 01-21-2013 03:05 PM
panasonic inverter microwave pawtastic Microwave Repair 1 07-23-2012 09:14 PM
