Discuss
Bad Primary Switch (B2)
 in
Microwave Repair
Timer counting down but no fan and no power to magnetron Opened-up the unit, found signs of overheating on the
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Bad Primary Switch (B2)
  #1 (permalink)
Old 11-15-2015, 07:56 AM
Junior Member
mvuille is on a distinguished road
Question Bad Primary Switch (B2)
Model Number: MW6470W   Brand: Samsung   Age: More than 10 years
magnetron
quick-disconnect to switch B2 (primary switch)
Removed the switch and found that the N.O. terminal
has overheated, plastic switch casing is slightly melted,
switch no longer operates correctly (N.O. on only when
partially activated, off when fully activated)
I am thinking there are two possibilities:
1) quick-disconnect connection went bad over time, increasing
resistance, causing overheating, eventually resulting in the
damage I see
2) overheating and damage are a symptom of a short-circuit
or similar more serious issue
For (1), I can simply replace the switch and clean-up or
replace the quick-disconnect
I am more concerned about (2). How would I check for an
over-current or short-circuit?
MV
Related Models
Amana MW700.000 COMMERCIAL MICROWAVES
Amana MW72 MWAVE- CNTRTP / STAND ALONE
 MW730BB MWAVE- CNTRTP / STAND ALONE
 MW735WB MWAVE- CNTRTP / STAND ALONE
 MW735WB/XAA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW7400XW0 Microwaves*
Whirlpool MW7500XW0 Microwaves*
 MW7695GS MWAVE- CNTRTP / STAND ALONE
Whirlpool MW8100XL0 MICROWAVE
Whirlpool MW8100XL1 MICROWAVE
Whirlpool MW8100XL2 MICROWAVE
Whirlpool MW8100XP0 MICROWAVE
Whirlpool MW8100XR0 MICROWAVE
Whirlpool MW8200XL0 Microwaves*
Whirlpool MW8200XL1 Microwaves*
Whirlpool MW8200XL2 Microwaves*
Whirlpool MW8200XP0 Microwaves*
Whirlpool MW8200XR0 Microwaves*
Whirlpool MW8300XL0 Microwaves*
Whirlpool MW8300XL2 Microwaves*
Whirlpool MW8300XP0 Microwaves*
 MW830BA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW830EXP0 Microwaves*
 MW830WA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW8400XL0 Microwaves*
Whirlpool MW8400XL2 Microwaves*
Whirlpool MW8400XR0 Microwaves*
Whirlpool MW8400XS0 Microwaves*
Whirlpool MW8400XS1 Microwaves*
Whirlpool MW8400XS2 Microwaves*
Whirlpool MW8400XW0 Microwaves*
 MW840BC MWAVE- CNTRTP / STAND ALONE
 MW840BC/XAA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW840EXR0 Microwaves*
 MW840WC MWAVE- CNTRTP / STAND ALONE
 MW840WC/XAA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW8450XL0 Microwaves*
Whirlpool MW8450XL2 Microwaves*
Whirlpool MW8450XP0 Microwaves*
Whirlpool MW8500XP0 Microwave
Whirlpool MW8500XR0 Microwave
Whirlpool MW8500XR1 Microwave
Whirlpool MW8500XS0 Microwave
Whirlpool MW8500XS1 Microwave
Whirlpool MW8500XS2 Microwave
Whirlpool MW8500XS4 Microwave
Whirlpool MW850EXP0 Microwave
Whirlpool MW8520XL9 Microwave
Whirlpool MW8520XP0 Microwave
Whirlpool MW8550XL0 Microwave
Whirlpool MW8550XL2 Microwave
Whirlpool MW8550XS0 Microwave
Whirlpool MW8550XS1 Microwave
Whirlpool MW8550XS2 Microwave
Whirlpool MW8550XS4 Microwave
Whirlpool MW8550XS5 Microwave
Whirlpool MW8570XR0 Microwave
Whirlpool MW8570XR1 Microwave
Whirlpool MW8580XL9 Microwave
Whirlpool MW8580XP0 Microwave
Amana MW85T MWAVE- CNTRTP / STAND ALONE
Whirlpool MW8600XL0 Microwave
Whirlpool MW8600XL2 Microwave
Whirlpool MW8600XR0 Microwave
Whirlpool MW8600XS0 Microwave
Whirlpool MW8600XS1 Microwave
Whirlpool MW8600XS2 Microwave
Whirlpool MW8650XL0 Microwave
Whirlpool MW8650XL2 Microwave
Whirlpool MW8650XR0 Microwave
Whirlpool MW8650XS0 Microwave
Whirlpool MW8650XS1 Microwave
Whirlpool MW8650XS2 Microwave
Whirlpool MW8650XS3 Microwave
Whirlpool MW8650XS4 Microwave
Whirlpool MW8650XS5 Microwave
Whirlpool MW8650XS6 Microwave
Whirlpool MW8650XS7 Microwave
Whirlpool MW865EXR0 Microwave
Whirlpool MW8700XL0 Microwaves*
Whirlpool MW8700XL2 Microwaves*
Whirlpool MW8700XR0 Microwaves*
Whirlpool MW8700XS0 Microwaves*
Whirlpool MW8700XS1 Microwaves*
Whirlpool MW8700XS2 Microwaves*
Whirlpool MW8750XL0 Microwaves*
Whirlpool MW8750XL2 Microwaves*
Whirlpool MW8750XP0 Microwaves*
Whirlpool MW8800XR0 Microwaves*
Whirlpool MW8800XS0 Microwaves*
Whirlpool MW8800XS1 Microwaves*
Whirlpool MW8800XS2 Microwaves*
Whirlpool MW8800XS4 Microwaves*
 MW880BKA MWAVE- CNTRTP / STAND ALONE
 MW880BKA/XAA MWAVE- CNTRTP / STAND ALONE
 MW880BLA MWAVE- CNTRTP / STAND ALONE
 MW880BLA/XAA MWAVE- CNTRTP / STAND ALONE
 MW880BSA MWAVE- CNTRTP / STAND ALONE
 MW880BSA/XAA MWAVE- CNTRTP / STAND ALONE
 MW880GRA MWAVE- CNTRTP / STAND ALONE
 MW880GRA/XAA MWAVE- CNTRTP / STAND ALONE
 MW880KSA MWAVE- CNTRTP / STAND ALONE
 MW880KSA/XAA MWAVE- CNTRTP / STAND ALONE
 MW880RDA MWAVE- CNTRTP / STAND ALONE
 MW880RDA/XAA MWAVE- CNTRTP / STAND ALONE
 MW880RSA MWAVE- CNTRTP / STAND ALONE
 MW880RSA/XAA MWAVE- CNTRTP / STAND ALONE
 MW888STB MWAVE- CNTRTP / STAND ALONE
Whirlpool MW8900XS0 Microwaves*
Whirlpool MW8900XS1 Microwaves*
Whirlpool MW8900XS2 Microwaves*
Whirlpool MW8900XS3 Microwaves*
Whirlpool MW8900XS4 Microwaves*
Whirlpool MW8900XS5 MICROWAVE
Whirlpool MW8900XS6 Microwaves*
Whirlpool MW8901XS0 Microwaves*
 MW945WB MWAVE- CNTRTP / STAND ALONE
 MW965BB MWAVE- CNTRTP / STAND ALONE
 MW965BB/XAA MWAVE- CNTRTP / STAND ALONE
 MW965WB MWAVE- CNTRTP / STAND ALONE
  #2 (permalink)
Old 11-15-2015, 11:22 AM
Junior Member
Default Additional information
Measured the D.C. resistance of the low-voltage winding
of the H.V. Transformer and got 0.4 ohm. (This is with both
secondaries disconnected)
That doesn't seem reasonable, does it?
MV
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
repeated primary door switch failure naem Microwave Repair 0 11-20-2012 09:34 PM
Transformer Primary Voltage Builder99 Microwave Repair 1 05-23-2011 07:49 PM
Primary Oven Broken DOTCON Oven Repair (including Ranges and Cooktops) 0 12-04-2008 03:32 PM
