Discuss
Advantium 120 Micro/Bake Suddenly Inop
 in
Microwave Repair
Have had my Advantium 120 GE Profile Series 1.7 cu. ft. Over-the-Range Microwave Oven for about 9 years of pretty
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Advantium 120 Micro/Bake Suddenly Inop
  #1 (permalink)
Old 11-12-2015, 06:52 PM
Junior Member
vetski179 is on a distinguished road
Default Advantium 120 Micro/Bake Suddenly Inop
Brand: GE   Age: 5 - 10 years
Have had my Advantium 120 GE Profile Series 1.7 cu. ft. Over-the-Range Microwave Oven for about 9 years of pretty much trouble free operation. Wednesday, the microwave and cook with conventional heat stopped working. All other normal operational items, i.e. fan (all speeds) range hood light (low and high) timer, menu items, clock, etc seem to be working as normal. Tried unplugging/replugging back in without success. When pushing any of the buttons that activate the micro wave/conventional heat, all the timers etc seem to work as normal, just the heating does not work. Any thoughts on what might be wrong? Thanks very much!
  #2 (permalink)
Old 11-16-2015, 03:15 PM
Junior Member
Default I fixed it!
FYI for those who might encounter this same issue: When shutting the door, there are buttons on the internal safety switch that are depressed when the door is closed, allowing the unit to activate any cooking commands. As my oven is about 9 years old, there is slop in the hinge pins/ hinge holes in the door, allowing the door to droop. This drooping caused the safety buttons to be depressed down too far, which the oven thinks means the door is open, thus refusing to operate. Shimming the door up solved the problem and the oven works as usual. Hope this helps!
  #3 (permalink)
Old 12-07-2015, 04:03 PM
Junior Member
Default Fixed it (again)
Seems my fix was just temporary. Ultimately stoped working again a week later. I ordered 2 door switches. Upon disassemby, found the upper switch noticably fried. A continuity check revealed it was bad. The other 2 were OK, so replaced the bad top switch and it has worked fine.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
240V Advantium Speedcook Inop cjbaker790 Microwave Repair 0 10-18-2014 01:58 PM
Frigidaire gas range: Bake function inop Dave1175 Oven Repair (including Ranges and Cooktops) 1 03-14-2014 03:42 PM
After Cleaning-Lower bake element?Inop. Victorious3 Oven Repair (including Ranges and Cooktops) 0 11-02-2011 09:55 AM
Ice Maker Inop - Changed Water Valve, Still Inop rhino299 Refrigerator & Freezer Repair 0 08-21-2010 11:32 AM
Fridge inop,Freezer inop 35mastr Refrigerator & Freezer Repair 5 10-24-2007 08:22 AM
