Discuss
KB6524PS Sharp Drawer MW won't heat food, but magnetron gets hot.
 in
Microwave Repair
Quick read - My magnetron heats up, but the food doesn't. Hi: Kind of a science question here. You might
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » KB6524PS Sharp Drawer MW won't heat food, but magnetron gets hot.
  #1 (permalink)
Old 09-27-2015, 02:04 PM
Junior Member
wigglytoes is on a distinguished road
Default KB6524PS Sharp Drawer MW won't heat food, but magnetron gets hot.
Model Number: kb6524ps   Brand: -other-   Age: Less than 1 year
Hi:
Kind of a science question here. You might not know the answer, but your knowledge of how microwaves work could put me on the right path.
My Sharp microwave is basically brand new. (Unfortunately it's also out of warranty because it sat for a year waiting it's turn to be installed in a kitchen remodel)
I used it 4-10 times and it worked fine.
Then it broke. It won't heat food.
Everything powers on. The unit powers up, the display works perfectly, I can start a cook cycle, it will go through that normally, the light will come on, the unit will hum, but anything inside the MW does not heat up.
Additional details.
I've taken it apart, a little. (I even built a nice resistor wire with alligator clips to drain the capacitor. I've seen the warnings.)
Everything checks out visibly.
The magnetron checks out. In that I get close to a 0.0 ohm reading when I connect a multimeter to the two prongs. (My multimeter is analog, pretty old, and I would have a hard time seeing a small reading. Like 0.1 ohm or 0.2 ohm.) In fact it looks like it's exactly 0.0 ohm (But the accuracy of the multimeter is questionable) Perhaps that's a clue. What would cause a 0.0 ohm reading? I know the reading is supposed to be tiny, like 0.3 or so, but 0.0 seems too small.
Also the magnetron shows an open circuit when I measure resistance between either prong and the body of the magnetron. As it's supposed to.
Here's the big clues.
1) If I run the microwave for a couple minutes, the magnetron gets very hot.
So the magnetron is heating up, but the food is not. It's like it's creating microwaves, but they aren't being moved into the food compartment of the microwave.
The stirrer is turning, when the unit is running.
2) The fan that is supposed to cool the magnetron wasn't working, until today. So the magnetron could have gotten quite hot in the couple weeks that I used it. However, I never ran a cycle over 2 minutes. No baked potatoes, or anything else which took a long time. But the magnetron was definitely on, without a fan blowing any cooling air on it.
3) During the short time that the unit worked, I hadn't tried any of the fancy settings. Just time and Start. The unit failed the first time when I tried the 'Sensor Reheat' button. It was at this point that I pulled out the directions. Sensor reheat is supposed to measure the steam coming off the food, and heat it accordingly. It didn't heat it at all, and eventually I canceled the cycle. It hasn't worked since.
To me, the fact that the magnetron heats up but food doesn't probably tells us what's going wrong.
Related Models
Frigidaire KB663GDM0 Wwh(v1) / Electric Self - Clean Oven
Frigidaire KB663GDM1 Wwh(v2) / Electric Self - Clean Oven
Frigidaire KB663GDM2 Wwh(v1) / Wall Oven
Frigidaire KB663LM0 Wwh(v1) / Electric Range
Frigidaire KB663LM1 Wwh(v1) / Electric Range
Frigidaire KB663LM2 Wwh(v1) / Electric Range
Frigidaire KB663LMO Wwh(v0) / Electric Range
Frigidaire KB883GDM1 Wwh(v1) / Electric Double Oven W/self Clean Upper
Frigidaire KB883GDM2 Wwh(v1) / Electric Range
Frigidaire KB883GDM3 Wwh(v2) / Electric Range
Frigidaire KB883GDMO Wwh(v2) / Electric Double Oven W/self Clean Upper
Frigidaire KB883LM0 Wwh(v1) / Electric Range
Frigidaire KB883LM1 Wwh(v1) / Electric Range
Frigidaire KB969LM0 Wwh(v1) / Electric Range
Frigidaire KB969LM3 Wwh(v1) / Electric Range
Whirlpool KBAL181TSS00 ACCESS DOORS, 18"
Whirlpool KBAR181TSS00 ACCESS DOORS, 18"
Whirlpool KBAU181VSS00 ACCESS DOORS 18"
Whirlpool KBAU272TSS00 ACCESS DOORS, 27"
Whirlpool KBAU272VSS00 ACCESS DOORS, 27"
Whirlpool KBAU302TSS00 ACCESS DOORS, 30"
Whirlpool KBAU362TSS00 ACCESS DOORS, 36"
Whirlpool KBAU362VSS00 ACCESS DOORS, 36"
Whirlpool KBAU482TSS00 ACCESS DOORS, 48"
Whirlpool KBAU482VSS00 ACCESS DOORS, 48"
Whirlpool KBBP100LSS0 BUILT-IN BAR CART 30"
Whirlpool KBCA06XPBL00 REFRIGERATOR
Whirlpool KBCA06XPBL01 REFRIGERATOR
Whirlpool KBCA06XPBS00 REFRIGERATOR
Whirlpool KBCA06XPBS01 REFRIGERATOR
Whirlpool KBCA06XPWH00 REFRIGERATOR
Whirlpool KBCA06XPWH01 REFRIGERATOR
Whirlpool KBCO06XPBL00 REFRIGERATOR
Whirlpool KBCO06XPBL01 REFRIGERATOR
Whirlpool KBCO24LSBX00 BEVERAGE CENTER
Whirlpool KBCO24LSBX01 BEVERAGE CENTER
Whirlpool KBCO24LSBX02 BEVERAGE CENTER
Whirlpool KBCO24LSBX03 BEVERAGE CENTER
Whirlpool KBCO24RSBX00 BEVERAGE CENTER
Whirlpool KBCO24RSBX01 BEVERAGE CENTER
Whirlpool KBCO24RSBX02 BEVERAGE CENTER
Whirlpool KBCO24RSBX03 BEVERAGE CENTER
Whirlpool KBCS24LSBS00 BEVERAGE CENTER
Whirlpool KBCS24LSBS01 BEVERAGE CENTER
Whirlpool KBCS24LSBS02 BEVERAGE CENTER
Whirlpool KBCS24LSBS03 BEVERAGE CENTER
Whirlpool KBCS24RSBS00 BEVERAGE CENTER
Whirlpool KBCS24RSBS01 BEVERAGE CENTER
Whirlpool KBCS24RSBS02 BEVERAGE CENTER
Whirlpool KBCS24RSBS03 BEVERAGE CENTER
Whirlpool KBCS24RSSS00 BEVERAGE CENTER
Whirlpool KBCS24RSSS01 BEVERAGE CENTER
Whirlpool KBCS24RSSS02 BEVERAGE CENTER
Whirlpool KBCS24RSSS03 BEVERAGE CENTER
KitchenAid KBDS100T DISPOSER
Whirlpool KBDS100T0 DISPOSER
Maytag KBDS24L92KA REF - SXS
Maytag KBDS24L92KW REF - SXS
Whirlpool KBDS250S0 DISPOSER
Whirlpool KBDS250S1 DISPOSER
Whirlpool KBDS250T1 DISPOSER
Whirlpool KBDS250V0 DISPOSER
Whirlpool KBDS250V1 DISPOSER
Whirlpool KBDS250V2 DISPOSER
Whirlpool KBDS250X DISPOSER
Whirlpool KBDS250X3 DISPOSER
Whirlpool KBDS250X4 DISPOSER
Whirlpool KBDS250X5 DISPOSER
Whirlpool KBEU121TSS00 BUILT-IN SIDE BURNER
Whirlpool KBFA20ERBL00 REFRIGERATOR
Whirlpool KBFA20ERBL01 REFRIGERATOR
Whirlpool KBFA20ERSS00 REFRIGERATOR
Whirlpool KBFA20ERSS01 REFRIGERATOR
Whirlpool KBFA20ERWH00 REFRIGERATOR
Whirlpool KBFA20ERWH01 REFRIGERATOR
Whirlpool KBFA25ERBL00 REFRIGERATOR
Whirlpool KBFA25ERBL01 REFRIGERATOR
Whirlpool KBFA25ERSS00 REFRIGERATOR
Whirlpool KBFA25ERSS01 REFRIGERATOR
Whirlpool KBFA25ERWH00 REFRIGERATOR
Whirlpool KBFA25ERWH01 REFRIGERATOR
Whirlpool KBFC42FSS00 42" BOTTOM MOUNT BUILT IN REFRIGERATOR
Whirlpool KBFC42FTS00 42" BOTTOM MOUNT BUILT IN REFRIGERATOR
Whirlpool KBFC42FTS02 42" BOTTOM MOUNT BUILT IN REFRIGERATOR
Whirlpool KBFC42FTS03 42" BOTTOM MOUNT BUILT IN REFRIGERATOR
KitchenAid KBFC42FTS04 42" BUILT IN REFRIGERATOR
Whirlpool KBFL25ETBL00 REFRIGERATOR
Whirlpool KBFL25ETBL01 REFRIGERATOR
KitchenAid KBFL25ETBL11 BOTTOM-MOUNT REFRIGERATOR
Whirlpool KBFL25ETSS00 REFRIGERATOR
Whirlpool KBFL25ETSS01 REFRIGERATOR
KitchenAid KBFL25ETSS11 BOTTOM-MOUNT REFRIGERATOR
Whirlpool KBFL25ETWH00 REFRIGERATOR
Whirlpool KBFL25ETWH01 REFRIGERATOR
KitchenAid KBFL25ETWH11 BOTTOM-MOUNT REFRIGERATOR
Whirlpool KBFL25EVMS00 REFRIGERATOR
Whirlpool KBFL25EVMS1 REFRIGERATOR
Whirlpool KBFL25EVMS2 REFRIGERATOR
Whirlpool KBFO42FSX00 42" BOTTOM MOUNT BUILT IN REFRIGERATOR
Whirlpool KBFO42FTX00 42" BOTTOM MOUNT BUILT IN REFRIGERATOR
Whirlpool KBFO42FTX02 42" BOTTOM MOUNT BUILT IN REFRIGERATOR
Whirlpool KBFO42FTX03 42" BOTTOM MOUNT BUILT IN REFRIGERATOR
KitchenAid KBFO42FTX04 42" BUILT IN REFRIGERATOR
Whirlpool KBFS20ETBL00 REFRIGERATOR
Whirlpool KBFS20ETBL01 REFRIGERATOR
Whirlpool KBFS20ETSS00 REFRIGERATOR
Whirlpool KBFS20ETSS01 REFRIGERATOR
Whirlpool KBFS20ETWH00 REFRIGERATOR
Whirlpool KBFS20ETWH01 REFRIGERATOR
Whirlpool KBFS20EVBL00 REFRIGERATOR
Whirlpool KBFS20EVBL1 REFRIGERATOR
Whirlpool KBFS20EVBL2 REFRIGERATOR
KitchenAid KBFS20EVBL3 REFRIGERATOR
KitchenAid KBFS20EVBL4 REFRIGERATOR
KitchenAid KBFS20EVBL5 REFRIGERATOR
Whirlpool KBFS20EVMS00 REFRIGERATOR
Whirlpool KBFS20EVMS1 REFRIGERATOR
Whirlpool KBFS20EVMS2 REFRIGERATOR
Whirlpool KBFS20EVMS3 REFRIGERATOR
Whirlpool KBFS20EVMS4 REFRIGERATOR
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Display/Control panel is off on Sharp Electric Range w/ micowave drawer cordobap Oven Repair (including Ranges and Cooktops) 0 02-06-2014 08:46 AM
food freezing in crisper drawer stockm Refrigerator & Freezer Repair 1 07-13-2012 12:55 PM
Food freezing in main compartment and top produce drawer jrhtools Refrigerator & Freezer Repair 6 07-21-2011 08:21 AM
Low heat, new magnetron anonymouse Microwave Repair 0 03-06-2010 06:15 PM
Fruit/Veggie drawer freezes food jerrykeely Refrigerator & Freezer Repair 0 05-20-2008 01:45 PM
