Discuss
Bad door monitor switch WB24X817 (AP2024325)
 in
Microwave Repair
Hi, When I start the microwave, the timer countdown starts, I hear few clicks but the turn table does not
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Bad door monitor switch WB24X817 (AP2024325)
  #1 (permalink)
Old 09-22-2015, 09:16 AM
Junior Member
yfegade is on a distinguished road
Default Bad door monitor switch WB24X817 (AP2024325)
Model Number: PEB2060DM2BB   Brand: GE   Age: 1 - 5 years
When I start the microwave, the timer countdown starts, I hear few clicks but the turn table does not rotate and microwave does not start (no humming, no heat).
It seems that either the primary/secondary interlock switch or the monitor switch is bad. I suspect it's the monitor switch because when I check the connectivity between the two ends of the monitor switch, it always shows 0 ohms regardless if the door is closed or not. The GE manual says that I have to remove one connector from this switch to check the connectivity, but I don't understand why removing one connector would make any difference (would the monitor switch always show 0 ohms when both connectors are attached?).
Anyways, I tried to remove one connector, but it seems to be stuck. With normal pulling/wiggling I can remove any connectors. I was afraid if I pull hard it would break something and I will have bigger mess.
I wonder, if there is a trick to remove those connectors from the switch.
How do I remove the switch to replace with the new one (Do I have to remove board latch in order to replace the switch)?
I was thinking while the microwave is already open, I might as well replace all 3 switches (if one has gone bad, other two are probably on their way too).
Connectors on the primary interlock switch are hard to remove as well (any trick to remove those).
Appreciate any help. Thanks
Related Models
General Electric PEB2060DM2BB MICROWAVE
General Electric PEB2060DM2CC MICROWAVE
General Electric PEB2060DM2WW MICROWAVE
General Electric PEB2060SM1SS MICROWAVE
General Electric PEB2060SM2SS MICROWAVE
General Electric PEB206CDN1BB MICROWAVE
General Electric PEB206CDN1WW MICROWAVE
General Electric PEB206CDN2BB MICROWAVE
General Electric PEB206CDN2WW MICROWAVE
General Electric PEB206CSN1SS MICROWAVE
General Electric PEB206CSN2SS MICROWAVE
General Electric PEM1050DM1BB MICROWAVE
General Electric PEM1050DM1CC MICROWAVE
General Electric PEM1050DM1WW MICROWAVE
General Electric PEM1050SM1SS MICROWAVE
General Electric PEM31DM1BB MICROWAVE
General Electric PEM31DM1CC MICROWAVE
General Electric PEM31DM1WW MICROWAVE
General Electric PEM31DM2BB MICROWAVE
General Electric PEM31DM2CC MICROWAVE
General Electric PEM31DM2WW MICROWAVE
General Electric PEM31DM3BB MICROWAVE
General Electric PEM31DM3CC MICROWAVE
General Electric PEM31DM3WW MICROWAVE
General Electric PEM31DM4BB MICROWAVE
General Electric PEM31DM4CC MICROWAVE
General Electric PEM31DM4WW MICROWAVE
General Electric PEM31SM1SS MICROWAVE
General Electric PEM31SM2SS MICROWAVE
General Electric PEM31SM3SS MICROWAVE
General Electric PEM31SM4SS MICROWAVE
Maytag PER1125ACW RANGE- F/S STD GAS
Maytag PER3524ACW RANGE- S/C F/S ELE
Maytag PER3525ACW RANGE- S/C F/S ELE
Maytag PER3724ACB RANGE- S/C F/S ELE
Maytag PER3724ACW RANGE- S/C F/S ELE
Maytag PER3725ACW RANGE- S/C F/S GAS
Maytag PER4100BAW RANGE- F/S STD ELE
Maytag PER4102BAH RANGE- F/S STD ELE
Maytag PER4102BAT RANGE- F/S STD ELE
Maytag PER4305BAH RANGE- F/S STD ELE
Maytag PER4305BAT RANGE- F/S STD ELE
Maytag PER4310BAQ RANGE- F/S STD ELE
Maytag PER4310BAW RANGE- F/S STD ELE
Maytag PER4310BCW RANGE- F/S STD ELE
Maytag PER4311ACW RANGE- F/S STD ELE
Maytag PER4510AAQ RANGE- F/S STD ELE
Maytag PER4510AAW RANGE- F/S STD ELE
Maytag PER4510ACW RANGE- F/S STD ELE
Maytag PER5502BAH RANGE- S/C F/S ELE
Maytag PER5502BAT RANGE- S/C F/S ELE
Maytag PER5505BAH RANGE- S/C F/S ELE
Maytag PER5505BAT RANGE- S/C F/S ELE
Maytag PER5508BAQ RANGE- S/C F/S ELE
Maytag PER5508BAW RANGE- S/C F/S ELE
Maytag PER5509AAW RANGE- S/C F/S ELE
Maytag PER5510AAQ RANGE- S/C F/S ELE
Maytag PER5510AAW RANGE- S/C F/S ELE
Maytag PER5510ACW RANGE- S/C F/S ELE
Maytag PER5510BAQ RANGE- S/C F/S ELE
Maytag PER5510BAW RANGE- S/C F/S ELE
Maytag PER5515BCQ RANGE- S/C F/S ELE
Maytag PER5515BCW RANGE- S/C F/S ELE
Maytag PER5702BAH RANGE- S/C F/S ELE
Maytag PER5702BAT RANGE- S/C F/S ELE
Maytag PER5705BAH RANGE- S/C F/S ELE
Maytag PER5705BAT RANGE- S/C F/S ELE
Maytag PER5708BAQ RANGE- S/C F/S ELE
Maytag PER5708BAW RANGE- S/C F/S ELE
Maytag PER5710BAC RANGE- S/C F/S ELE
Maytag PER5710BAQ RANGE- S/C F/S ELE
Maytag PER5710BAW RANGE- S/C F/S ELE
Maytag PER5715BAQ RANGE- S/C F/S ELE
Maytag PER5715BAW RANGE- S/C F/S ELE
Maytag PER5715BCQ RANGE- S/C F/S ELE
Maytag PER5715BCW RANGE- S/C F/S ELE
Maytag PER5720ACW RANGE- S/C F/S ELE
Maytag PER5720LAQ RANGE- S/C F/S ELE
Maytag PER5720LAW RANGE- S/C F/S ELE
Maytag PER5750LAQ RANGE- S/C F/S ELE
Maytag PER5750LAS RANGE- S/C F/S ELE
Maytag PER5750LAW RANGE- S/C F/S ELE
Maytag PER5750QAQ RANGE- S/C F/S ELE
Maytag PER5750QAS RANGE- S/C F/S ELE
Maytag PER5750QAW RANGE- S/C F/S ELE
Maytag PER5750QCQ RANGE- S/C F/S ELE
Maytag PER5750QCW RANGE- S/C F/S ELE
Maytag PERL451ACQ RANGE- F/S STD ELE
Maytag PERL451ACW RANGE- F/S STD ELE
Maytag PES3759BCB RANGE- F/S STD ELE
Maytag PES3759BCS RANGE- F/S STD ELE
Maytag PES3759BCW RANGE- F/S STD ELE
Frigidaire PF18TFA1 Frg(v2) / Top Mount Refrigerator
General Electric PFCA1NJZADSS BOTTOM MOUNT REFRIGERATOR
General Electric PFCA1NJZBDSS BOTTOM MOUNT REFRIGERATOR
General Electric PFCA1NJZCDSS BOTTOM MOUNT REFRIGERATOR
General Electric PFCE1NFYAANB BOTTOM MOUNT REFRIGERATOR
General Electric PFCE1NFYCANB BOTTOM MOUNT REFRIGERATOR
General Electric PFCE1NFZAANB BOTTOM MOUNT REFRIGERATOR
General Electric PFCE1NFZBANB BOTTOM MOUNT REFRIGERATOR
General Electric PFCE1NFZCANB BOTTOM MOUNT REFRIGERATOR
General Electric PFCE1NJWADBB BOTTOM MOUNT REFRIGERATOR
General Electric PFCE1NJWADSS BOTTOM MOUNT REFRIGERATOR
General Electric PFCE1NJWADWW BOTTOM MOUNT REFRIGERATOR
General Electric PFCE1NJWBDBB BOTTOM MOUNT REFRIGERATOR
General Electric PFCE1NJWBDSS BOTTOM MOUNT REFRIGERATOR
General Electric PFCE1NJWBDWW BOTTOM MOUNT REFRIGERATOR
General Electric PFCE1NJWCDBB BOTTOM MOUNT REFRIGERATOR
General Electric PFCE1NJWCDSS BOTTOM MOUNT REFRIGERATOR
General Electric PFCE1NJWCDWW BOTTOM MOUNT REFRIGERATOR
General Electric PFCE1NJYADBB BOTTOM MOUNT REFRIGERATOR
General Electric PFCE1NJYADSS BOTTOM MOUNT REFRIGERATOR
General Electric PFCE1NJYADWW BOTTOM MOUNT REFRIGERATOR
General Electric PFCE1NJYCDBB BOTTOM MOUNT REFRIGERATOR
General Electric PFCE1NJYCDSS BOTTOM MOUNT REFRIGERATOR
General Electric PFCE1NJYCDWW BOTTOM MOUNT REFRIGERATOR
General Electric PFCE1NJZADSS BOTTOM MOUNT REFRIGERATOR
General Electric PFCE1NJZBDSS BOTTOM MOUNT REFRIGERATOR
General Electric PFCE1NJZCDSS BOTTOM MOUNT REFRIGERATOR
General Electric PFCF1NFWABB BOTTOM MOUNT REFRIGERATOR
  #2 (permalink)
Old 09-25-2015, 07:01 PM
Junior Member
Default
After going through the circuit diagram, I think the monitor switch is fine. I could not test monitor switch by isolating it (by removing one of its connector as GE manual says).
From circuit diagram it looks like the primary switch must be faulty.
Problem is - I can't seem to knock lose the connectors on the primary switch either. Any ideas?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Monitor Switch? tobomeo Microwave Repair 1 12-04-2012 11:51 AM
GE JE1860SH04 Door Monitor darrelljs Microwave Repair 0 04-21-2011 10:51 AM
Monitor Switch Installation Help for Frigidaire Gallery & Gallery Professional tinammueting Microwave Repair 0 03-23-2011 09:09 AM
Monitor light does not come on. tenoral Oven Repair (including Ranges and Cooktops) 1 04-18-2008 10:51 AM
Monitor fuse blows, door switches OK !? mgai7755 Microwave Repair 0 04-16-2008 01:28 PM
