Discuss
Microwave Repair
 in
Microwave Repair
When the door on the microwave is closed, it is saying the door is not closed. I had all three
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Microwave Repair
  #1 (permalink)
Old 08-22-2015, 07:00 AM
Junior Member
Bryce 309 is on a distinguished road
Default Microwave Repair
Model Number: MMH1162XVB1   Brand: Whirlpool   Age: 5 - 10 years
When the door on the microwave is closed, it is saying the door is not closed. I had all three switches checked and they are all good. The light and the vent both work. What else can the problem be?
Related Models
Amana MMO166 MWAVE- MOUNTED OVER RANGE/WO
Amana MMO166/101W MWAVE - FAMILY SIZE (60 HZ)
Amana MMO16610 MWAVE - FAMILY SIZE (60 HZ)
Amana MMO166MN002 RANGE- S/C S/I DDRAFT GAS
Amana MMO219 MWAVE- CNTRTP / STAND ALONE
Amana MMO2661D MWAVE- MOUNTED OVER RANGE/WO
Amana MMO2661W MWAVE- MOUNTED OVER RANGE/WO
Amana MMO2671D01 MWAVE - FAMILY SIZE (60 HZ)
Amana MMO2671WW01 MWAVE - FAMILY SIZE (60 HZ)
Maytag MMV1153AAB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV1153AAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV1153BAB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV1153BAB15 MICROWAVE OVEN/HOOD 1.5 Cu. Ft.
Maytag MMV1153BAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV1153BAS15 MICROWAVE OVEN/HOOD 1.5 Cu. Ft.
Maytag MMV1153BAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV1153BAW16 MICROWAVE OVEN/HOOD 1.5 Cu. Ft.
Maytag MMV1153WB0 Microwave Oven 1.5 Cu. Ft.
Maytag MMV1153WB1 MICROWAVE OVEN 1.5 CU. FT.
Maytag MMV1153WB2 MICROWAVE OVEN 1.5 CU. FT.
Maytag MMV1153WS0 Microwave Oven 1.5 Cu. Ft.
Maytag MMV1153WS1 MICROWAVE OVEN 1.5 CU. FT.
Maytag MMV1153WS2 MICROWAVE OVEN 1.5 CU. FT.
Maytag MMV1153WW0 Microwave Oven 1.5 Cu. Ft.
Maytag MMV1153WW1 MICROWAVE OVEN 1.5 CU. FT.
Maytag MMV1153WW2 MICROWAVE OVEN 1.5 CU. FT.
Maytag MMV1163DB00 Microwave Oven/Hood 1.6 Cu. Ft.
Maytag MMV1163DS00 Microwave Oven/Hood 1.6 Cu. Ft.
Maytag MMV1163DW00 Microwave Oven/Hood 1.6 Cu. Ft.
Maytag MMV1164WB0 MICROWAVE OVEN 1.6 CU. FT.
Maytag MMV1164WB1 MICROWAVE OVEN 1.6 CU. FT.
Maytag MMV1164WS0 MICROWAVE OVEN 1.6 CU. FT.
Maytag MMV1164WS1 MICROWAVE OVEN 1.6 CU. FT.
Maytag MMV1164WW0 MICROWAVE OVEN 1.6 CU. FT.
Maytag MMV1164WW1 MICROWAVE OVEN 1.6 CU. FT.
Frigidaire MMV150KBA MICROWAVE OVEN
Frigidaire MMV150KWA MICROWAVE OVEN
Maytag MMV4184AAB MWAVE- MOUNTED UNDER CABINET
Maytag MMV4184AAQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV4184AAW MWAVE- MOUNTED UNDER CABINET
Maytag MMV4203DB00 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV4203DQ00 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV4203DS00 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV4203DW00 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV4203WB0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV4203WQ0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV4203WS0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV4203WW0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV4205AAB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV4205AAQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV4205AAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV4205AAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV4205BAB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV4205BAB14 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV4205BAB17 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV4205BAQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV4205BAQ14 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV4205BAQ17 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV4205BAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV4205BAS14 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV4205BAS17 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV4205BAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV4205BAW15 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV4205BAW18 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV5000ADA MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000ADB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000ADW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BAB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BAC MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BAQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BAW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BDB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BDC MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BDQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BDW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5100AAB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5100AAQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5100AAS MWAVE- MOUNTED UNDER CABINET
Maytag MMV5100AAW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156AAB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156AAQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156AAS MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156AAW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156ACB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156ACQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156ACS MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156ACW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5165AAB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165AAQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165AAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165AAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165BAB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165BAB14 Microwave Oven/Hood 1.6 Cu. Ft.
Maytag MMV5165BAB15 MICROWAVE OVEN/HOOD 1.6 Cu. Ft.
Maytag MMV5165BAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165BAS14 Microwave Oven/Hood 1.6 Cu. Ft.
Maytag MMV5165BAS15 MICROWAVE OVEN/HOOD 1.6 Cu. Ft.
Maytag MMV5165BAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165BAW15 Microwave Oven/Hood 1.6 Cu. Ft.
Maytag MMV5165BAW16 MICROWAVE OVEN/HOOD 1.6 Cu. Ft.
Maytag MMV5186AAB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186AAQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186AAS MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186AAW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186ACB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186ACQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186ACS MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186ACW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5201DB00 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5201DS00 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5201DW00 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5207AAB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207AAQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207AAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207AAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207ACB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207ACQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207ACS MWAVE- MOUNTED OVER RANGE/WO
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
microwave repair help dia Microwave Repair 1 10-01-2012 05:54 PM
Microwave Wall Oven combo - Microwave repair Alexismyboy Microwave Repair 0 09-15-2012 09:39 AM
microwave repair allene Microwave Repair 3 10-13-2009 05:17 AM
Microwave repair SherryT Microwave Repair 0 01-31-2009 12:54 PM
Microwave Repair jpsorg@aol.com Microwave Repair 0 10-12-2008 10:12 AM
